Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 1670Likes
post #361 of 21161 Old 01-15-2013, 02:00 PM
mogorf's Avatar
Quoted: 1047 Post(s)
Liked: 600
Originally Posted by AustinJerry View Post
It is normally considered a better practice to aim the microphone at the ceiling because it takes into account the contributions of the room.  Pointing the mic directly at the speaker is better if you are interested in analyzing a specific speaker's response.  Also note that if you want to measure the combined output of left+right+subs, it is impossible to aim the mic at multiple sound sources at the same time, so aiming at the ceiling produces the better measurement.  After all, you don't aim the Audyssey mic directly at the speaker, do you?
Jerry et all,
Pointing the mic to different directions: well noted and makes perfect sense! On the otherhand if we look at the UMM-6 calibration graph of Cross-Spectrum we can see that up to 1 kHz there is practically no difference between 0, 45 and 90 degrees, while above 1 kHz things start to change a bit:
Cross-Spectrum page here.
My Q with the UMIK-1 (or any other commercially available condenser type test mic) is: do we really need to be surgically precise with the calibration files for different directions and always choose the appropriate file, or no need to sweat on it too much due to minute differences that only appear at the top of the HF side?
Note: the above graph has been taken with 1/3rd octave smoothing, while no smoothing may reveal something more below 1 kHz. wink.gif Hopefully not much.
Another note: once we have a known calibration file, say for 0 degrees, we can take another measurement by pointing the mic to the ceiling, read the differences from the graph and create another cal file, save it as .txt and load it into REW. Seed for thought! smile.gif
mogorf is online now
post #362 of 21161 Old 01-15-2013, 02:32 PM
AustinJerry's Avatar
Quoted: 6258 Post(s)
Liked: 3489
Feri, you can do whatever you want to. However, I prefer the incremental accuracy of the individually-calibrated mic. Recall that the Mini-DSP uses a generic calibration file, while Cross-Spectrum labs provides the extra service of calibrating each microphone.
Would I want to manually adjust a measurement file to compensate for the differences between the 0 and 90 degree response curves? No, I would not.
Why are you being so persistent in defending the Mini-DSP mic over the UMM-6 mic? I don't think it makes a hughe difference, but please let the rest of us choose what we want to.
AustinJerry is offline
post #363 of 21161 Old 01-15-2013, 02:59 PM
mogorf's Avatar
Liked: 600
Jerry, what I'd like to see clearly is whether we really need to be dead on with mic specs or there is a certain range of tolerance we can all live with without seriously affecting the end results. Of course the slogan shall remain: "each his own". Agree? smile.gif
post #364 of 21161 Old 01-15-2013, 05:04 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5067
Originally Posted by sdrucker View Post
Originally Posted by kbarnes701 View Post
IDK what J does, but did I not read he is setting up his own acoustics company?  J?
This is what I think I will love about REW once it is working here. I can make one measurement file, with all the measurements in it that I need for that session and then go and sit and analyse those measurements every whichway, at my leisure. If I want different smoothing, I apply it... if I want a waterfall, I generate it, if I want an ETC, I create it... And best of all, I can send my data file to the experts and THEY can analyse it for me and tell me where I am going wrong or what I need to do next (if I get stuck). This is way, way ahead of OM...
By the time you're done, you're going to wind up creating Powerpoint presentation with all the charts you'll have from a given configuration smile.gif
This is the problem with Windows - so many potential combinations of OS versions, hardware, firmware, drivers, etc etc etc. But often it's fairly obvious - if a screenie says XXXX Soundcard and you have YYYY soundcard, it's still a soundcard.... ;)
kbarnes701 is offline
post #365 of 21161 Old 01-15-2013, 05:07 PM
kbarnes701's Avatar
Liked: 5067
Would this be because it's the one he's bought?  :) ;)
post #366 of 21161 Old 01-15-2013, 05:16 PM
mogorf's Avatar
Liked: 600
Not bought, but will buy! BTW, why buy a non-PNP mic when a PNP mic is or will be available for "him" soon. smile.gif
post #367 of 21161 Old 01-15-2013, 05:58 PM
Liked: 3489
My friend Feri,
What is a discussion without facts and data?  To support my case, I have devised the following test:
- Pulled out and set up the "legacy" REW kit, which includes an individually-calibrated EMM-6 microphone with both zero and 90-degree calibration files.
