Any tips for discretely wiring around the house? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-08-2012, 02:29 PM - Thread Starter
Dillsnik's Avatar
I wanted to run a pair of speakers downstairs from where my amp is, without having wire everywhere in plain view.
This is a short term living situation though, so it may not be worth the extra time and effort to go through the walls etc.
But I wanted to see what others have done and get any advice to maybe be a bit more discrete.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Dillsnik is offline
post #2 of 12 Old 11-08-2012, 03:06 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Look at Wiremold products. They are available from HD and Lowe's. Keep in mind that removing them usually requires re-painting of the wall due to damage from glue.
ap1 is offline
post #3 of 12 Old 11-08-2012, 04:08 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
The damage is often actually reduced in terms of ease of repair by holding them in place with a few screws. The screws make a few small holes while the adhesive can tear off big strips of paint.
arnyk is offline
post #4 of 12 Old 11-08-2012, 07:31 PM - Thread Starter
Dillsnik's Avatar
Yes, not trying to make a big repair job after out if this if i can help it. Probably moving in 9 months
Dillsnik is offline
post #5 of 12 Old 11-09-2012, 11:21 AM
Wayne A. Pflughaupt's Avatar
Quoted: 118 Post(s)
Liked: 86
^^ +1
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #6 of 12 Old 11-10-2012, 09:13 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
First, you are confusing "discrete' and "discreet'...lol. "Discrete" means "individual and separate", while discreet is the word you want to use.
Wiremold makes a number of products that can be used to route wires discreetly; the devil is in the details.
commsysman is offline
post #7 of 12 Old 11-10-2012, 11:03 AM - Thread Starter
Dillsnik's Avatar
I appreciate the feedback, but I just looked at those and I don't know how much more attractive those tubes would look running along the wall. Plus it could become a cost for how many I might need
Dillsnik is offline
post #8 of 12 Old 11-10-2012, 05:39 PM
Quoted: 118 Post(s)
Liked: 86
Well, if you’re trying to avoid in-wall wiring, your options are pretty limited. Another one would be to take off the baseboards, run the wiring behind them, then re-attach the baseboards. But that’s usually a major hassle, as most houses these days have them calked to the sheetrock.
Wayne A. Pflughaupt
Equipment List
post #9 of 12 Old 11-10-2012, 05:43 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 741
An out of box option is to move the source of the sound and amplification to the other floor. A wireless media player for example can play content over your already existing WiFI network. These boxes can then be moved with you. A bonus is that you can listen to something other than what this node is playing.
amirm is offline
post #10 of 12 Old 11-11-2012, 07:03 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
The only thing that looks worse than wiremold is standard cable and wire just tacked in place.
arnyk is offline
post #11 of 12 Old 11-11-2012, 01:21 PM - Thread Starter
Dillsnik's Avatar
lol
Dillsnik is offline
post #12 of 12 Old 11-14-2012, 10:52 AM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 151
How about this? It says subwoofer, but it's a 2-channel device... no amp, but that's an easy fix these days.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-580
fbov is offline
