Speaker Settings: DefTech 8060ST - AVS Forum | Home Theater Discussions And Reviews
post #1 of 59 Old 12-07-2012, 10:54 AM - Thread Starter
Popo9's Avatar
Hi Everyone,
I am trying to figure out what settings allow for LFE/small speaker's low frequency channels to be sent to my front towers. The receiver I am using is Denon 1713, my center/surrounds are set to small, and I do not have a separate subwoofer.
(1) Does setting the towers to LARGE send LFE channel to the towers?
(2) Does setting the towers to LARGE send the low frequency of my center/surrounds to the towers?
(3) Does LFE+Main setting on my receiver send the LFE/small speaker's low frequency to all speakers set to LARGE?
(4) I know if I connect the subwoofer out line to the towers using a Y-splitter, this will send the LFE/small speaker's low frequency to the towers (with the receiver's subwoofer mode at LFE), but is there any downside to this?
I guess what I am trying to get at is, what is the best setting/wire connection that will play all 5.1 channels of sound in a movie?
Sorry in advance if I am missing some very basic concepts.
Thanks for the help!
Popo9 is offline
post #2 of 59 Old 12-08-2012, 11:13 AM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
Originally Posted by Popo9 View Post
Hi Everyone,
Nice speakers. I have been using the older Def-Tech 2002TL's. The 2002TL's have several hook up methods. After trying all, I ended up with the most simple hook up configuration...just the speaker wire connection, mostly because if there is a sonic difference, I can't hear it, and hooking up this way uses the least amount of wires, which are difficult to hide.
You have two options with your 8060's:
1. LFE "out" of your receiver/processor to a "Y" connector, to "in" LFE on the rear of both of the 8060's.
You also need to run the regular speaker wire connection.
On the receiver/processor set the menu for the two front speakers to "Large" and Sub-woofer to "Yes".
2. Regular speaker wire hook up using no LFE cables.On the receiver/processor set the two front speakers to "Large" and sub-woofer to "No".
The rest of the speakers...I would set to small, redirecting the ultra low bass to the sub-woofers. FWIW, the "woofers" in the 8060"s are not true sub-woofers.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #3 of 59 Old 12-11-2012, 07:16 AM - Thread Starter
Popo9's Avatar
Thanks Espo. I interpret your option (2) as meaning that all low frequencies of small speakers/LFE channel will be directed to the front large speakers via the speaker cables. If that's not right, please let me know.
Popo9 is offline
post #4 of 59 Old 12-11-2012, 07:49 AM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
Yes but you tell the receiver what crossover number to use. Set to 80HZ, all bass below 80 is redirected to the subs.
Espo77 is offline
post #5 of 59 Old 01-29-2013, 06:31 PM
dapala's Avatar
This is the only time I've seen this written. Please explain. Definitive Technology seems to insist that the woofer configuration in these speakers are powered subwoofers, stating basically that they are built in SuperCubes.
dapala is offline
post #6 of 59 Old 01-29-2013, 08:39 PM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
I didn't see any indication that the 8060 has a built in Super-cube. The higher dollar Super-cubes do have control settings similar to other "true sub woofer's"...volume, high pass filter adjustment, low pass filter adjustment, phase setting, high pass delay, room compensation, sub woofer tune, parametric equalizer. The 8060 has only a volume knob doesn't it. It is, what it is...
Espo77 is offline
post #7 of 59 Old 01-30-2013, 06:58 PM
dapala's Avatar
It's not a SuperCube per se, I know that. Defenitive Technology's words are that the subwoofers in the 8060's have SuperCube technology. Their words.
I'm not arguing that these speakers have built in SuperCube subs. I was asking why you referred to the 8060's not having "true subwoofers". In your statement, that is the only time I can find that someone referred to the 8060's as not having "ture subwoofers".
I want to know what you know, because I have a pair of 8060's on backorder and can still change my mind on the purchase. I cannot afford a sub with this purchase. I'm unbiased and want to make the best purchase decision.
dapala is offline
post #8 of 59 Old 01-30-2013, 09:11 PM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
...and I am not cutting down the quality of the speaker, I own a complete Def-Tech speaker package...(Two 2002TL towers with built in powered woofers, CLR 2500 center also with a powered woofer, and two BPX's for surrounds). I am also using a Velodine powered sub-woofer, and I have the tower's set to "small" redirecting bass to the Velodine at 80HZ.
