Dolby TrueHD vs. DTS-HD Master Audio - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #91 of 135 Old 01-22-2013, 07:58 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
Originally Posted by pokekevin View Post
I remember people discussing that issue with the 2L bd awhile back. PCM should work at 192khz (according to the folks who had an oppo) but when bit streaming I think it's the receiver/prepro thats down converting since it can't process the 192khz and all that audyssey blah blah and such.
Whew! After typing my post I started worrying that I had misunderstood something very basic, just because in general I take your posts as gospel re DD in particular.
JHAz is offline
post #92 of 135 Old 01-22-2013, 10:04 AM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
aww thanks! But you probably meant to quote Roger haha
pokekevin is offline
post #93 of 135 Old 01-22-2013, 05:29 PM
Kilian.ca's Avatar
Liked: 37
Originally Posted by Roger Dressler View Post
Originally Posted by Kilian.ca View Post
the 96 kHz part of the DTS bitstream?
Yes. DTS 192 kHz coding splits the spectrum at 48 kHz (96 kHz sampling) so that a decoder that is not 192 kHz capable has an easier time decoding the audio.
So in a dts-HD MA 192kHz 'stream' there is:
1. a dts core stream at 48kHz sample rate,
2. a lossless extension at 96kHz and
3. a second lossless extension at 192kHz (which with (1) and (2) makes up the whole lot, kind of 3-tier structure)?
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #94 of 135 Old 01-23-2013, 12:04 AM
Roger Dressler's Avatar
Quoted: 1872 Post(s)
Liked: 1004
I went back and reviewed the spec, and I must recant. It states that only one extension can be used at a time. Either 96 kHz or 192 kHz, but not both. My apologies, Kilian.
I'm afraid that leads to the conclusion that the Oppo is downsampling the audio. Frankly I cannot understand why -- all it has to do is send it to the HDMI, same as it does for 192 kHz PCM or TrueHD. confused.gif Could it be that in order to support the internal processing for the analog outputs (bass management, perhaps delays), those resources are encroached by the HD MA decoder?
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is online now
post #95 of 135 Old 01-23-2013, 01:37 AM
Kilian.ca's Avatar
Liked: 37
No need to apologise Roger and thanks for looking it up!
It's not confined to the Oppo. When I raised this before I was told by rdgrimes it was because Oppo uses the dts Essentials decoder. I don't know if it's the real reason or not.
I told Morten Lindberg at 2L about it and suggested using Dolby TrueHD instead and he said was he'd take it up with hardware manufacturers and that was about a year ago. At least I did try to push for Dolby for this cause as it obviously is the better choice.smile.gif
post #96 of 135 Old 01-23-2013, 12:24 PM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
Yep. "My aim ain't true"
JHAz is offline
post #97 of 135 Old 01-28-2013, 11:22 PM
Liked: 1004
Kilian,
I was able to learn something talking to a DTS insider. The spec I was referencing is rather old, and obsolete. It has been updated and published as an ETSI spec. The newer version indeed does allow for a dual band encode, so the 96 kHz result is indeed because the Oppo is discarding the extension band to 192 kHz sample rate, and nor due to downsampling. In the end, it's 6 of one, half-dozen of the other, but thought I should correct the record.
post #98 of 135 Old 01-30-2013, 01:52 AM
Kilian.ca's Avatar
Liked: 37
Thanks again Roger! If you do get another chance to probe, what's the reason for all players doing this?
post #99 of 135 Old 01-30-2013, 09:22 AM
Liked: 1004
It is up to the player maker, not DTS, and that probably means it is up to the chip maker. It reduces cost to reduce the processing load. In the early days when sample rates first exceeded 48 kHz, many AVRs and chips had to downsample to 48 Khz for all the post processing. That is actually still the case in some products.
