This amp work with these speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 01-05-2013, 08:26 PM - Thread Starter
phatcorns's Avatar
Hi, everyone. I just can't seem to wrap my head around all of this. I have a pair of JBL ND310 speakers, and they say to use an amp with a maximum of 250 watts of power.
Now, from some things I've read, you need to have MORE wattage from your amp so that it doesn't produce clipped signals that damage your speaker.
So with that being said, will this QSC GX3 (http://www.qscaudio.com/products/amps/GX/index.php) be okay to power those speakers or is it going to overload the speakers since it has 300 watts per channel at 8 ohms.
Thanks for any help, I just really don't understand all of this that well.
phatcorns is offline
post #2 of 17 Old 01-06-2013, 05:10 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Wattage ratings in speakers are more for guidelines than absolutes and the difference between 250 watts and 300 watts is a fraction of a dB.
The BIG problem you have is a mismatch of equipment since the the amps you are looking at are designed for commercial use. Their SQ would be considered unacceptable for serious HT use. If going to use this in a commercial setting then the speakers are (likely) inappropriate for that task.
William is offline
post #3 of 17 Old 01-06-2013, 08:02 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
The power rating of a speaker is like the speed rating on a tire; it is the MAXIMUM safe operating power.
There is nothing wrong with having an amplifier with more or less of a power rating compared to the speakers, BUT if the amplifier can put out more than the speakers are rated for you have the capability to overdrive and damage the speakers.
This is almost never a real problem, however if you have ears and use them.
When the power level approaches a dangerous level, the speakers will almost certainly be deafeningly loud and they will distort.
If you ignore that, you can damage them, but a person has to be pretty dumb to let it get to that point.
commsysman is offline
post #4 of 17 Old 01-06-2013, 09:56 AM
diomania's Avatar
Liked: 50
How did you figure that out?
diomania is offline
post #5 of 17 Old 01-06-2013, 09:59 AM
diomania's Avatar
Liked: 50
Still safer for an amp to have more than speaker can handle because clipping from not having enough can cause serious damage to speaker drivers.
diomania is offline
post #6 of 17 Old 01-06-2013, 11:25 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Largely audiophile myth, actually. The real threat to speaker health is an idiot with a volume knob. the extra energy in clipped waveforms is generally marginal.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #7 of 17 Old 01-06-2013, 11:28 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Not true. Clipping doesn't damage speakers; power does. (To be more precise, power in the hands of a nincompoop does.)
A basic 50 wpc receiver could probably drive your JBLs just fine.
mcnarus is offline
post #8 of 17 Old 01-06-2013, 12:18 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
There are several reasons but one is the amp uses Class B amplification. Class B is great for PA and very efficient but suffers from x-over distortion and is (almost) never used in HT amps.
Originally Posted by mcnarus View Post
Not true. Clipping doesn't damage speakers....
Clipping can be very dangerous for speakers, especially tweeters. Here is a good easy explanation of why.
William is offline
post #9 of 17 Old 01-06-2013, 01:47 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Agreed.
Please illustrate this claim with relevant measurements or reliable listening tests.
arnyk is offline
post #10 of 17 Old 01-06-2013, 01:51 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
http://www.qscaudio.com/products/amps/gx/gx_faq.php#q8
QSC says that the GX3 uses a revolutionary biasing scheme that allows a near-perfect implementation of class B which eliminates the historical problems of Class B operation with crossover notches. That is not the same as a traditional class B output stage.
This is relatively unique among pro audio amps, so nothing about pro audio amps should be extrapolated from the GX3,
arnyk is offline
post #11 of 17 Old 01-06-2013, 04:08 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
No, it really can't, except in rare circumstances that don't generally apply to home audio. If you have a driver connected directly to an amplifier, as you might in a pro setup (and note that you linked to a pro audio site), then yes, that could happen. But a passive crossover will prevent that extra energy from reaching the tweeter—except for the extra harmonics produced by the clipped waveform as it starts to resemble a square wave. Often these extra harmonics are blamed for the damage, but they just don't account for enough energy to do the trick.
mcnarus is offline
post #12 of 17 Old 01-06-2013, 07:10 PM
diomania's Avatar
Liked: 50
Not that rare, at least the group that I'm familiar with. Many of them use "full range" speakers (Fostex, Lowther) with no passive crossover.
diomania is offline
post #13 of 17 Old 01-06-2013, 07:39 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Please note that the OP does not use such a speaker.
mcnarus is offline
post #14 of 17 Old 01-06-2013, 08:06 PM - Thread Starter
phatcorns's Avatar
Thanks for the replies everyone. I have an Audiosource Amp 102 (http://www.audiosource.net/products/electronics/amplifiers/amp-102/overview/), I haven't had a chance to test it, but will that work ok with my speakers? I run them at high volume in a dance studio.
post #15 of 17 Old 01-06-2013, 08:28 PM
diomania's Avatar
Liked: 50
That could mean many different things. One person's high volume may mean medium volume for perception of someone else. To get some bearing, you will need to come up with decibel numbers.
If you mean dance studio as in commercial setting, I'll be more concerned with the durability of the speakers and amp. How often, how long of use and what db level are you dealing with?
diomania is offline
post #16 of 17 Old 01-07-2013, 06:34 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If I were trying to present high volumes in a dance studio, and we mean truly high volumes well in excess of 110 dB SPL, I would not look at hifi gear, but start looking at the world of professional audio.
On balance a pair of ND310s driven by a 300 wpc QSC power amp have a lot of pro audio DNA, and may exactly what you are looking for.
I think that they are worth giving a chance. If they come up a little light you have some logical paths for upgrades that would preserve the value of your initial investment - get another pair of ND310s and/or get a subwoofer.
Note that ND310 have not been made for about 4 years and are valued at about $2-300 each in the used equipment market. I don't know what you are being asked to pay for them.
Like other insightful posters. I also don't really know what you are trying to do - size of room, actual SPLs, room acoustics, etc. However if you are currently using a boom box or something like it, this is going to be one heck of a good upgrade!
arnyk is offline
post #17 of 17 Old 01-07-2013, 09:34 AM
diomania's Avatar
Liked: 50
But it's still better to have some headroom than not. Plus, clipping doesn't sound good.
diomania is offline
