Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 2285Likes
post #331 of 23602 Old 01-14-2013, 02:39 PM
mogorf's Avatar
Quoted: 1125 Post(s)
Liked: 723
Originally Posted by kbarnes701 View Post
A useful tip...
I think the advice of Jerry has a lot of practical values. May I note that once we have established the guideline of the vertical axis to be between 45 - 105 dB, the 75 dB level would put the curve right in the middle of the graph instead on the lower part as seen on my graph. As far as we are still at the stage of measuring our room's response the curve is not supposed to show a different response with different sweep levels. We haven't arrived to equal loudness contours, human hearing and DynamicEQ issues yet. Just the room.
Remember the slogan? " Hi-Fi systems are supposed to sound best when there is nobody in the room!" LOL
mogorf is online now
post #332 of 23602 Old 01-14-2013, 04:48 PM
asarose247's Avatar
Quoted: 832 Post(s)
Liked: 642
Im going thru Jerrys "rew setup etc" .
all went well until rew preferences page 28, i do not have a "drivers" selection box. has rew not noticed that asio is present?
i'd appreciate any direction.
i'm using my audessey mike for this experimentation.
thank you
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #333 of 23602 Old 01-14-2013, 04:58 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7707 Post(s)
Liked: 4312
thank you
The "drivers" box has nothing to do with the ASIO4ALL installation, and should always have two options, "Java" and "ASIO".  On the REW toolbar, please click Help/About REW and report what version you have installed.  You should be running this version:
AustinJerry is online now
post #334 of 23602 Old 01-14-2013, 05:43 PM
asarose247's Avatar
Quoted: 832 Post(s)
Liked: 642
thank you, Jerry
i have only rew 5.00.
i've been to hts. i got past the problem of installing 5.0 that i had late last week
now i'm getting the same "did not install properly" messagefor 5.01 beta 12
windows defender is "off" firewall is "on"
and my systems guy is currently not onsite but i could call him if i get any creative suggestions to help him guide me.
post #335 of 23602 Old 01-14-2013, 05:51 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Originally Posted by AustinJerry View Post
Originally Posted by jevansoh View Post
EDIT: Max obviously beat me to this and stated it much more eloquently I might add, but I do agree with the poster that stated this needs to be added to the eventual Usage Guide/Current FAQ. I will be adding this to post 2. Could someone who previously DID NOT understand this and now DOES understand this thanks to Max's or my post take a few minutes and re-write this as a Q
Before we do this, I am still sorting out with Max what seems to be a misunderstanding of averaging, and smoothing applied to averaging.  I am still waiting for Max's respoonse.
Oh sorry, missed that.
Yes, you can just delete the averaged graph using 1/3 smoothing on thwe individual measurements and then open all 6 mmeasurements and set them to No Smoothing and average them again. The question is why? If you just set the individual measurements to No Smoothing before averaging them, you can save the result and view it any way you want to later.
This makes it much simpler later on if you want to compare several different averaged measurements of say, pre and post Audyssey, pre and post acoustic treatment, different sub locations etc.
As you can see from Feri's example, you can view the full range averaged measurement at 1/3 smoothing, then focus on the 5-250Hz region with No Smoothing easily, as opposed to having to re-average the measurements with a different Smoothing setting.
Max
djbluemax1 is offline
post #336 of 23602 Old 01-14-2013, 05:57 PM
asarose247's Avatar
Quoted: 832 Post(s)
Liked: 642
5.01 installed via uninstalling 5.0
proceeding
thanks anyway if you were thinking about it.
post #337 of 23602 Old 01-14-2013, 05:58 PM
Liked: 4312
Max
I understand now, Max. Two different approaches resulting in the same thing, but your approach is certainly more efficient. Thanks for clearing this up.
post #338 of 23602 Old 01-14-2013, 06:45 PM
asarose247's Avatar
Quoted: 832 Post(s)
Liked: 642
strangely . . . no output or input to be selected, but the asio showed up as expected. my onkyo 270 now shows multichannel in and sounds great playing anything i have, even after restarting
my sound card lets me check 5.1 speakers, full range (so to speak)tho i run a 7.2 anyway . . hints?
a check in the sound card shows output thru the hdmi and i can see the bar for the mike also responding tis a puzzlement
post #339 of 23602 Old 01-15-2013, 05:11 AM - Thread Starter
jevansoh's Avatar
Quoted: 51 Post(s)
Liked: 102
Originally Posted by mogorf View Post
Hi Guys,
I've selected this graph from my previous post below for some further discussions with the aim of clarifying matters before most of us can get their usb mic.
