How to get my albums onto an Ipod? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-15-2012, 06:53 PM - Thread Starter
sly1's Avatar
I last tried connecting my turntable to receiver then using the only plug on receiver (tape mon-rec.out) rca plugs to an adapter down to 1 mini plug which I plugged into line in on sound card/MB, I also connected the extra ground between TT and receiver but still got a loud feedback? Though the music did play thru pc speakers-not great though. I also need a free pc recorder too I believe.
After just looking, maybe I should have used the tape in for my turntable? There must be an easy way to accomplish this? TIA!
sly1 is offline
post #2 of 5 Old 09-15-2012, 10:52 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
Try searching for a phono preamp with a usb output.
lovinthehd is offline
post #3 of 5 Old 09-16-2012, 12:29 AM
/dev/null's Avatar
I'd suggest putting them next to each other in a room alone with candlelight, and let them get to know each other first. They'll do the rest... eek.gif
J/K
The 1/8" jack on your laptop is probably expecting a microphone level input. You could either try going into the System Mixer on your laptop to try to reduce the gain on that input, or get a dedicated ADC(analog to digital converter) with a USB connection to your computer. The second will definitely be the better sounding. Some even come with their own audio recorder/editor bundled in the package. An editor will allow you to record the entire side, and cut it into the individual songs. Once cut up, you can either use it to save as MP3/AAC or save them as WAV files and let iTunes do the job of converting. Having the WAV files(uncompressed PCM audio), will let you make a standard Redbook CD disc, as well as dump them to the iPod.
Peter M
******This space for rent******
/dev/null is offline
post #4 of 5 Old 09-16-2012, 06:15 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
It is unlikely that you got feedback, but it is likely that you got a loud hum. The extra ground might be even causing the hum.
You seem to have about 5 different questions jumbled together:
(1) Interfacing a turntable to a PC
(2) Interfacing a turntable to a receiver
(3) Interfacing a receiver to a PC
(4) Interfacing an iPod to a receiver
(5) Interfacing an iPod to a PC
Try breaking your situation down into individual questions. A little google searching will get you lots of good answers to any of them.
arnyk is offline
post #5 of 5 Old 09-18-2012, 12:20 PM - Thread Starter
sly1's Avatar
Geez, I must be brain dead? I have a new in box converter from radioshack I got a few years back, of course no directions, do I just use this between my turntable and the line in on my desktop computer? I don't think I have software though too?? TIA!
sly1 is offline
