dvd settings for audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-30-2012, 10:46 AM - Thread Starter
web25's Avatar
i have a standard dvd player but i need help with a few setttings.
digital output - pcm or bitstream
dynamic range - on or off
pcm downsampling - on or off
would you guys mind telling me what these 3 settings mean and how i should have them set up using a 5.1 surround receiver and while just hooked to a tv?
thanks for any input.
web25 is offline
post #2 of 7 Old 11-30-2012, 11:46 AM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1770
My answers below assume you really have a DVD player and not a Blu-ray player. Blu-rays have more complicated answers.
receiver: Bitstream. TV: bitstream if your TV can decode DTS. Most can. Bitstream passes through the multichannel audio exactly as it is coming from the disc. The player needs to convert the audio to PCM if the audio playback device can't decode the audio coming from the disc. (Many TVs can't decode DTS.)
This needs to be on only if you want to watch something which could have loud explosions late at night and not disturb other people. It limits the maximum volume. Usually, this feature is included in the TV or receiver, though, which can do a better job.
Receiver: probably off. TV: probably on.
It downconverts high resolution 96KHz or 192KHz sampling to the standard 48 (or 44.1) KHz. Some audio output devices can't handle the higher bitrates, but very few DVDs have high bitrate audio, anyhow.
I hope this helps a little.
Selden
Selden Ball is offline
post #3 of 7 Old 11-30-2012, 11:54 AM - Thread Starter
web25's Avatar
yes, thanks
web25 is offline
post #4 of 7 Old 12-01-2012, 03:25 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Very few TVs can decode DTS. If connected to a receiver, use bitstream. Otherwise, use PCM.
If you are using HDMI to connect a player to a TV, those settings don't matter because the handshake between the player and the set will negotiate the correct settings. If the TV cannot handle DTS, for example, the HDMI handshake will override the bitstream setting so that the player does the decoding and sends a properly downmixed stereo PCM signal.
Also, dynamic range and PCM down sampling only come into play when the output is PCM. If you are set to bitstream, those adjustments would have to be handled by a receiver doing the decoding.
BIslander is offline
post #5 of 7 Old 12-01-2012, 03:34 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
If you are using HDMI to connect a player to a TV, the bitstream and downsampling settings don't matter because the handshake between the player and the set will negotiate the correct settings. If the TV cannot handle DTS, for example, the HDMI handshake will override the bitstream setting so that the player does the decoding and sends a properly downmixed stereo PCM signal.
Also, dynamic range and PCM downsampling only come into play when the output is PCM. If you are set to bitstream, those adjustments would have to be handled by a receiver doing the decoding.
post #6 of 7 Old 12-01-2012, 11:31 AM - Thread Starter
web25's Avatar
should i use bitstream or pcm if the dvd player is connected to the tv using component cables?
right now i notice a sound difference while watching tv compared to watching a dvd. the dvd sound seems a lot lower for some reason.
thanks.
web25 is offline
post #7 of 7 Old 12-01-2012, 12:05 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Component cables are for video. Presumably, you are using stereo analog cables for audio. With analog stereo, the digital setting has no effect. The player will decode the track, downmix it to stereo, and convert it to analog.
