Q? Subwoofer – On- or – OFF while calibrating a 5.1 MCA setup. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-13-2012, 10:09 AM - Thread Starter
DAB
DAB's Avatar
Quoted: 27 Post(s)
Q? Regarding Subwoofer – On- or – OFF while calibrating a 5.1 MCA setup.
I recalibrated my 5.1 MCA system {HDMI>Video}.  So after two different
sets of dB numbers I had to rethink.  I thought should you calibrate your system with Sub >Off in the DVD player and physically>Off on the Sub. Just so no cross over from the test disc and just better accuracy in getting the Sub dialed in. Calibrate the Sub. separately
Trail #1:  I calibrate the 5. speakers  with the Sub >Off and got one set of dB for each speaker
 Trial #2 Calibrated the 5.1 system with Sub>On and got a different set of dB. – Usually lower dB for each speaker.
Or because, I set the Sub to>Off ,  the Calibration disc redirected some bass/LFE to the other speaker channels. Thinking there was not going to be a Sub channel in this setup/calibration so it just redirected the Sub’s dBs to the other channels. FL/FR-C.
  • Using an Oppo 95- speaker trims in the player. Denon 3803- master volume                                             -13dB. Extended –In channels at _0_  . RS-SPL mounted on a tripod.
  • AIX calibration disc. 5.1 LPCM
DAB
DAB is offline
post #2 of 3 Old 11-13-2012, 12:39 PM
DonH50's Avatar
Quoted: 1835 Post(s)
Liked: 1365
You normally want the effect of the subs and mains together, plus the cal progam typically "pings" each speaker seperately. Both argue for leaving the sub on when you do the cal so it is calibrated as a system.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 3 Old 11-13-2012, 01:23 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
DAB
How do you listen to this system? Sub on, or sub off?
You should calibrate the system that you actually listen to, no? ;-)
arnyk is offline
