Multiple speakers going into one spring clip terminal pair - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-05-2012, 05:29 PM - Thread Starter
jimcame's Avatar
I want to feed 2 pairs of speakers from the output of an Audio receiver. the output is a pair of spring clip terminals. I would like to put a single pair of wires into the receiver and then have some kind of a splitter where the two wires from the receiver are the input and the four wires to the speakers are the output. I wouldnt have to bend over to access the back of the receiver. It would make life easier.
Problem is that I have not found any accessory like that on Google.. Surely someone else has faced this issue before and stores sell this..
Jim
jimcame is offline
post #2 of 4 Old 12-05-2012, 06:56 PM
javi404's Avatar
if i understand this correctly, you want to hook up 2 speakers to the left terminal and 2 speakers to the right?
javi404 is offline
post #3 of 4 Old 12-05-2012, 07:42 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Jim
Wirenuts?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 4 Old 12-06-2012, 05:44 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
Twist the amp ends of each cable pair together.
Be aware that 2 eight ohm speakers wired this way (in parallel) will present a 4 ohm load, which is lower than many receivers are specified to handle and could lead the receiver to overheat and/or the receiver going into protect mode if driven hard. FWIW, two 4 ohm speakers, or one 8 and one 4, present an even more difficult load to the receiver.
JHAz is offline