I used the term "true Sub-woofer" referring to all of the adjustments on board of that type of sub-woofer. The 8060's only have a gain/volume control for settings, don't they? I don't know what you had prior to purchasing the Def-Tech, but my guess is that your new speakers will be very impressive. I've certainly enjoyed mine.
Espo77 is offline
post #9 of 59 Old 01-31-2013, 08:34 AM - Thread Starter
Popo9's Avatar
I found the bass from the 8060's insufficient and added a PSA XS15 to the system. The addition of a separate subwoofer made a big difference.
Popo9 is offline
post #10 of 59 Old 01-31-2013, 09:36 AM
Wayne Highwood's Avatar
Liked: 43
The amps and driver/pr surface area is about the same. Because they are within the towers, phase/crossover are pre-set for seamless integration, with only gain controls available to the user.
DT has a history of rather wild exaggerations as to their speakers bass extension, but unless you're directly comparing to something better they will probably make you very happy.
I find DT super tower bass to be less on the tight/dry/defined, more on the ripe/phat side of the resolution spectrum, but that is only in direct comparison to slightly better setups. My impressions are likely due to placement restrictions more than anything. That is one of the limits of built-in powered "sub"woofs: ideal speaker locations may not be the best locations for subs, but they're built in so you're stuck with wherever the mains are. The results can be lumpier in-room response than could otherwise be achieved. Adding a separate sub as Popo9 has done effectively remedies this problem.
The meat of the music is above 80 hz anyway. If you have heard the DT's and like them, then buy with confidence and don't look back.
Wayne Highwood is offline
post #11 of 59 Old 01-31-2013, 06:59 PM
dapala's Avatar
Thanks for the excellent replies!
I'm gonna hold off on the 8060's for now. The 5 speaker package deal nearly max's out my budget and I need a new avr. My 13 year old Yamaha receiver, which has served me more then well over the years, has bit the dust. I listen to music mostly, but love the epic home theater experience. So I feel a separate subwoofer would be ideal.
dapala is offline
post #12 of 59 Old 02-01-2013, 05:25 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Hi Everyone,
The 8060ST is a very interesting speaker. I don't particularly like it because it seems to me to be less than what it is sold as, and less than what people who buy it seem to perceive it to be.
The two 4 1/2 speakers are really pretty wimpy as bass drivers, and no way can they be candidates for "large" settings:
Freq,Hz Max SPL, DB
10 66
20 78
30 85
40 90
50 94
60 97
70 100
80 102
90 104
100 106
110 108
120 109
130 110
140 112
150 113
160 114
170 115
The traditional 80 Hz setting is an absolute and total low water mark for a average In a high quality system, the recommended crossover setting would be more like 120-130 Hz.
Now, lets look at the 10" subwoofer:
Freq,Hz Max SPL, DB
10 80
20 92
30 99
40 104
50 108
60 111
70 114
80 116
90 118
100 120
110 122
120 123
130 125
140 126
150 127
160 128
170 129
As medium-performance subwoofers, I'd rate them for operation down to 50-60 Hz.
For your approx $2K investment I'm not dancing in the street. Your recovery position would be a subwoofer from SVS, Hsu, etc in the $1k-2K range possibly as your third sub.
arnyk is offline
post #13 of 59 Old 02-01-2013, 09:20 AM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
Freq,Hz Max SPL, DB
10 66
20 78
30 85
40 90
50 94
60 97
70 100
80 102
90 104
100 106
110 108
120 109
130 110
140 112
150 113
160 114
170 115
Freq,Hz Max SPL, DB
10 80
20 92
30 99
40 104
50 108
60 111
70 114
80 116
90 118
100 120
110 122
120 123
130 125
140 126
150 127
160 128
170 129
I'm not sure why you're mentioning that the 4 1/2" drivers are "pretty wimpy as bass drivers" because they are not bass drivers. They are not intended to be used as bass drivers. The larger woofer is the bass driver, and you can set that speaker as "large" at your receiver/processor. It has it's own internal crossovers.
