Did I just totally screw up??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-04-2013, 09:21 PM - Thread Starter
Scared by AV's Avatar
I just got done running 2 lengths of two conductor speaker wire under my carpet from 1 side of the room to the other and now that I have the carpet and furniture back in place I just realized I didn't label either conductor, on either length, "black" or "red"!! Did I just screw up badly or can I test the wire some how to make sure I put the same conductor on red on each side of the wire?
Scared by AV is offline
post #2 of 8 Old 01-04-2013, 09:26 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Most have a coloration difference for each wire, or a ridge on one and smooth on the other....depends what you bought.
lovinthehd is offline
post #3 of 8 Old 01-04-2013, 09:29 PM - Thread Starter
Radio shack white speaker wire...the conductors look exactly alike?!?!?! I can't just hook it up and test it? Won't it NOT work if I have it switched on 1 end?
post #4 of 8 Old 01-04-2013, 09:37 PM - Thread Starter
Wait....I am an idiot and you are right. I swear when I first looked at it they looked exactly alike. Sorry, and thank you.
post #5 of 8 Old 01-04-2013, 09:39 PM
lovinthehd's Avatar
Liked: 4775
No problem, been there done that. Hooking them up switched around will put your speakers out of phase (unless they were wired incorrectly internally which can on occasion actually happen).
post #6 of 8 Old 01-05-2013, 12:03 PM
possamai's Avatar
Just out of curiosity..
How would that affect things?
Would it degrade audio quality? Would it damage the speakers?
possamai is offline
post #7 of 8 Old 01-05-2013, 12:53 PM
lovinthehd's Avatar
Liked: 4775
When two speakers are out of phase with each other they're not in sync so the audio will be off, a less focused sound than it should be. Won't harm your speakers. Try this http://www.thx.com/consumer/home-entertainment/home-theater/thx-optimizer/thx-optimizer-speaker-phase/
post #8 of 8 Old 01-09-2013, 10:35 AM
possamai's Avatar
Thanks for the explanation.. I suppose when both speakers are wired wrong (but in phase with each other) that's when you switch phase on a subwoofer..
possamai is offline
