Dolby TrueHD vs. DTS-HD Master Audio - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #121 of 135 Old 04-23-2015, 03:19 PM
DRC72's Avatar
Quoted: 72 Post(s)
Liked: 30
Originally Posted by sdurani View Post
I had the opposite result. I compared the TrueHD track on Star Trek Into Darkness to the DTS-HD MA track on Stargate. Now, I know they're different movies, but the TrueHD track smoked the DTS Master Audio track. Not saying TrueHD is better, just reporting my findings.
The Dark Knight and The Matrix are awesome in True HD, although I would be curious to see what those movies would sound like if they where mixed with DTS HD MA.
Sent from my AT&T iPhone 6 Plus using Tapatalk
DRC72 is offline
post #122 of 135 Old 04-23-2015, 03:22 PM
sdurani's Avatar
Quoted: 5072 Post(s)
Liked: 3546
If that were to happen, I think the DTS-HD MA track would be more identical to the original than the TrueHD track.
Sanjay
sdurani is offline
post #123 of 135 Old 04-23-2015, 03:24 PM
DRC72's Avatar
Quoted: 72 Post(s)
Liked: 30
Curious as to why you think that? Although I wouldn't doubt it.
DRC72 is offline
post #124 of 135 Old 04-26-2015, 07:28 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
dts and dolby are different data compression codecs, not different methods of mixing soundtracks. A movie is mixed, creating a multichannel PCM soundtrack. Sometime later, that PCM track is put in a disc, almost always using data compression to save space. With lossless codecs such as TrueHD and dts-MA, the PCM coming out of the decoder is identical to the PCM that was fed into the encoder. In other words, if you start with the same soundtrack, it makes no difference which lossless codec is used.
btw, I think Sanjay is fooling with you a bit. Comparing two different movies says nothing about the lossless codecs involved. And, by definition, with the same input, the outputs of two lossless codecs must be the same. One cannot be "more identical" than the other.
krabapple, holt7153 and ChromeJob like this.
BIslander is offline
post #125 of 135 Old 04-27-2015, 03:35 AM
DRC72's Avatar
Quoted: 72 Post(s)
Liked: 30
So all soundtracks start out as PCM, and then are encoded in either Dolby T HD or DTS HD MA on the disc? Then the receiver re-encodes it back to PCM for output?
DRC72 is offline
post #126 of 135 Old 04-28-2015, 03:09 AM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
I don't know for sure, but I suspect not "encode to PCM", but rather decode the compression scheme (DD*/DTS*), and with the resultant data streams in memory, apply processing prior to output to amps.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #127 of 135 Old 04-28-2015, 11:30 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 274
no mixing or sound manipulation software can work directly on data compressed signals like DD or DTS, so in a recording situation, mostly you see folks using PCM, unless they're into the analog thing. The Sony one-bit system also is around, but there is AFAIK limited software to add EQ, reverb, etc etc etc and it's use is somewhat limited to audiophile "no enhancements" type recordings. I could be wrong abot that, though.
But, yeah, movies and music mostly are recorded mixed mastered and generally fooled with in PCM. If I wanted to add compression or reverb to DD or DTS sound file, I'd have to decode it to PCM so my software could understand it. Or I'd have to decode it to PCM so my DA converters could turn it into analog that I could feed into my (not in the sense that I'll ever own any of these devices) mulitkilobuck 60s and 70s outboard analog boxes, then that revised signal would come back to the AD converter to be turned into PCM, which could then be turned into DD or DTS if I so chose.
JHAz is offline
post #128 of 135 Old 04-28-2015, 10:39 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
It's pretty much a zipping and unzipping process. The PCM goes into the encoder where it gets zipped up to save space. The decoder does the unzip, turning it back into PCM.
With lossless codecs, the PCM coming out of the decoder is identical to the PCM fed into the encoder. With lossy codecs, like DD and DTS, some of the data removed in the encoding process is not restored by the decoder.
Why do they do this? In the early days, a PCM soundtrack was much too large to fit on a film strip or in the audio area of a DVD. Dolby and DTS developed lossy codecs to squeeze multichannel tracks onto the available media. Blu-rays have a lot more space and can hold a 7.1 PCM soundtrack. But, the studios would rather use the space for other purposes. Lossless codecs do less compression than their older lossy cousins, allowing studios to provide soundtracks matching the original PCM while still saving space for extras.
Eyleron likes this.
post #129 of 135 Old 05-03-2015, 08:25 PM
Worf's Avatar
Quoted: 561 Post(s)
Liked: 299
Early Blu-rays used LPCM as their soundtracks as the mastering tools were very immature (and that's also why they used MPEG-2). Early Blu-rays were also single layer, which meant there was a severe space crunch - it was hard to put a 1080p movie and a 7.1 soundtrack without compromising the video to fit it all, which was why early Blu-Ray didn't go so well compared to alternatives. It's why a lot of early Blu-rays got reissued years later.
These days it doesn't matter as the tools are mature. You cannot compare two different movies as their mastering makes a whole pile of difference and it in no way reflects which method is better.
Worf is offline
post #130 of 135 Old 05-05-2015, 04:36 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
I think this is a fairly meaningless issue. Any differences in sound could be ascribed just as accurately to differences in the masters than any audible differences in the codecs. I would view it as very very unimportant.
FMW is offline
post #131 of 135 Old 05-06-2015, 06:14 PM
DRC72's Avatar
Quoted: 72 Post(s)
Liked: 30
Either that or get a movie that is mastered with both HD codecs. Top Gun has both codecs on it's BD.
DRC72 is offline
post #132 of 135 Old 05-06-2015, 07:59 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
If memory serves, the different Top Gun encodes come from different masters. So, it's not a meaningful comparison.
post #133 of 135 Old 05-06-2015, 08:49 PM
Worf's Avatar
Quoted: 561 Post(s)
Liked: 299
Would make sense. Both are lossless codecs - they really should come out the same either way otherwise there's a problem with your system somewhere. The only reason a disc would be mastered with both is if they just copied the mastered audio track across to save encoding time.
This is really like arguing over whether FLAC sounds better than ALAC or PCM WAV.
Worf is offline
post #134 of 135 Old 05-07-2015, 04:10 AM
DRC72's Avatar
Quoted: 72 Post(s)
Liked: 30
Yeah the DTS track is 6.1 compared to the 5.1 Dolby track.
DRC72 is offline
post #135 of 135 Old 04-09-2017, 12:15 PM
Liked: 0
mine won't even go that low. The lowest my receiver will go is -15db.
Rollerskater is offline