Espo77 is offline
post #14 of 59 Old 02-01-2013, 09:33 AM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
To the OP, when I had my 2002TL's on the short wall, and pulled about 2.5 to 3 feet out into the room they were very natural sounding with lots of bass impact, with the gain on the rear of the speaker set at 11:00 or 12:00...no need for a sub. I have since moved them to the long wall (due to new furniture) and found the need to hook up my older Velodine sub-woofer for more bass. You'll need to experiment with placement in your room.
Espo77 is offline
post #15 of 59 Old 02-01-2013, 09:37 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Freq,Hz Max SPL, DB
10 66
20 78
30 85
40 90
50 94
60 97
70 100
80 102
90 104
100 106
110 108
120 109
130 110
140 112
150 113
160 114
170 115
Freq,Hz Max SPL, DB
10 80
20 92
30 99
40 104
50 108
60 111
70 114
80 116
90 118
100 120
110 122
120 123
130 125
140 126
150 127
160 128
170 129
Reading the manufacturer's documentation, it seems to me like the intent is that the 4 1/2 drivers are woofers and the 10 inch drivers are subwoofers. This is consistent with other speakers in the Deftech line.
This from the Deftech web site, their page dedicated to the bp-8060st
http://www.definitivetech.com/products/bp-8060st
" Later Definitive pioneered the concept of "powered towers" by incorporating powered subwoofers into Bipolar floor-standing speakers and dubbed them "SuperTowers." The BP-8060ST is a third generation BP SuperTower and makes use of our most advanced technologies,"
Significant phrase: "powered subwoofers"
arnyk is offline
post #16 of 59 Old 02-01-2013, 10:09 AM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
FYI, in the manual for the 8060ST you have two hook up options. Both options state "set the receiver/processor to "large".
Espo77 is offline
post #17 of 59 Old 02-18-2013, 07:28 PM
dapala's Avatar
Since passing on the 8060 front and center, I've been looking at some discounted Mythos Four's and a Mythos Three that I can afford to pair with a good subwoofer. Any thoughts on if that would be a good set up? Comparable to the 8060 setup without a sub?
dapala is offline
post #18 of 59 Old 02-21-2013, 09:35 AM
Larry L's Avatar
Freq,Hz Max SPL, DB
10 66
20 78
30 85
40 90
50 94
60 97
70 100
80 102
90 104
100 106
110 108
120 109
130 110
140 112
150 113
160 114
170 115
Freq,Hz Max SPL, DB
10 80
20 92
30 99
40 104
50 108
60 111
70 114
80 116
90 118
100 120
110 122
120 123
130 125
140 126
150 127
160 128
170 129
I am wondering where tese numbers come from. Are these from an independant lab, the manufacture, home measurements, or where?
What is the tes set up?
Was this using the LFE input of the UUT or using the speaker wire input?
Was the input signal direct to the speaker system or through another component?
What was the amplitude of the input signal(s)?
What is meant by "Max SPL, DB"? dos thiis mean the input was increased as the frequency was changed to measure the maximum possible output of the system? Or was the input voltage held constant and there was a drop off of output for the same input across the spectrum?
What was the room?
Very interesting numbers, if we know the test conditions.
Larry L is offline
post #19 of 59 Old 02-26-2013, 09:19 AM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
What was the room?
I'm a little confused about his numbers also. I think the first number represents the frequency, and the second is the sound pressure level in decibels.
Espo77 is offline
post #20 of 59 Old 02-26-2013, 09:37 AM
josh6113's Avatar
Quoted: 33 Post(s)
Liked: 26
He is just throwing basic numbers out there to try and explain the 8060-st's...if you want true numbers talk to definitive or post in the definitive forum...I own the 8060's and they sure can be set as large.
Doing what I do best...LIVIN!
josh6113 is offline
post #21 of 59 Old 02-26-2013, 12:14 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Freq,Hz Max SPL, DB
10 66
20 78
30 85
40 90
50 94
60 97
70 100
80 102
90 104
100 106
110 108
120 109
130 110
140 112
150 113
160 114
170 115
Freq,Hz Max SPL, DB
10 80
20 92
30 99
40 104
50 108
60 111
70 114
80 116
90 118
100 120
110 122
120 123
130 125
140 126
150 127
160 128
170 129
They are based on a mathematical model that estimates speaker SPL versus frequency for low distortion. The model is based on accepted loudspeaker theory and the particular one is due to Sigfried Linkwitz. The parameters for the model are developed by taking the most optimistic reasonable view of the parameters for the loudspeaker being analyzed because actual data is unfortunately generally given.