Being that BD players are not primarily focused on audio processing, the DSPs are apparently less extravagant in that respect. And particularly since any enthusiast who is keen to get the 192 kHz experience can stream out the data, I suppose they figure it's not essential to make extra efforts for player decoding of 192 kHz for every codec. They of course ignore that niche of folks who prefer to use the analog outputs. I suppose if there were more than a handful of DTS titles at 192 kHz, a case could be made. But it's a pretty insignificant number.
post #100 of 135 Old 01-31-2013, 12:14 AM
Kilian.ca's Avatar
Liked: 37
I understand what you're saying. The implication is that there is more than one type of dts decoder or more than one implementation for dts-HD MA and the dts claim (on their website and in the whitepaper) about bit-for-bit identical to the master just isn't always true without qualification. They say dts-HD MA supports 5.1 192kHz but conveniently omit to tell you oh by the way not all our decoders can do that. It is this which I find a little misleading and annoying more than any real loss from downsampling.
The trouble with AVR decoding is, unlike player decoding there's no easy or sure way of knowing what happens to the sample rate internally whether other processing steps are applied or not, and if the DSP applies any digital band limiting filters to the output (some Onkyo/Integra models seem to do that).
I suspect the 2L titles were encoded before the dual band encoding update, therefore old and new players must be downsampling still.
The irony is that the PS3, a games console not focused on audio can fully decode dts-HD MA 192kHz from day one and the latest BD players, even 'audiophile', 'high-end' ones that focus on audio can't and surely processing power can't be a limitation any more with streaming, 3D, 4k etc.
post #101 of 135 Old 01-31-2013, 02:15 PM
Liked: 1004
Is all this concern over 2L and other niche content? Really the idea of 192 kHz is highly overrated for all the trouble it causes. Let alone the dearth of titles.
Even my lovely SSP-800 fully decodes DTS 192 kHz tracks then applies ASRC conversion to 96 kHz (same as Theta CBIII HD and others). This may sound like a sell out for 192 kHz, but it brings certain benefits in design, operation, and even sound quality (the DACs have better specs at 96 kHz than 192 kHz).
I'm not so sure. How can you tell?
Not exactly day one. The PS3 could not decode DTS-HD MA until 18 months after Blu-ray introduction. They had to completely rearrange the Cell chip resources.
post #102 of 135 Old 01-31-2013, 08:09 PM
Kilian.ca's Avatar
Liked: 37
No, again it's about the dts claim, a case of 'it doesn't do exactly what it says on the tin' (modified from a British expression).
Better address this to Morten L. and anyone making 192kHz audio. I'm only exposing the limitations, not the advocate. Don't shoot the messenger!smile.gif
Divertimento came out in 2008, the ETSI DTS spec update was in 8.2011 (the one before was in 2002). Just putting two and two together. I can't be certain without asking Morten L which encoder he used but it's not a pressing issue.
BTW the update allows DTS-HD to do 384kHz (requiring a 3rd extension) and no longer needs the core.tongue.gif
OK, day one from the day it could decode.
I've made my point and let people know dts-HD MA decoding isn't always bit-for-bit identical to the source. Time to draw a close.
post #103 of 135 Old 01-31-2013, 11:19 PM
Liked: 1004
Understood. BTW, the date the code is implemented is not necessarily related to the date the spec is published.
LoL, a sample rate war! The "coreless" option was there originally, but the Blu-ray folks did not want to use it, so that older DVD player chips could be pressed into service.
post #104 of 135 Old 05-27-2013, 03:55 PM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
For whatever reason I seem to end up enjoying DTS-MA more than Dolby HD mixes.
Basement: BenQ W1070 on 110" Elite Screen, Denon AVR-1913, JBL LC1 (C), JBL L880 (FL/FR), JBL 810 (BR/BL), Rhythmik LV12R Sub, PS3 and Roku 3
Living Room: Vizio M65-E0, Vizio SB3651-e6 Soundbar, PS4, Roku Premier+, and X Box One X coming soon
CheYC is offline
post #105 of 135 Old 05-27-2013, 04:10 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Yes, you are enjoying certain mixes more than others. No, that has nothing to do with the data compression codecs used to store those mixes on discs. TrueHD and dts-MA are really just types of zip files which are used to save space when storing large multichannel PCM soundtracks. The mixing is done long before a data compression codec like TrueHD is used to store the track on a Blu-ray disc. And there is nothing in the data compression process that changes the mix.
