Rear Speaker Placement Question for 7.2 Set up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-19-2012, 07:18 PM - Thread Starter
04rex's Avatar
Quoted: 132 Post(s)
Hey guys, i have a question about placement for the rears in a 7.2 setup. My room is 13 wide by 17 length. I am considering doing 7.2. Currently my 5.2 setup is all Paradigm Studio series with the rears being the ADP590s. The way the room is, i have the rears placed on a corner type shelf in each corner of the room with the woofer facing the listening position (so on an angle). (only way i can set it up due to the layout) The seating position is about 2 feet away from the rear wall (so at about 15 feet). I was thinking of putting in wall rears directly behind the listing position making it 7.2. This would mean that all the rears are kind of on the same wall.
Would this work like 7.2 should work? It is the only real way that i would be able to do it if i did.
Any help or suggestions is appreciated.
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 300, Apple TV Gen 3, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v.5 L/R, CC-690 v.5 C, Studio 10 v.5 x4 Surround Side and Backs, 4x DIY 15" Ultimax Subwoofers in 3.0 Cu Ft sealed boxes, Cerwin Vega CV-5000 for Subs, Anthem MRX 720, Outlaw Audio 7700, HTPC, Apple TV Gen 4, X-Box One, Harmony Ultimate Remote, Ben-Q W1070, 92" screen
04rex is offline
post #2 of 3 Old 08-19-2012, 09:31 PM
sdurani's Avatar
Quoted: 4913 Post(s)
Liked: 3347
With all 4 surrounds on the back wall, you wouldn't get any rear vs side separation in the surround field, kinda defeating the point of a 7.1 set-up. In your situation, I would stick with a 5.1 layout.
Sanjay
sdurani is online now
post #3 of 3 Old 08-20-2012, 08:18 AM - Thread Starter
04rex's Avatar
Quoted: 132 Post(s)
Thanks for the advice. That is what i was thinking as well.
04rex is offline
