Anyone prefer 100hz crossovers? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 03-14-2013, 06:56 AM
Nightlord's Avatar
Quoted: 713 Post(s)
Liked: 239
Originally Posted by kiwi2 View Post
Tell that to Nightlord above!
Well, my livingroom speakers are quite capable at normal full range (largest full range speaker of the brand), I just want to go 5-10Hz deeper than that (into the infrasonics), be able to play louder, bring distortion in bass range down and smoothen out room respones from driving the room from 8 points instead of 2.
Top graph - fullrange, bottom graph - with subwoofers.
My front theater speakers on the other hand are designed for use with subwoofers and a rated to handle 7dB more @100Hz than my fullranges can.
Under construction: the Larch theater
Nightlord is offline
Old 03-20-2013, 06:34 AM
Eyleron's Avatar
Quoted: 253 Post(s)
Liked: 146
If I was going to use a 80 or 100hz crossover, then I may as well just brought myself small 4" satellite speakers.
Which might be fine if you needed low output. A headphone driver too has enough frequency extension, but not enough output 12 feet away. For me, to get 110db peaks from seats without needing huge xmax woofers and huge amps, I had to go with 10" woofers. But because they're sensitive, they don't extend low so I crossover at 80-100hz.
I hear you about the smoother graph versus the blend.
Have you looked at distortion graphs in REW at your desired drive level? It's a newer feature in REW.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is online now
Old 03-20-2013, 04:57 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
No I haven't as of yet but may be something I will look into one day. Thanks for the suggestion.
kiwi2 is offline
Old 03-21-2013, 05:37 PM
Kelvin1965S's Avatar
Quoted: 260 Post(s)
Liked: 161
Well I'm going to do a big 'U' turn today: The reason I ended up at 100Hz was due to a colouration from my centre speaker which is really positioned too close to the floor. At 80Hz it gets an extra bit of bass and on louder sections it starts to sound 'muddy' so I settled on 100Hz as I wanted to retain some 'depth' to my surround since 100Hz is starting to become directional I wanted the surround effect to stay at the sides and back rather than at the front in my sub. I only have a global crossover setting in my Oppo, so I have to chose the best compromise.
Anyway, today I experimented with a phantom centre setting. This totally changed the sound, making it much more 'open' yet as my seat is dead centre it is near impossible to tell that there is no centre. Even sitting off to one side still sounds better (not that my OH would notice TBH wink.gif ). I found that I could run at 60Hz crossover (40Hz started to sound 'muddy' again and the speakers sounded less punchy/dynamic). This worked better than 80Hz since I have a bit of a bass null at my seat and using 60Hz gives a more even response.
It really has made the system 'sing' and I listened to a 'Police' concert disc twice as it just sounded so good set this way. It seems a bit of a waste of a £600 centre speaker, but I'll look into trying to rig up a higher stand for use when I have my projector on.
It's threads like this that have made me reassess my set up (which I've become a bit disappointed with lately due to the colouration issue) so I'm grateful for the information within, even if it just spurred me on to try a few experiments for myself and let my ears (rather than THX) be my guide.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is online now
Old 03-21-2013, 06:01 PM
primetimeguy's Avatar
Quoted: 561 Post(s)
Liked: 359
I noticed you are setting crossovers in your oppo.  Is this because you are using analog connection rather than digital/HDMI?
primetimeguy is offline
Old 03-21-2013, 06:39 PM
Quoted: 260 Post(s)
Liked: 161
Yes, I have an older Arcam AV9 that doesn't decode HD soundtracks (but sounds better for stereo than the HD decoding receiver I had previously). For AV use the AV9 is just an 8 channel volume control.
