What should i set the cut off frequency dial on the back of my sub ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-23-2012, 03:59 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
Running all my speakers to small with 80 crossover from the avr for all the speakers. At the moment the cut-off frequency on the back of the sub is all the way up.
Thanks !
dazkyl is offline
post #2 of 7 Old 12-23-2012, 04:04 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
That is the usually recommended setting, the one that causes no or a minimal high frequency cutoff. This puts the AVR and the recordings LFE channel in control of your system, which is generally the right thing to do.
arnyk is offline
post #3 of 7 Old 12-23-2012, 07:36 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
It depends on what your front speakers are capable of, and what setup capabilities your receiver has.
If they have frequency response down to 50 hz, for example, you don't want an excessive overlap between the front speakers and sub, so the sub should be set to cut off above 60 Hz or so.
On the other hand, if you have tiny front speakers that only go down to 100 Hz, then the subwoofer needs to operate up to that frequency.
Some receivers allow you to set the rolloff individually for each speaker and some will set them all the same, so it depends on the functionality of the receiver setup menu.
commsysman is offline
post #4 of 7 Old 12-23-2012, 08:32 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
My fronts are jamo s608 and ive set them to small with 80hz crossover so the sub handles from 80hz and down. Right ?
dazkyl is offline
post #5 of 7 Old 12-23-2012, 08:37 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
All good advice.
If you don't possess measuring capability, play some music with vocals, and with the help of a second person adjust the setting so it's doesn't un-naturally color the vocals,.. yet it retains the extra weight and warmth that the sub is tasked with.
Experiment, it shouldn't draw attention to itself, instead it should add seemlessly to the mains.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #6 of 7 Old 12-23-2012, 08:52 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
Originally Posted by FOH View Post
All good advice.
It is. All bass is kinda punchy and smooth but.not that strong. I gues because its a small 8" sub ( jamo sub 250) and the dial on the back is set to 9 to 10 o'clock so it stays smooth and does not rumble.
dazkyl is offline
post #7 of 7 Old 12-23-2012, 12:43 PM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
eljaycanuck is offline
Closed Thread Audio Theory, Setup, and Chat
