Help adding second sub??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-30-2012, 11:25 AM - Thread Starter
prn1972's Avatar
I have a yamaha yht s401 soundbar with all in one receiver/subwoofer. I want more bass & want to add second sub. What would be best way to add one to this system? & will it turn It's volume up with main system or have to do it separate? Thx for any help
prn1972 is offline
post #2 of 6 Old 10-04-2012, 08:20 AM
has7738's Avatar
Liked: 24
Sorry, you're stuck. This soundbar has no accessible connection for a subwoofer. Any other solution I can think of would be a haywired mess, and though you could get a sub to play, you'd never be able to control it well.
has7738 is offline
post #3 of 6 Old 10-04-2012, 08:37 AM
Perry R's Avatar
Liked: 26
A sub with a amp that accepts speaker level inputs will work.
Easy to hook up and it will work with your volume control
Perry R is offline
post #4 of 6 Old 10-04-2012, 03:15 PM
has7738's Avatar
Liked: 24
Good catch. Forgot about those, I don't see them much. I guess you could also use a speaker to line level adapter and go into a powered sub that way too.
has7738 is offline
post #5 of 6 Old 10-06-2012, 07:28 PM
HopefulFred's Avatar
Quoted: 523 Post(s)
Liked: 484
Won't those speaker signals be high-pass filtered?
HopefulFred is offline
post #6 of 6 Old 10-06-2012, 09:59 PM
has7738's Avatar
Liked: 24
Perhaps, but no crossover is perfect. Might be enough left over for a sub if you cranked the gain. I dunno, the whole thing seems sort of a hack job. Soundbars: you love them, you hate them. Clearly the boffins at Yamaha had no intention of anyone very adding a second sub.
has7738 is offline