- Configured my left speaker as a full-range speaker, and turned Audyssey and subs off (i.e. isolating the left speaker)
- Placed the mic at the MLP
- Ran the following tests:
1.  Full sweep with mic pointed at 90 degrees, with no calibration file
2.  Full sweep with mic pointed at 90 degrees, with 90-degree calibration file
3.  Full sweep with mic pointed at 90 degrees, with 0-degree calibration file
4.  Full sweep with mic pointed at 0 degrees (i.e. at the left speaker), with 0-degree calibration file
5.  Tests 2 and 4 repeated, with Audyssey on
Here are the measurements.  First, the three measurement taken with the mic pointing upwards at 90 degrees.  Below 600Hz, there is not much difference.  Above 600Hz, the curves begin to diverge, with a visible difference above 10kHz.
Second, here are two measurements, the red one with mic at 90 degrees using the 90-degree cal file, and the black one with the mic pointing directly at the speaker, with the 0-degree calibration file.  This graph shows significantly different curves above 400Hz.
Third, here is the same graph as the second one, but with Audyssey turned on.  Again, significant differences, but seen over the entire frequency range.
This experiment leads me to the following conclusions:
- First, with the microphone pointed at the ceiling, calibration files do make a difference, but the difference is subtle.
- Second, there is a significant difference in the measurement curves with the mic pointed toward the ceiling versus pointing the mic directly at the speaker.
So, one might ask, which of the two microphone orientations produces the more correct measurement upon which we should make decisions involving moving speakers, adding treatments, etc.?  If we choose the wrong one, our corrections may be flawed.
The Mini-DSP, as I understand it, comes only with the zero-degree calibration file.  So, with this mic, you can chose to point it directly at the speaker using the zero-degree calibration file, or point the mic at the ceiling zero-degree calibration file.  IMO, either is a compromise.
Based on this data, Feri, which mic orientation would you choose, now that it has been demonstrated that it makes a big difference?
post #368 of 21161 Old 01-15-2013, 06:32 PM
Liked: 3489
FYI, in case you haven't experienced a "legacy" REW setup, here it is:
Rob Greer likes this.
post #369 of 21161 Old 01-15-2013, 08:10 PM
asarose247's Avatar
Quoted: 682 Post(s)
Liked: 442
follow up to post 338
when i select java in the preferences, obviously ASIO etc isnt selected BUT ta-da the HDMI output and the External mike are there!
and they "work "if i just run a measurent.
how much more backwards could i do this to get it right.
and the sound card configures to test 7.1 speakers
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #370 of 21161 Old 01-15-2013, 10:12 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
BTW, just thought I'd mention for all the folks having REW setup issues, I just ran into an HDMI output issue that took 20+ minutes to solve and the solution turned out to be stupidly simple (and annoyingly dumb).
Because there are so many different PC and Windows configurations possible, it's difficult to have one set of settings. In my case, my laptop's HDMI port does not natively output audio. I have to toggle that ON, but in this instance, toggling it on didn't work. It took 20+minutes to discover that I had to shut down and reset for the change to take effect. How annoying.
Max
djbluemax1 is offline
post #371 of 21161 Old 01-16-2013, 04:11 AM
kbarnes701's Avatar
Liked: 5067
Sorry Feri - I thought you said you had ordered it already. If not, I would urge you to buy the calibrated UMM-6 which is a similar price and comes with 3 calibration files for 0, 45 and 90 degrees. The issue of it being PnP is a non-issue for someone with your technical expertise.
post #372 of 21161 Old 01-16-2013, 04:15 AM
kbarnes701's Avatar
Liked: 5067
Good job there AJ.  Personally, I can't see the point in buying a mic that is effectively UNcalibrated for its most common use (for us) which is in the 90 degree position pointing up to the ceiling. Not when there is a similarly priced mic available that is individually calibrated three ways. Yes, there is a little more to do (initially) with the UMM-6 but it has to be done once only and that is it. And with your excellent Guide to hand, it is an easy and straightforward process that anyone in this thread can master. Even me ;)
post #373 of 21161 Old 01-16-2013, 04:32 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Keith, curious whats the difference between getting it at CSL and Parts Express (see product details)?