BIslander is offline
post #106 of 135 Old 04-22-2015, 06:04 AM
DRC72's Avatar
Quoted: 73 Post(s)
Liked: 30
I always thought both formats where equally good. The Matrix, and The Dark Knight are just a few that sound fantastic in Dolby True HD. Not sure why the studios are abandoning Dolby on the bluray format?
Sent from my AT&T iPhone 6 Plus using Tapatalk
DRC72 is offline
post #107 of 135 Old 04-22-2015, 09:10 AM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
My understanding back in the DVD days at least, was that different production houses would often handle the DD and DTS mixes. Thus you could get different quality from the DTS.
Was that and is that still true?
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #108 of 135 Old 04-22-2015, 11:33 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
Participant around here FilmMixer is an award winning, and more important (possibly to him) living-making fella in the movie mixing industry, and he has confirmed multiple times that he consulted with both Dolby and DTS. At least back when his former studio (Todd-AO, not exactly a newcomer, although they managed to kill themselves) was still active, AFAIK, they would output whatever sound system the producer/Disney/Columbia/Whoever wanted. The software to make the conversions is not so expensive, AIUI, or so complex, that you couldn't make multiple soundtracks, whether it was DD, DTS, Sony DTS (for theatrical release) or whatever. The decision would always be in the hands of the Disney/Columbia, etc. and was of no great import to the mixing house.
BUT in these days of remastering for home video release, it's certainly possible that individual remastering contractors prefer (read have licenses for) only one or the other of the available lossless schemata. Given that the lossless stuff is, ummmmm, lossless, it doesn't much matter which they use anyway. ONce decoded, they should be identical, unless something is broke. It's not even necessary, with BD storage capacity, to use DD or DTS for home release. Disney, in particular, released a number of films (some of the Primates of the Caribbean come to mind) in multichannel PCM. I suppose eventually that much data interferes with the ability to include a ton of added material, which I often find useless anyway (but sometimes it's fun) and everybody seems to be moving toward standardizing on Dolby or DTS (ok, mostly DTS) lossless as the way to handle soundtracks for the feature itself. Lossy DD or DTS is more likely for the extra features . . . .
JHAz is offline
post #109 of 135 Old 04-22-2015, 03:28 PM
DRC72's Avatar
Quoted: 73 Post(s)
Liked: 30
I think Dolby's response to their shrinking bluray market is Atmos. But I think Atmos is more of a niche right now,. Not sure how much it will take off on the home theater front. Not many people have rooms big enough to handle an Atmos setup. I know I definitely don't.
DRC72 is offline
post #110 of 135 Old 04-22-2015, 04:11 PM
sdurani's Avatar
Quoted: 5129 Post(s)
Liked: 3608
No, Atmos was in commercial theatres 3 years ago in response to movie mixers wanting to go beyond channel-based mixing. Like many cinema technologies, it was a matter of time before it came to consumers. I doubt Dolby is worried about the Blu-ray market, considering they dominate in broadcast, cable, satellite, streaming, commercial cinemas, etc.
Footprint is no larger than a typical 5.1 set-up (just add a pair of height speakers for Atmos).
Sanjay
sdurani is offline
post #111 of 135 Old 04-23-2015, 07:55 AM
DRC72's Avatar
Quoted: 73 Post(s)
Liked: 30
Originally Posted by sdurani View Post
No, Atmos was in commercial theatres 3 years ago in response to movie mixers wanting to go beyond channel-based mixing. Like many cinema technologies, it was a matter of time before it came to consumers. I doubt Dolby is worried about the Blu-ray market, considering they dominate in broadcast, cable, satellite, streaming, commercial cinemas, etc. Footprint is no larger than a typical 5.1 set-up (just add a pair of height speakers for Atmos).
Oh ok I see. But still kind of odd that Dolby True HD has lost ground in the bluray market. A lot of older movies that were encoded in True HD have now moved over to DTS HD. Wizard of Oz comes to mind.