A mathematical model.
The model ignores any practical differences between those options. It presumes that the best way for that particular speaker was used by ignoring any potential losses.
It is presumed that the speaker is connected directly to amplifier, or effectively so.
Whatever it takes to achieve the given results. That information is also estimated by the model (an Excel spread sheet) but I generally don't provide it because it requires even more assumptions.
The maximum undistorted acoustical SPL that a speaker can generate is limited by diaphragm area and Xmax.
What was the room?
A room that neither helps nor hurts the performance of the speaker is presumed by simply not including any possible room effects in the model.
The model is only consistent with itself. The intent is that it should be used as a guide. In many cases it shows that it is impossible for the given driver configuration, presuming SOTA drivers which are of course rarely used, to produce enough bass to be satisfying in a neutral room. I''ve checked the model against real world speakers on occasion, and it showed the same general shape of data as the real world speaker, but as promised the computer model significantly overstated what the speaker actually did.
arnyk is offline
post #22 of 59 Old 02-26-2013, 12:17 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
It appears that you've missed the point. I never said that the 8060s can't be set as large. What I've said is that if you do that, you will encounter certain situations with performance. I don't recommend it on easy-to-explain theoretical grounds.
arnyk is offline
post #23 of 59 Old 02-26-2013, 12:18 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
What was the room?
That is correct.
arnyk is offline
post #24 of 59 Old 02-26-2013, 12:57 PM
josh6113's Avatar
Quoted: 33 Post(s)
Liked: 26
If you haven't tested the 8060's yourself you cannot say there will be situations with performance...unless your specific with your own tests.That is why I said to check with definitive for numbers and or any performance issues...that is what I meant...but thanks for your imput.
josh6113 is offline
post #25 of 59 Old 02-26-2013, 03:10 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
It is common engineering practice to base decisions on boundary condition models like this.
No speaker can reasonably be expected to exceed the performance numbers I post. Even though they are biased strongly towards the speaker in question, they still critique the capabilities of most of the speakers I apply them to.
That is why I said to check with definitive for numbers and or any performance issues...that is what I meant...but thanks for your imput (sic).
Those numbers are usually unobtainable. They do rarely exist but they don't exist for the vast majority of all speakers that people talk about on these forums.
Of course you can try to prove me wrong and correct the data I post with the results of actual tests. ;-)
arnyk is offline
post #26 of 59 Old 02-26-2013, 03:20 PM
josh6113's Avatar
Quoted: 33 Post(s)
Liked: 26
You seem to be the one to need to ask about the numbers....your numbers don't pertain to the 8060's and you've not done your own tests so I'll say again your numbers are basic numbers and don't reflect numbers related solely to the 8060's....just a basic accepted theory as you put it.
josh6113 is offline
post #27 of 59 Old 02-26-2013, 03:56 PM
Liked: 43
Arny, the 8060 has three 4 1/2" drivers whose output drops like a stone below 130hz or so. I'm not sure if they have a band pass filter, and they are each in their own sealed sub-enclosures which helps, but the point is they simply aren't tasked with high spl at frequencies below 130 hz. Even using your own best-case-scenario estimates, they don't seem insufficient.
post #28 of 59 Old 02-26-2013, 04:21 PM
josh6113's Avatar
Quoted: 33 Post(s)
Liked: 26
Where is your mesurents that they drop like a stone after 130 hz?....if you don't have any then your speculating.
josh6113 is offline
post #29 of 59 Old 02-26-2013, 05:12 PM
Liked: 43
Josh, you need to do more reading and learning, and less posting.
bfreedma likes this.
post #30 of 59 Old 02-26-2013, 05:18 PM
pokekevin's Avatar
Quoted: 16 Post(s)
Liked: 102
I wouldn't set 4.5 inch drivers to large:eek:
pokekevin is offline
