What is your preferred option for converting 5.1 to 7.1 with Surround Back? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-04-2012, 02:28 PM - Thread Starter
TazExprez's Avatar
I recently bought an Onkyo TX-NR818 and wonder what the preferred option for converting 5.1 to 7.1 with Surround Back is. My receiver does Dolby Pro Logic IIx, DTS Neo:X, THX Select2 Cinema, and THX Surround EX for accomplishing this. It may have other modes that I have not found. My receiver also does Audyssey DSX, but I think that only adds Front Wide and Front Height speakers, and not Surround Back speakers.
Btw, I would like the settings for watching movies.
Thanks a lot for any help.
HD-A1 + XBOX Add-On + PS3 = Format Neutral
TazExprez is offline
post #2 of 8 Old 12-04-2012, 04:06 PM
sdurani's Avatar
Quoted: 5151 Post(s)
Liked: 3628
Those two THX modes extract a mono surround-back channel from the surround channels, sending the same content to both rear speakers. By comparison, PLIIx and Neo:X extract stereo surround-back channels, so the rear speakers contain independent info rather than being run in dual-mono.
With that in mind, my preferred option is for PLIIx and Neo:X instead of the THX modes. Of the two preferred options, I don't find much difference when using them to scale 5.1 channels to 7.1 speakers. I would lean towards PLIIx because the stereo separation in the rear speakers is a little more distinct.
Sanjay
sdurani is online now
post #3 of 8 Old 12-04-2012, 05:19 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 40
I use PLIIX for the reasons stated above.
Secret Squirrel is offline
post #4 of 8 Old 12-05-2012, 11:02 AM - Thread Starter
TazExprez's Avatar
Will PLIIx or Neo:X degrade lossless TrueHD, DTS HD MA, or PCM tracks, or will they simply steer the lossless audio to the Surround Back speakers?
post #5 of 8 Old 12-05-2012, 12:04 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 791
I've set PL Iix 2 years ago and it truly enhances the 5.1 into 7.1 quite well.
Sent from my 32GB iPhone4 using Tapatalk
mtbdudex is offline
post #6 of 8 Old 12-05-2012, 06:05 PM
Peter M's Avatar
Quoted: 184 Post(s)
Liked: 215
Another vote for PLIIx.
Cheers,
Peter M is offline
post #7 of 8 Old 12-16-2012, 11:56 AM
boardinguy100's Avatar
Quoted: 13 Post(s)
Hi, I have the same AVR running 9.2 with rears and heights and I finally settled on NEO X:)
boardinguy100 is offline
post #8 of 8 Old 12-16-2012, 12:48 PM
sdurani's Avatar
Liked: 3628
The latter. Lossless audio doesn't stop being lossless when you apply bass management, time alignment, surround processing, room correction, etc.
Sanjay
