Help with basic 5.1 power question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-02-2013, 12:22 PM - Thread Starter
Messymitch's Avatar
I know practically nothing when it comes to sound set ups so bare with. Hope I posted this in the right spot.
Thinking about matching these speakers and this sub to match with a recent Onkyo receiver I scored for on the cheap. I'm a noob to speaker set ups and wondering if the receiver will be able to power these?
A little info on the stuff.
Receiver:
Power Output
Front L/R
80 W + 80 W (8 ohms, 20 Hz-20 kHz, 0.7%, 2 channels driven, FTC)
110 W + 110 W (6 ohms, 1 kHz, 0.9%, 2 channels driven, FTC)
Center
Surround L/R
Dynamic Power: 180 W (3 ohms, 1 ch); 160 W (4 ohms, 1 ch); 100 W (8 ohms, 1 ch)
Sub says Power Output: 50 watts Continuous Average Output and Dynamic Power Output: 100 watts.
These speakers say: Recommended Amplifier Power: 20 - 100 Watts RMS (Continuous)
Thanks for help guys! Hopefully there wasn't a sticky on basic info did some searches but nothing came up.
Messymitch is offline
post #2 of 4 Old 01-02-2013, 12:50 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
That's not a problem. But what do the state as the nominal impedance? Do they state a minimum impedance? If anything, that's the critical question, though the odds are you're OK.
Messymitch likes this.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 4 Old 01-02-2013, 12:52 PM - Thread Starter
Messymitch's Avatar
Nominal Impedance
Center Speaker: 8-ohm compatible
Satellite Speaker: 8-ohm compatible
Thanks again
post #4 of 4 Old 01-02-2013, 01:00 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
I presume the fronts are 8 ohm as well. You have nothing to worry about.
mcnarus is offline
