Setting up new 5.1 speakers with 14 AWG speaker wire and noticed the instructions for the speakers says to use 16-20 gauge wire. Will it hurt anything to use the 14? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-05-2012, 05:18 PM - Thread Starter
RhaegarsBlade's Avatar
The speakers are Klipsch HD Theater 1000 5.1 and they are being connected to a Denon AVR-1613 receiver if that matters. Thanks in advance!
RhaegarsBlade is offline
post #2 of 5 Old 12-05-2012, 06:06 PM
commsysman's Avatar
Quoted: 977 Post(s)
Liked: 526
Your intro above there got cut off.
14 gauge wire is the right thing to use.
Is there some other question?
RhaegarsBlade likes this.
commsysman is offline
post #3 of 5 Old 12-05-2012, 06:18 PM - Thread Starter
Oops. The issue is that the instructions that came with the speakers say to use 16-20 gauge wire. I have 14. Is it a problem to use the 14 when it says to use 16-20? From I've been able to gather it shouldn't really matter and should improve quality if anything. Can you confirm? Thanks.
post #4 of 5 Old 12-05-2012, 06:55 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Only if the terminals won't accommodate 14. If it fits in the holes, you're good.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #5 of 5 Old 12-05-2012, 07:13 PM - Thread Starter
Thank you!
