Inexpensive tripod for Audyssey microphone setup? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By lovinthehd
  • 1 Post By bsoko2
  • 1 Post By arnyk
  • 2 Post By mogorf
  • 1 Post By kbarnes701
  • 1 Post By bsoko2
  • 1 Post By arnyk
post #1 of 13 Old 12-05-2012, 11:08 PM - Thread Starter
Tom4221's Avatar
Hi all,
I'm looking for an inexpensive tripod to lend a hand with my microphone placement for Audyssey MultEQ setup, and I was wondering if someone could link me one that did the job for them. There seems to be a ton of options out there! Thanks in advance.
Tom4221 is offline
post #2 of 13 Old 12-05-2012, 11:13 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
bsoko2 is offline
post #3 of 13 Old 12-06-2012, 12:17 AM - Thread Starter
Tom4221's Avatar
Thanks for the reply. Was there a particular model there that worked well for you, bsoko?
Tom4221 is offline
post #4 of 13 Old 12-06-2012, 12:30 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Something like this http://www.sears.com/shc/s/p_10153_12605_SP101A10877S4566499801P?sid=IDx20110310x00001i&srccode=cii_184425893&cpncode=32-201833780-2 but may limit positioning. Parts Express has some relatively inexpensive boom mic stands that give you more options but might be more than you want....http://www.parts-express.com/pe/showdetl.cfm?partnumber=233-020 or http://www.parts-express.com/pe/showdetl.cfm?partnumber=233-006
Tom4221 likes this.
lovinthehd is offline
post #5 of 13 Old 12-06-2012, 12:59 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
http://www.parts-express.com/pe/showdetl.cfm?partnumber=242-743 & http://www.parts-express.com/pe/showdetl.cfm?partnumber=242-025
Tom4221 likes this.
bsoko2 is offline
post #6 of 13 Old 12-06-2012, 05:43 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Hi all,
Audyssey Multieq microphones are usually not made to fit a regular microphone stand. They look like they were made to sit on a table or a chair.
The counterpoint is that the common "boom stand" is a very good tool for positioning microphones and are available for low prices given what they are.
http://www.guitarcenter.com/Musician-s-Gear-Tripod-Mic-Stand-with-Fixed-Boom-107218844-i1326041.gc
But that doesn't help you attach a mic that looks like this:
Perhaps a little gizmo like this will help:
http://www.guitarcenter.com/ProLine-Universal-Microphone-Clip-103302048-i1168308.gc
Tom4221 likes this.
arnyk is offline
post #7 of 13 Old 12-06-2012, 06:47 AM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
The Audyssey mic at the bottom (not seen on the above pic) has the same size thread as a camera, so it easily fits on a camera tripod. To use it with a mic stand you need an adaptor.
gh32 and Tom4221 like this.
mogorf is online now
post #8 of 13 Old 12-06-2012, 08:59 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5069
Hi all,
In this answer in the Audyssey FAQ are links to exactly what you need to ensure a good result, along with useful tips on how best to use them:
d)1.   Do I really need to put the Audyssey mic on a tripod or stand?
Tom4221 likes this.
kbarnes701 is offline
post #9 of 13 Old 12-06-2012, 09:37 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
When I had my Audyssey mic, I screwed in a long bolt to the bottom of the mic then mounted it to the clip for holding. Take the mic and go to Lowes or home Depot for a 3" bolt. The mic clip will hold it in position.
Tom4221 likes this.
bsoko2 is offline
post #10 of 13 Old 12-06-2012, 09:41 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I forgot about those - very cool.
Tripods for video cameras can work, and are probably the cheapest and most available things around.
Tom4221 likes this.
arnyk is offline
post #11 of 13 Old 12-06-2012, 10:18 PM - Thread Starter
Tom4221's Avatar
Thanks for the replies, everyone. Great information.
Tom4221 is offline
post #12 of 13 Old 12-11-2012, 10:58 AM
MuaySteve's Avatar
Quoted: 24 Post(s)
Liked: 31
If you are in a bind and want really cheap, a lot of lamps have a screw on top for the lamp shade and your mic will screw right on to it. Works pretty good...
MuaySteve is offline
post #13 of 13 Old 12-11-2012, 01:17 PM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2984
+1
I use my camera tripod. It was $20 model. Works fine.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
