What gauge wires to use - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-30-2012, 10:12 PM - Thread Starter
Hey guys i just ordered the Kef T305 and a Denon AVR-2113CI. They should be ariving next week and i dont want to be caught without cables for them.
My longest distance from the amp to the rear speakers will be about 25-30 feet. I dont know weather to get 16 or 18 gauge wires for it. What do you guys think?
Also should i be buying banana connectors or the straight wires should be fine.
smoothop is offline
post #2 of 3 Old 12-30-2012, 10:46 PM
Glimmie's Avatar
Quoted: 764 Post(s)
Liked: 638
Here you go.
This is the defacto AVS standard for such advice.
http://www.roger-russell.com/wire/wire.htm
Glimmie is offline
post #3 of 3 Old 12-31-2012, 01:39 AM - Thread Starter
thanks i guess im good with the 18
smoothop is offline
