Is Audiquest still the best? - AVS Forum | Home Theater Discussions And Reviews
Old 11-11-2012, 10:29 AM - Thread Starter
tedcousens's Avatar
Quoted: 28 Post(s)
I am picking up a new Marantz av7701 to replace my 14 year old av550. I have always outputted the audio via good audioquest cables but they are very old, almost 20 years. I have two questions:
1. I am outputting to warm Mosfet amps (Adcom): can anyone recommend a good RCAcable to use and do the old cables need to be replaced?
2. Although I will not be using them, of what benefit are the XLR outputs - is the sound that much better?
I've seen things you people wouldn't believe...
Roi Batty
tedcousens is offline
Old 11-11-2012, 10:47 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I won't hold that against you!
I'm wondering which Adcom amps have MOSFET outputs, because I have the service manuals (schematic, parts list) for several of them and the outputs are Bipolar.
I've also done level-matched, time-synched, bias-controlled listening tests of them and also done bench tests. Long story short they are electrically flat, have low source impedances, and are sonically transparent, that is uncolored, neither warm nor cold.
Power amps as a rule don't have XLR outputs. They may have XLR inputs.
arnyk is offline
Old 11-11-2012, 10:58 AM - Thread Starter
tedcousens's Avatar
Quoted: 28 Post(s)
HI Arnie,
Thanks for responding. Yes, it's been so long that I have forgotten how to speak audio. biggrin.gif Perhaps the Adcom amps are not mosfet, I am not really sure- I do know that they are considered AB: class A for 10 watts then B upon draw.
Of course the prepro has the output and the amps perhaps have the input. My question is: does utilization of xlr even on one end only, improve the quality of sound? If not, and I continue to use the rca outputs on the prepro, would I benefit by replacing the old audioquest cables I have or just keep the ones I have which are at least 15 years old. Thanks again. T
Roi Batty
Old 11-11-2012, 11:02 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Generally no, unless there's a clear problem with the alternative.
No.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Old 11-11-2012, 12:17 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
HI Arnie,
Since there is then nothing to connect the terminal that would make the balanced output special to, it can't make a difference.
Cables rarely wear out in home applications because they are rarely messed with. I would sincerely hope that expensive cables would at least be technically competent enough to last as well as good commodity cables.
You have a big advantage on me - you can see and touch the cables. Are there crackling noises if you flex them while your audio system is turned on? Is there evidence of bad corrosion on the connectors? If the insulation on the cables stiffening or cracking?
If the Audioquest cables are at least as well made as a good commodity cable, then there would be no reason to replace it.
People tell me that cables made by Blue Jeans Cables are very well made and should last for life - if you have doubts about the AQ cables you might want to try them.
arnyk is offline
Old 11-11-2012, 12:35 PM - Thread Starter
tedcousens's Avatar
Quoted: 28 Post(s)
The AQ cables seem to be intact. The body of the cable is a little greasy but the connectors are fine. I will not worry about it for now.thanks again.
Roi Batty
Old 11-11-2012, 05:38 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
I have several sets of AQ interconnects, and they're worth every penny I paid for them.
(I got them for free.)
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
Old 11-11-2012, 06:02 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 251
CharlesJ is online now