DRC72 is offline
post #112 of 135 Old 04-23-2015, 09:03 AM
sdurani's Avatar
Liked: 3608
Not really that odd. Titles with Dolby soundtracks actually contained two tracks: TrueHD lossless audio and Dolby Digital for backwards compatibility. Because of that, it took twice as long to encode and quality-check (two separate tracks to check). By comparison, on DTS soundtracks the backwards compatible lossy DTS track was the core of the lossless DTS-HD MA track. That allowed them to be encoded and QC'd in a single pass (if the backwards compatible part didn't work, the entire soundtrack wouldn't play).
Since time = money, this gave DTS the advantage. Dolby couldn't be bothered to do anything about it at the time, which allowed DTS to dominate on BD (but only BD, as Dolby dominates on ALL other delivery media where they compete). Now it's a few years later and the new TrueHD encoders are smoking fast, eliminating the difference in speed between them and DTS-HD MA encoders. Hard to predict the future, but I wouldn't take DTS' dominance on Blu-ray to automatically infer that they'll similarly dominate moving forward to delivery media such as UDH BD, 4K streaming, broadcast (ATSC 3.0), etc.
Sanjay
sdurani is offline
post #113 of 135 Old 04-23-2015, 11:06 AM
DRC72's Avatar
Quoted: 73 Post(s)
Liked: 30
So DTS HD MA is more bandwidth efficient?
DRC72 is offline
post #114 of 135 Old 04-23-2015, 11:21 AM
sdurani's Avatar
Liked: 3608
You mean smaller data rate peaks? Not sure. If there is a difference, then it hasn't been significant enough to keep loud/busy soundtracks from being delivered using TrueHD.
Sanjay
sdurani is offline
post #115 of 135 Old 04-23-2015, 11:34 AM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
That's interesting...another example of balancing production expediency / cost with end product quality.
Eyleron is offline
post #116 of 135 Old 04-23-2015, 11:38 AM
DRC72's Avatar
Quoted: 73 Post(s)
Liked: 30
Well as far as the lossy/lossless encoding goes? You were saying that Dolby Digital and True HD require separate encodings on a BD? Where as DTS has both the lossy/lossless encodes bound together? Thus saving space on a BD? Hope I am explaining this right?
DRC72 is offline
post #117 of 135 Old 04-23-2015, 11:49 AM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
^ regardless of bandwidth efficiency, the point of "how do producers feel working with which codec", it wasn't an issue of the end result bandwidth efficiency but rather the efficiency of doing the work, of encoding the soundtrack and checking it and doing it again if need be.
Eyleron is offline
post #118 of 135 Old 04-23-2015, 11:51 AM
sdurani's Avatar
Liked: 3608
Well as far as the lossy/lossless encoding goes? You were saying that Dolby Digital and True HD require separate encodings on a BD?Where as DTS has both the lossy/lossless encodes bound together? Thus saving space on a BD? Hope I am explaining this right?
Storage space is different from transmission bandwidth. Storage space is not a problem for audio on Blu-ray like it was for DVD. However, when transmitting the audio signal through the HDMI pipeline, you don't want the audio data rate to get so high (even momentarily) that it cuts into the video data rate and reduces picture quality. I'm guessing neither codec does that, since there appears to be room in the pipeline for even higher audio data rates (required for immersive audio formats like Atmos and DTS:X).
Sanjay
sdurani is offline
post #119 of 135 Old 04-23-2015, 01:10 PM
DRC72's Avatar
Quoted: 73 Post(s)
Liked: 30
I conducted an experiment just for my own personal interest. I have the first Transformers movie which has a Dolby True HD track, and Transformers revenge of the fallen which has a DTS HD Master audio track. Now I know they're both different movies, but damn the DTS HD Master audio track was so much more powerful on the second Transformers movie. The Dolby True HD track on the first movie had some juice, but nowhere near the power that the DTS HD track had. I'm not saying DTS HD is better, this is just my personal observation of these two movies.
DRC72 is offline
post #120 of 135 Old 04-23-2015, 02:56 PM
sdurani's Avatar
Liked: 3608
I had the opposite result. I compared the TrueHD track on Star Trek Into Darkness to the DTS-HD MA track on Stargate. Now, I know they're different movies, but the TrueHD track smoked the DTS Master Audio track. Not saying TrueHD is better, just reporting my findings.
Sanjay
sdurani is offline
