Outdoor Speaker Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-21-2012, 08:31 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Ok, so I did try searching, but as most of you know this new search engine is terrible...all I could find is garbage from 2004 and older.
Anyways...now on to my "setup question".
I hope this makes sense.
Basically I need to install a few speakers for my patio, but I need them to be removable for winter as I have no good place to cover them and I need them to last.
Based on where I need to place them I think I am going to be "forced" to use something like this.
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10904&cs_id=1090401&p_id=6966&seq=1&format=2
I have a separate amp off my main system that I will be using to power them.
I figured it would make sense to include one of these as well.
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10903&cs_id=1090304&p_id=6851&seq=1&format=2
NOW...I assume all I do is run "outdoor" rated wire out of my basement, then underground to where it will hook up to the volume control, then I go from the volume control to the back of the speakers.
Is it that simple ?
Then in the winter, I simply "remove" the speakers and wrap up the exposed wires from the control and away I go ?
Is there a "better" way to do this ?  I wish I would find somewhere to mount real speakers...but I really have no "structures" in close enough proximity.
Thanks in advance!
toofast68 is offline
post #2 of 5 Old 08-21-2012, 10:55 AM
underminded999's Avatar
Quoted: 29 Post(s)
I am also in the planning stages for outdoor music.  However, I am not impressed with monoprice's current offerings.  By the by, the speaker you linked is currently out of stock.
There was a thread here a weeks ago, that was about someone being unhappy with their outdoor speakers.
I am still checking specs and have not found anything that I like for a price I want.  So since my next big shindig won't be until December, I am still looking for what I want for the price I want.
Back on subject...
The process is simple enough and you have the gist of it.  I read somewhere that one of the weakest links in an outdoor system is the additional volume box, but I can't find it, or the thread I mentioned above.
So with that said, what distance away will the speakers be?  How loud do you want them to be?  And what will the source of music be; i.e. iPod/MP3, AVR's "B" system, or some other in line system.  There may be a better way to control sound, than the one you are currently thinking about.
EDIT. Found it, forrest for the trees and all...
http://www.avsforum.com/t/1424642/distorted-speakers-need-more-volume
underminded999 is offline
post #3 of 5 Old 08-21-2012, 11:21 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Is it that simple ?
Any outdoor system has to be designed to meet your application's needs. There's a big difference between playing background music and running dance parties.
There are also SQ issues.
There are speakers that are designed for year-around use outdoors.
"TIC GS-3 150-Watt Outdoor In-Ground Speaker"
and:
"TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers"
As far as putting wiring underground, mere outdoor rated cable won't do.
You want cable that is rated for use underground, or put it in a well-drained conduit.
Not to worry, your local home improvement store probably has what you need on the shelf.
arnyk is offline
post #4 of 5 Old 08-21-2012, 11:56 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Yep, I really just need background music...vs. dance party.
I will have the cable in conduit (coming from the basement).
Now I just wonder if I need to add 4 speakers vs. the 2 for future upgrades. Also looks like the "in line" volume control is a BAD IDEA ?
So perhaps I will just sink a small weather proof box in the ground to join the cables together...and control via my zone control on my reciever via my cell phone.
post #5 of 5 Old 08-22-2012, 07:48 AM
caper_1's Avatar
Liked: 26
I bought my parents a pair of portable wireless speakers from the source. There is a sender unit from a sound source, and the speakers go where ever you want with either AC power or battery (would need rechargeables). The speakers have their own volume and power button and have a nice glowing blue light aiming down so you don't trip over them at night. I can't find the ones I bought, but here are some options:
AWS5 Indoor/outdoor wireless
AU Velo 4 pack
If it is only background music, they an option. Cheers.
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
