Different brand for Wides/Heights - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-06-2012, 07:16 PM - Thread Starter
shaneb0422's Avatar
I have a Onkyo 709 and 7.1 Atlantic Tech 2400 -
I am thinking about picking up another set of the LR's to run as front wide/front high so I can switch between those and the rears just to see what I like.
I already have an extra Center Channel that is exactly same as system - are the height channels in plz and dsx truly stereo, or could I run a height center.
Or I could put the center in the rear (THX-ish style) and put the LR's in the height or wide to see what it's like.
Which would you do out of these...
Center height - LR rear - uses speakers i already have
Center rear - LR height/wide - uses speakers i already have
LR Height/Wide - LR Center - requires spending $$ on another set
Any real downside to mono rear instead of "stereo" - they are currently positioned like 3.5 ft apart - closer to THX setup rather than Dolby.
Thanks again!
shaneb0422 is offline
post #2 of 3 Old 12-07-2012, 03:16 PM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
Early surround systems used mono surround channels, and even if you have two rear speakers, they're using similar signals. A single rear speaker should suffice if you decide to add front-wide or front-high speakers. In fact, looking at the AT2400 set, the CC appears unique making this a great match.
I run front-wides, and the speakers better be comparable to your L/Rs as I don't hear much difference in output level - they're program level, not ambiance level. Don't skimp on these. Can't say about heights...
HAve fun,
Frank
fbov is offline
post #3 of 3 Old 12-08-2012, 12:31 PM - Thread Starter
shaneb0422's Avatar
What do you mean by the CC being unique?
It would be exact match to my front CC.
I figured slightly as much about the rear channels being somewhat mono (i.e. 6.1 style).
Especially considering the fact that they are positioned so close together, and discerning the LR from behind that close together seems unlikely.
The speakers I have on the rear now that would move to front wide are the same exact speakers 2400LR - so they will fit. Interesting they get so much program - I am intrigued.
Right now I am looking at getting a couple older model year AT's on craigslist - this may free up some speakers depending on how they perform compared to what I have.
Do the Front Wide go at same same physical height as LRs? Or up higher?
EDIT_after some reading - it looks like I don't have room to do wides. Here is a pic -
I could do heights though.