JChin is online now
post #374 of 21161 Old 01-16-2013, 04:36 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
No, I am afraid my laptop hardware only supports 2 channels, regardless of the attempts I have made.  As I stated previously, being able to measure two channels provides the functionality one needs with REW.  You can measure left, right, center (as a combined left+right) and the subwoofers (through redirected bass from the main speakers).  I see no significant additional benefit from being able to measure surrounds or surround backs separately.  Of course, I could just be rationalizing my hardware deficiency...   wink.gif
Well that sucks. Wonder how hard it is to change out a sound card on a laptop?
JChin is online now
post #375 of 21161 Old 01-16-2013, 05:27 AM
kbarnes701's Avatar
Liked: 5067
CSL individually calibrate each mic and issue a calibration file for 0, 45 and 90 degrees.
post #376 of 21161 Old 01-16-2013, 07:28 AM
Liked: 3489
As I mentioned, I see no particular disadvantage of having only two channels. I have been using REW for several years with an external sound card which also has only two channels, and that never inhibited taking meaningful measurements. Why do you think this is an issue? There is no physical "sound card" in a laptop--it is a chip embedded in the laptop's motherboard.
post #377 of 21161 Old 01-16-2013, 08:07 AM
IgorZep's Avatar
Quoted: 386 Post(s)
Liked: 185
When I was experimenting with my mic angle I wasn't getting as much of a difference as you did on those graphs on the mid frequencies. This makes me worry that you get that difference because of some other reason than the mic angle. There might be the height/distance difference if you leave the center of the mic in the same place (the capsule placement is what matters). Also dip between 10-20kHz might suggest that you measure L+R on those graphs and then interference might also make great difference with minimal mic displacement.
Under 4kHz there is really a very minor difference in mic sensitivity on the direction, but with higher frequencies it is much less sensitive for sound coming from 90 degree, so when measuring at 0 degree we measuring direct sound mostly on those frequencies, but when pointing it to the ceiling reflections have much more weight over the direct sound than when measured at 0 degrees, and so is the difference in measurements in real rooms even when proper calibration files applied.
IgorZep is online now
post #378 of 21161 Old 01-16-2013, 08:07 AM
cdnbum88's Avatar
I thought Jason noted the DSP mic could also be sent to get calibrated by someone? Could they have it calibrated for all 3 options? Again, I thought in general the pointing to the ceiling is what we wanted like Audyssey, so the DSP would be fine would it not? It comes with the 90 degree file.
cdnbum88 is online now
post #379 of 21161 Old 01-16-2013, 08:16 AM
Liked: 3489
I believe you are correct--the Mini-DSP mic could be sent to Cross-Labs for calibration, but this involves an additional expense and delay. And, IIRC, the Mini-DSP comes with a zero-degree calibration file, which is why we are having this discussion in the first place.
post #380 of 21161 Old 01-16-2013, 08:23 AM
Liked: 3489
Igor, when I changed the orientation of my mic, I re-measured to make sure the tip of the mic was still at ear-height and as close to the same spot as when it was oriented vertically. It's certainly possible that there could have been a slight variation, perhaps an inch or so, which could have contributed to some of the variance.