Averaged with 1/24th octave smoothing and Audyssey Off:
As a reminder, this graph is a 1/24th octave smoothed and averaged graph of 6 unsmoothed measurments taken in Audyssey style (MLP + 5 more around the couch) in my living room of the Center + Sub with the Audyssey mic (without a calibration file, of course). Nonetheless, as stated above this was taken with Audyssey off. Now, please take a look at the right side of the graph where there is a severe rolloff from cca. 13 kHz. I don't know why this happens. Denon should be OK up to 100 kHz, laptop should be no problem, Audyssey mic should also perform well way above 20 kHz. Could this HF rolloff be due to the lack of calibration of the Audyssey mic? Any ideas? Let's discuss. smile.gif
Hi Feri,
This is totally normal with this type of mic. Pretty much all condensor Mic's that use the $2.00 Panasonic module (which is pretty much all inexpensive mics) will be pretty darn accurate from the mid-bass to upper mid-range frequencies but start rolling off somewhere around 50hz and anywhere above 10khz (conservative estimates here).
That's the main point of the built-in Audyssey calibration file and how they are all able to be the same based on a batch/test of several mics because they all pretty much perform close to the same. The cheap Panasonic Capsules really are that good and consistent.
So almost all cal files will show the most correction in the high end and very low frequencies.
For folks that use the Radio Shack SPL meters, they are actually pretty accurate, too, contrary to common belief.
They are great from about 40hz to about 7-8khz but have pretty sharp roll-off above that when used at grazing angles (90 degrees) with C-Weighting and surprisingly have a shallow roll-off to below 20hz! So believe it or not, the Radio Shack SPL meters are great for calibrating subwoofers as they are inexpensive and easy to come by.
I don't have experience with the new model of RatShack meter though, this is only in reference to the 2055 model.
Anyway, don't worry about it. It looks totally normal. I definitely recommend you of all people get a calibrated mic, and at 90 degrees too. For you, I honestly would recommend the Dayton UMM-6 mic calibrated at 0, 45, and 90 degrees as that Mini-DSP Mic will only be able to be used at 0 degrees, pointing at the speakers and NOT up at the ceiling like you take all your Audyssey measurements. wink.gif
As for your previous graphs, they look totally normal and much more accurate now.
Audyssey is really doing a good job in your room as you have 3 obvious modes and a ton of reflections/comb filtering yet you have one of the smoothest "after" measured graphs I've ever seen!
Congratulations,
--J
jevansoh is offline
post #340 of 23602 Old 01-15-2013, 05:16 AM - Thread Starter
jevansoh's Avatar
Quoted: 51 Post(s)
Liked: 102
One would expect the measurements centered around 75dB with a proper mic calibration.
A useful tip...
Yes! RE: This tip and the previous regarding smoothing/averaging that Jerry is still in talks with Max about... When Jerry is ready or feels "we" collectively are ready to add that Q&A, where do you feel these tips should best be placed??
I have so many tips in the 2nd post, some of which are actually pretty important, I'm afraid since it's such a long post they might be overlooked, plus we need to be able to add the tips and tips by nature aren't necessarily Q&A's/FAQ's so I'm again calling on your organization skills, Keith. wink.gif
Not that it is so important to hurry up and get this tip and the one other one up, I'm just thinking ahead, and honestly have a bunch more to add, but don't know where to put them. Tell me where to stick it, Keith. tongue.gif
--J
jevansoh is offline
post #341 of 23602 Old 01-15-2013, 06:41 AM
JChin's Avatar
Quoted: 376 Post(s)
Liked: 210
I hear you. When I first started testing ASIO4ALL, I had the same problem in the ASIO control panel. My HD audio device was showing idle, and no amount of clicking would enable it. You may recall a previous posting of mine, where I reported that a completely fresh install of Windows cleared up this problem.
