Speaker placement - Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-27-2012, 10:33 AM - Thread Starter
VancouverMike's Avatar
We're renovating our basement and so I have the opportunity to hide wires and such. But the thing is the room is an odd shape, and the TV sits in a corner. I had 5.1 set up before but the speakers are all different distances from the couch, and different heights! I use a receiver to power and tune the speakers but it's never been great.
The room image is below. You'll see the TV in the bottom left corner (51" though I'll upgrade soon).
1. Any suggestions on speaker placement?
2. Is a sound bar or surround bar the way to go here?
Thanks in advance!
VancouverMike is offline
post #2 of 4 Old 11-28-2012, 04:41 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
In this situation, using a sound bar for the LCRs might be the way to go. So then you still have the surrounds.
Putting the RS @ the edge of the stairwell, and the LS @ the opposite wall (lower right corner of drawing).
Then reposition the sofa so the center of the seat is equal distance to both.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 4 Old 11-28-2012, 08:45 AM
drunkpenguin's Avatar
Quoted: 1092 Post(s)
Liked: 1040
What about moving the tv to the right wall? Theres a bit of a rectangle formed on the bottom half of the room where you could place speakers more theater-like.
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is offline
post #4 of 4 Old 11-29-2012, 12:24 AM - Thread Starter
We've considered moving the TV to the right side of the room. But thats a fireplace on the left side and it seemed weird to have the fireplace on one end and the TV on the other. I'm considering a new TV and mounting it above that fireplace thus giving me a more rectangular layout.
Are sound bars worth it?