If you re-read my original post, the measurements were taken with only one speaker, not left+right. I still think the tests demonstrate that the best approach to producing accurate and meaningful REW measurements is to orient the mic towards the ceiling, and to use a calibration file that was specifically created for the 90-degree orientation.
post #381 of 21161 Old 01-16-2013, 08:43 AM
kbarnes701's Avatar
Liked: 5067
I agree with you Jerry FWIW. It is nice to be able to isolate all 7 channels in a 7.1 system but I can't see a lot of value in measuring the surrounds independently. I am open to persuasion otherwise, but currently I would be happy with measuring just the mains and the subs. This is what I have done with my OM and it seems to have yielded good results so far.
post #382 of 21161 Old 01-16-2013, 08:47 AM
kbarnes701's Avatar
Liked: 5067
You can have the mic calibrated individually but I have no idea what that would cost. Seems pointless to me when you can get an already individually calibrated mic for the same sort of money. The mic that Feri and Jerry and I were discussing is only calibrated for 0 degrees AIUI, which means when it is used normally (pointed to the ceiling) it will have to be used uncalibrated. How much difference that makes is currently under discussion between Jerry and Igor. I take Igor's point that the room effects may well have more importance than minor calibration differences, but it still seems to me that as it is just as easy to use a fully calibrated mic, then I might as well.
post #383 of 21161 Old 01-16-2013, 08:53 AM
mogorf's Avatar
Liked: 600
Gyus, my point is that once you have at least one known calibration file (like 0 degree for the UMIK-1) for your mic then it's possible to generate another calibration file (like 90 degrees) from it and load it into REW. I'll come back later this evening to expand on my (brave) idea with a lot of reasonings. Stay tuned, please! smile.gif
post #384 of 21161 Old 01-16-2013, 09:12 AM
kbarnes701's Avatar
Liked: 5067
I would be interested in hearing you on this, Feri. I thought the idea of calibrating a mic was to calibrate it against a known reference instrument and to create a correction file for it where it is shown to deviate from the FR of the reference instrument. I can't quite see how you can calibrate the mic for vertical orientation unless you have a known reference mic to compare it with. But I am all ears...
But the real question is, is it all worth it?  The properly calibrated mic from CSL is more or less the same price as the partially calibrated UMIK-1 - so why not just get the UMM-6 from CSL and be done with it?
The very minor benefit of the UMIK-1 being PnP is irrelevant IMO - anyone who can master the rest of REW will surely be able to perform the one additional step required when using the UMM-6.
post #385 of 21161 Old 01-16-2013, 10:48 AM
cdnbum88's Avatar
The reason I noted my question was that I already have the mini dsp one now. I hope I did not jump the gun, but I think the differences would be minor and again with WAF, not sure what options I will have anyway once I produce some graphs and you all say, David, you 'should' move your sub 3 inches to left smile.gif
post #386 of 21161 Old 01-16-2013, 11:29 AM
kbarnes701's Avatar
Liked: 5067
..... and "David, you do realise you need 12 bass traps and half a dozen diffusors in that space, don't you?"  :)
post #387 of 21161 Old 01-16-2013, 12:05 PM
Liked: 3489
David, I don't think it will make a huge difference for you.  IIWY, I would still point the mic at the ceiling, and I would use whatever calibration file that came with the mic.
post #388 of 21161 Old 01-16-2013, 12:58 PM
cdnbum88's Avatar
Keith - Yes I wish I could add all that good stuff. Who knows maybe some day. I just need to get running the graphs to post for you guys to look at and offer up what things I may or may not be able to try.
AustinJerry - the plan was to point up, so I think I am good with that, as noted, I just need some quiet time without wife and kids to do some at least some single position runs for all the speakers.
post #389 of 21161 Old 01-16-2013, 02:24 PM
IgorZep's Avatar
Quoted: 386 Post(s)
Liked: 185
I fully agree with you, just wanted to ensure as I've had different experience with variance of mid-frequency range. Although I have ECM8000, not EMM6. They should be quite similar, but still there might be some difference coming from that as well.
post #390 of 21161 Old 01-16-2013, 02:31 PM
IgorZep's Avatar
Quoted: 386 Post(s)
Liked: 185
Yes, I believe it should be possible with quite a good precision. The most of the difference in 90 degree and 0 degree performance is from the shape of the mic, I believe, so if you apply the difference from one mic to another it should be pretty good already. Not as precise as a separate calibration, but order of magnitude better than just taking generic profile for the mic.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