Hi Jerry, so a fresh install of Windows gave you the 8 channels as well? By the way, learned a few things on the step by step guide, excellent job!
JChin is online now
post #342 of 23602 Old 01-15-2013, 09:23 AM
Liked: 4312
No, I am afraid my laptop hardware only supports 2 channels, regardless of the attempts I have made.  As I stated previously, being able to measure two channels provides the functionality one needs with REW.  You can measure left, right, center (as a combined left+right) and the subwoofers (through redirected bass from the main speakers).  I see no significant additional benefit from being able to measure surrounds or surround backs separately.  Of course, I could just be rationalizing my hardware deficiency...   wink.gif
post #343 of 23602 Old 01-15-2013, 09:26 AM
mogorf's Avatar
Liked: 723
Jerry, if you still do not have 8 channel support, then what did the Windows reload acually solve?
post #344 of 23602 Old 01-15-2013, 09:43 AM
mogorf's Avatar
Liked: 723
Hi Feri,
Congratulations,
--J
J,
As regards the UMM-6 and the UMIK-1 MiniDSP mics what difference might one expect between these two devices when it comes to accuracy of REW measurements? Pointing the UMIK-1 to the speakers and changing direction from measurement to measurement would not be a big trouble, I suppose. If you recommend the UMM-6 to me, why only to me?smile.gif
post #345 of 23602 Old 01-15-2013, 09:45 AM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5262
A useful tip...
--J
I am making a note of everything posted so far that might be useful in a FAQ. When there is a decent amount of potential content I'll create the FAQ using interactive hyperlinks like the Audyssey FAQs. The FAQ will be in sections - eg Basic Windows Setup, Basic REW Setup, Advanced REW Setup, Creating and Interpreting FR Graphs, Creating and Interpreting Waterfall Graphs, Creating and Interpreting ETC Graphs etc etc. I will post the suggested format before populating it to get approval from you and other members along with any suggestions for improvement. Like the Audyssey FAQs, this FAQ can then be added-to on a continuous basis. It is too soon to make the FAQ yet because we need to be pretty sure of the outline before we start - it is a royal PITA to change it afterwards.
kbarnes701 is offline
post #346 of 23602 Old 01-15-2013, 09:47 AM
kbarnes701's Avatar
Liked: 5262
He recommended it to all of us, Feri, in his 'mic post'. I have mine on order - delivery beginning of Feb (plus carriage time to UK).
post #347 of 23602 Old 01-15-2013, 10:35 AM
Liked: 4312
I could not get the HDMI audio started--it showed idle and would not work.
post #348 of 23602 Old 01-15-2013, 10:42 AM
Liked: 4312
J,
It is normally considered a better practice to aim the microphone at the ceiling because it takes into account the contributions of the room.  Pointing the mic directly at the speaker is better if you are interested in analyzing a specific speaker's response.  Also note that if you want to measure the combined output of left+right+subs, it is impossible to aim the mic at multiple sound sources at the same time, so aiming at the ceiling produces the better measurement.  After all, you don't aim the Audyssey mic directly at the speaker, do you?
If you check Jason's original post, I believe he mentioned the advantage of the mini-DSP was that it was plug-and-play (I know I shouldn't use that term...).  However, I believe he also commented on the advantage of the individually-calibrated UMM-6, with its direction-specific calibration files.  He also mentioned that he is working with John Mulkahy to get the UMM-6 supported as a PNP mic.
post #349 of 23602 Old 01-15-2013, 10:53 AM
kbarnes701's Avatar
Liked: 5262
Murphy's Law dictates that JM will achieve this one day after we have all figured out the best manual configuration procedure :)
post #350 of 23602 Old 01-15-2013, 10:54 AM
kbarnes701's Avatar
Liked: 5262
Another one for the FAQ.
