Getting rumblind sound out of my 8'' subwoofer. Here's a picture of my setup ! Help ! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-19-2012, 01:50 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
So i got the JAMO S608 5.1 speakers along with a jamo sub 250. The sub is placed in the front left corner near the left front speaker. It makes a rumble sound during some part of the movies, for example in the first scene of avatar when he get out of the plane on the wheelchair and a robot passes by.
I also tried setting my fronts to large and other speakers to small , but still. All i want is to set everything to small because im pretty sure the subwoofer gives better and deeper bass than the woofers of the front speakers.
Is it a good idea setting everything to small and try a 60hz crossover?
And what about the gain volume on the back of the sub ?
Here's a picture. Room is 4.3x4.6 meters and the sub is exactly behind the xmas tree. One side of the room is opened and on the other side is a piano , some curtains and a computer desk.
dazkyl is offline
post #2 of 4 Old 12-19-2012, 01:51 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
I also move the couch a little bit forward for wathcing movies so that its not touching with the backwall.
dazkyl is offline
post #3 of 4 Old 12-22-2012, 07:41 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Have you ever thought about joining an Audio Video forum like AVS, so that you could ask questions, post your problems, and perhaps come up with some solutions?
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #4 of 4 Old 12-23-2012, 08:47 AM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
With those speakers, the front speakers should operate well down to at least the 40-50 Hz range.
My guess is that the "rumble' is due to the output of the sub interacting with the output of the front speaker's 10-inch woofers.
You should set the sub to operate only up to around 40 hz or so to avoid overlap with the front speakers.
Adjust the subwoofer's upper frequency settting up and down between 40 and 60 Hz and play material with low bass until you get the best setting.
commsysman is offline