Old 03-21-2013, 07:24 PM - Thread Starter
aarons915's Avatar
Quoted: 38 Post(s)
Liked: 33
Well I have to kind of update my stance on this, I was messing around with an 80hz and 60hz crossover setting with my sub turned off listening to music pretty loud and it didn't sound like the woofers were bottoming out or that there was too much distortion. I guess the real issue is either I'm getting a lot of room gain or that I just don't like that much bass. I'm going to be getting a mic soon to check my frequency response to see if that's it but I suspect I just don't like as much bass as most people, with a 100hz crossover and my sub set pretty low it sounds best to me for music at least. I like the extra oomph the 80hz crossover provides for movies.
aarons915 is offline
Old 03-22-2013, 11:58 AM
Quoted: 260 Post(s)
Liked: 161
Being able to set different crossovers for different uses can be useful I find: My AV9 has 5 memories so I could have 5 different crossover settings (and speaker level/distances if I wished) as well as my Oppo since I use it's internal decoder for BluRay viewing.
So for me just changing the input on the AV9 gives me two choices of crossover (any input that uses the current AV9 setting and the external analogue input which uses the player's settings). After yesterday's testing I now have a 60Hz crossover and phantom centre for high level BluRay watching, but for lower level day to day TV watching I use a 100Hz setting in the AV9 with the centre engaged which seems to work better as the phantom centre image tends to collapse at lower listening levels. Previously I'd just set everything to 80Hz without really testing it, so it's good to experiment and find an improvement. Every system and room is different so in the end it's your own ears that have to decide of course.
Old 03-22-2013, 01:10 PM
Nightlord's Avatar
Quoted: 713 Post(s)
Liked: 239
If receiver handles pushing to fronts before pushing to sub, try 250hz on the center.
Old 03-22-2013, 01:31 PM
Quoted: 260 Post(s)
Liked: 161
Unfortunately both my crossover options (Oppo and AV9 processor) are global. However, I'm a trained electronics Engineer so I may yet make up an external crossover box to put between my processor and power amp. However the easier solution is that I'm going to attempt to make a lift up centre speaker bracket so that the centre can be raised when watching on the projector (more critical listening and higher level than day to day TV) since it's the proximity to the floor that is causing the issue that forces me to use a higher crossover when the centre is in use.
Old 03-25-2013, 12:30 AM
derrickdj1's Avatar
Quoted: 885 Post(s)
Liked: 597
The XO should be based on the sub and speakers:
mains 50 Hz-20,000 kHz
center and surround 70 Hz-20,000 kHz
Sub 29 Hz- 180 Hz
xo range 70-180 Hz
in this example a range of 70-180 is acceptable. In general set the xo 10-15 Hz higher than the weakest speakers frequency range. Also try to stay under 100 hz unless this is a satellite system which may xo the sub at 120-200 Hz. Some subs don't do well over 80 Hz so it all depends on the speakers and the subs undistorted frequency response.
derrickdj1 is offline
Old 03-25-2013, 09:25 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
In "theory" going by the "numbers". If that 180 crossover sounds terrible though and makes your system sound sterile and boring... then it isn't acceptable. Ultimately you need to go with what sounds good over going by numbers.
kiwi2 is offline
Old 03-26-2013, 12:23 AM
derrickdj1's Avatar
Quoted: 885 Post(s)
Liked: 597
That is why I stated staying under 100 Hz for the sub is good unless you have a small satellite system where you have to use a higher sub xo.smile.gif
Old 03-27-2013, 04:40 PM - Thread Starter
aarons915's Avatar
Quoted: 38 Post(s)
Liked: 33
Sub 29 Hz- 180 Hz
xo range 70-180 Hz
This is the "normal" recommendation but the point of the post was asking if anyone preferred a crossover higher than 80hz but whose speakers could be crossed over at 80 if they wanted.