post #351 of 23602 Old 01-15-2013, 11:06 AM
mogorf's Avatar
Liked: 723
Thanks Jerry for making that clear. Wish the UMM-6 would be PNP and the UMIK-1 would come with direction-specific calibration files. That's all I wish! smile.gif
post #352 of 23602 Old 01-15-2013, 11:09 AM
sdrucker's Avatar
Quoted: 881 Post(s)
Liked: 599
Murphy's Law dictates that JM will achieve this one day after we have all figured out the best manual configuration procedure smile.gif
Silly question: what does Jason do professionally? From reading his posts, I'd think he's some sort of sound engineer or has specific technical training in acoustics. Or is he just an enthusiast who's dedicated most if not all of his non-working waking hours to A/V? More curiousity than anything else.
NB: I haven't given up trying REW, but I've had some family stuff that's taking up my time (plus I went to Canada for an ice wine festival with my wife over the weekend---where it was almost 60 degrees compared to frigid Chicago). I'm still following the conversation with interest, particularly how easy it is with REW to combine raw measurements into averages, and the graph scaling/smoothing guidlines. I hope to get more into this over the weekend, with my (current) OmniMic mic or the ancient Audyssey Basic one I've still got.
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Misc.: Oppo 103, Oppo 203 UHD player, JRiver
Speakers: PSB Imagine T3 LCR, Imagine T Wides and Side Surround 1, T2 Side Surrounds, Imagine XB rears, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 11.4.6
sdrucker is online now
post #353 of 23602 Old 01-15-2013, 12:03 PM
kbarnes701's Avatar
Liked: 5262
Get the best mic, regardless. I went for the UMM-6 for the reasons Jerry gives above.
post #354 of 23602 Old 01-15-2013, 12:07 PM
kbarnes701's Avatar
Liked: 5262
IDK what J does, but did I not read he is setting up his own acoustics company?  J?
This is what I think I will love about REW once it is working here. I can make one measurement file, with all the measurements in it that I need for that session and then go and sit and analyse those measurements every whichway, at my leisure. If I want different smoothing, I apply it... if I want a waterfall, I generate it, if I want an ETC, I create it... And best of all, I can send my data file to the experts and THEY can analyse it for me and tell me where I am going wrong or what I need to do next (if I get stuck). This is way, way ahead of OM...
post #355 of 23602 Old 01-15-2013, 12:10 PM
sdrucker's Avatar
Quoted: 881 Post(s)
Liked: 599
By the time you're done, you're going to wind up creating Powerpoint presentation with all the charts you'll have from a given configuration smile.gif
post #356 of 23602 Old 01-15-2013, 12:17 PM
cadett's Avatar
Quoted: 45 Post(s)
Liked: 102
I was hoping we could do a webinar!
cadett is offline
post #357 of 23602 Old 01-15-2013, 12:20 PM
sdrucker's Avatar
Quoted: 881 Post(s)
Liked: 599
^^ Worse, we can use GoToMeeting or another document sharing site to compare our measurements and resulting post-Audyssey calibrations biggrin.gif
post #358 of 23602 Old 01-15-2013, 12:23 PM
mogorf's Avatar
Liked: 723
Nonetheless, I do believe this is going to be the best REW thread on the Internet, ever! Coz we are going through each and every detail, even the smallest ones and by the time we can get our mics we will be more trained than an airline pilot in the cockpit with all the bells and whistles normal mortals can not imaging what they are for.
No lousy graphs and wrong conclusions will ever show up or happen to those members who are following up this thread and reading it to the letter. I'm sure! cool.gif
post #359 of 23602 Old 01-15-2013, 12:30 PM
Liked: 4312
Well, you guys are welcome to stop by my place any time and we'll do some serious measuring!
post #360 of 23602 Old 01-15-2013, 12:50 PM
sdrucker's Avatar
Quoted: 881 Post(s)
Liked: 599
Hopefully it won't take as long to master REW as writing a dissertation!
Dayton , Dayton Audio , Room Equilizer Wizard Rew