Old 08-04-2013, 08:34 AM - Thread Starter
aarons915's Avatar
Quoted: 38 Post(s)
Liked: 33
Another update and finally solved my issue with an 80hz crossover all along. My main issue is 99% of receivers use a 2nd order high pass filter for the speakers which are designed to combine with a sealed speakers 80hz natural 2nd order roll off to combine for a 4th order rolloff similar to the subwoofers low pass filter. The problem is most towers, mine included, are ported and have an f3 much lower than 80hz so you're basically getting a lot of extra bass from the mains that you shouldn't be causing the bass to sound bloated. The answer with these kind of speakers is to find a receiver or in my case a separate processor that allows you to use a 4th order high pass so you can effectively have a 4th order high pass and low pass filter for proper blending to the sub.
Old 08-04-2013, 08:58 AM
Nightlord's Avatar
Quoted: 713 Post(s)
Liked: 239
Great.
The originator of 80Hz uses 30/18 (Bessel) in his filter, btw. So with 4th order you're getting in the right range.
Old 08-06-2013, 03:05 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Did you end up using JRiver for this?
kiwi2 is offline
Old 08-06-2013, 05:23 PM - Thread Starter
aarons915's Avatar
Quoted: 38 Post(s)
Liked: 33
I actually ended grabbing an emotiva UMC 1 processor that allows 2nd or 4th order slopes, I've been wanting to do separates for awhile anyway so was the perfect time. I don't have an amp yet so just using my Denon but the difference in a 2nd and 4th order high pass at 80hz is pretty dramatic. No more deep bass playing through my mains and it blends in much better with the sub.
Old 04-05-2014, 08:55 AM
djwest78's Avatar
i.e. How could you have a dynamic soundstage if 120hz and below is turned to mono. Listening to your speakers by themselves with a certain crossover but without the subs powered up can be quite revealing.
Sure, if you are are interested in finding out what your room sounds like with a multi channel system playing sounds above 120hz., then this experiment could be quite useful.
Considering of course that you will never use your system this way.
djwest78 is offline
Old 04-05-2014, 09:02 AM
djwest78's Avatar
Confused...are you saying that you feel you get more "oomph" from the 80hz crossover than you do from the 100hz crossover?
djwest78 is offline
Old 04-05-2014, 09:04 AM
djwest78's Avatar
AND room acoustics, AND personal preference.
djwest78 is offline
Old 04-05-2014, 10:11 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Originally Posted by CruelInventions View Post
My guess is that with the lower crossover, because you're starting to introduce fuller and lower bass with it, what is now being revealed is the insufficient quality of at least one and maybe all of the following;
1) your room and/or your seating position, the latter being if you listen mostly when seated in the same place (standing bass waves building up and creating uneven response in your existing seat, etc.).
2) lack of optimal center speaker and/or other speaker positioning contributing to the too bass-bloated sound.
3) lack of a sufficient enough quality EQ program in your receiver (Audyssey, MCACC, etc., depending upon receiver brand) to help tame and level out some of uneven in-room response.
4) Or, you haven't really used the EQ program in yours yet, as all too often, many users don't really take advantage of their receiver EQ software or give up on it too soon.
You can simply leave the crossover at 100hz and be continue to be happy. But if you have enough time and interest, you can begin the process of exploring how to improve your results with the lower crossover setting (by use of bass and other room treatments, using an EQ program, speaker and seating position adjustments, adding multiple subwoofers to even out the bass within the room {not to add more bass, just even it out}).
+1.
arnyk is offline
Old 04-05-2014, 04:41 PM - Thread Starter
aarons915's Avatar
Quoted: 38 Post(s)
Liked: 33
I did with the towers I had at the time, because they were pretty capable mains so instead of all the bass coming from the single sub there was a lot more bass coming from 2 more sources (The Fronts). My real issue that I later found out after getting a mic and messing with REW is I have a massive peak at 60Hz in my room so pretty much every tower sounded bloated and boomy in my room. I now have to cut the frequency for my sub and mains about 10 decibels at 60Hz to flatten it out and that makes an 80hz crossover sound fine. Moral of the story is before you change out speakers and/or subs to solve problems check your in room response first. I had no idea the room can make that much of a difference but it does.
