Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 2223Likes
post #421 of 23449 Old 01-17-2013, 10:34 PM
batpig's Avatar
Quoted: 3695 Post(s)
Liked: 3548
Originally Posted by AustinJerry View Post
I am the messenger here, so there is no cause to get upset.
Not at all upset with you. Just annoyed that this is getting more complicated than I was led to believe. I went from having a simple answer that no additional equipment would be needed beyond the USB mic, and I could use standard analog audio output to generate the test tones, to your response, thus it feels like it's going backwards.
As I understood it, the audio output portion (HDMI vs. whatever) was secondary; the initial impetus was about the INPUT portion, i.e. the USB mic obviating the need for additional gear (external soundcard, phantom power, etc). The HDMI output aspect was secondary "gravy" for people who were fascinated by the idea of being able to ping each channel individually. But when jevansoh originally introduced the topic it was not limited in scope to the HDMI output option; the specific form of signal generation wasn't really relevant. I don't know at what point the two merged but when it was initially discussed in the Audyssey thread the two were NOT linked.
I don't know where you got the idea that you would be able to use your laptop's audio if your laptop has no HDMI port.
Not sure, but maybe it was the part where Jason explicitly said that was the case when this was initially being pitched in the Audyssey thread?
Originally Posted by jevansoh View Post
Here's some more info for everyone.
While it is true that REW generates the signal internally, meaning you will have to hook your computer/laptop up to any available stereo input on your AVR, you will not need to use an external CD/DVD Player and CD/(DVD??) like you do with Omnimic/RTZ so that pretty much cancels each other out as far as I'm concerned.
There are no other "black boxes" needed. You will NOT need a full duplex sound card because you aren't using the sound card's mic input and speaker/line output at the same time, as you'll be using the USB Mic. So the built-in sound card that every PC/Laptop has works fine. (Using it this way myself on a cheap laptop)
Yes, the output/jack on the sound card is 1/8" stereo mini and Yes, the input on the AVR is RCA, but that is taken care of by a $3.00 1/8" to RCA Splitter/Y-Adapter that I bet most of you already have.
You will NOT need an "external" sound card. I'm SURE your PC/Laptop has a sound card and the one that is built-in is more than adequate if manufactured in the last 10 years or so. Promise! (My business is computer hardware/software, sales and service, in business since 1994, so I'm sure of this)
Yes, the front AUX is exactly what I use. If you want "easy" (actually, every method is very easy, but this is the long-term/in-use tried and true method) and only care about the front 3 channels as far as testing goes, then you can use a simple RCA cable, and 25' or so is fine, but I wouldn't go more than 50' max, and stay as close to 25' as possible.
Monoprice makes great ones and you can do the same for even less. All they do is use standard RG-6 Sat/CATV cable and put some RCA plugs on the end. I make my own for even less, but if you don't want to fool with it and don't need custom lengths, their prices cannot be beat.
You'll simply plug the mic in to your PC/Laptop (Up to 15' standard USB extension cable can be used and if you need longer than that, Monoprice again has wonderful and cheap options for amplified USB cables for much longer lengths) and then from the sound card in the same computer you'll run an RCA cable back into your pre-pro's AUX input.
That's it!
No No no... wink.gif NOT $200. You do not need any external sound card if using a USB Mic because you no longer need full duplex capabilities since you won't be using the sound card for "input" (that will be the USB Mic now) at the same time as "output." The output is all you'll be using on the sound card and I haven't seen a PC/Laptop since about 1997 that doesn't have a built-in sound card, so I'm sure you don't have to purchase anything but the Mic which is less than $100. smile.gif
--J
Originally Posted by kbarnes701 View Post
When you say the 'sound card in the same computer' this would be the audio out connection I assume? This seems to be limited on my machine (from memory) to the headphone out socket - is that what you mean?
Yes, the headphone out is fine. You'll simply plug an RCA cable from that (may need a 1/8" to RCA adapter for a buck or so at Monoprice) into the front AUX on your Onkyo, then plug the Mic into a USB port on the same laptop and that's it! If doing it this way, you won't even need to fool with the ASIO driver because that's just for HDMI and if you want all 8 channels.
So, yeah, I think that was a reasonable inference on my part.
This thread was established to specifically leverage a new capability in REW 5.0 beta 10 that added support for laptops with HDMI and USB mics. AFAIK, nothing has changed with regards to how to do a legacy connection.
Well I guess you missed this exchange.
It's disappointing to me that the scope has narrowed from the original introduction in the Audyssey thread such that it's now exclusionary towards those who don't have the HDMI output option.
Again, I don't understand why the OUTPUT aspect has to be linked with the input side. It's almost certain that I am misunderstanding something, but I though the biggest revelation of the process was the support for PnP (or almost) USB mics making the intro to REW much more accessible. What does it matter how the funny test tone sounds gets from the laptop to the speakers? If the speakers make noise, can't you measure it?
If you read the REW documentation, it states: "Equipment Needed: A soundcard (internal or external) with line inputs and outputs. Note that most PC and laptop mic inputs are NOT suitable and should not be used (they have too much gain and most suffer from high noise levels and limited bandwidth)."
(snip)
A microphone input (mic-in) on a soundcard is not suitable (many laptops only have mic-in).
OK, that's all warning about the mic INPUT portion. That's the part that is now obviated by the USB mic (as I understood it). All I'm talking about is the sound OUTPUT, the signal generation portion.
I'm not trying to be a dick, and I truly don't understand enough about the topic to know where I'm going astray, but I feel like what you are telling me does not jive with what was originally discussed during the genesis of this idea in the Audyssey thread.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #422 of 23449 Old 01-18-2013, 02:52 AM
kbarnes701's Avatar
Quoted: 6818 Post(s)
Liked: 5250
FWIW, BP, I am confused too and, up to this point, thought the same as you did - that if you had the USB mic all you needed were some additional cables - HDMI or RCA as preferred,
kbarnes701 is offline
post #423 of 23449 Old 01-18-2013, 03:20 AM
audioguy's Avatar
Quoted: 2443 Post(s)
Liked: 1600
+2
Our Theater
FS: 2 Pair of Tannoy DI6 - DC Speakers. PERFECT for Atmos duty
"The further a society drifts from truth, the more it will hate those who speak it." George Orwell
Proverbs 9:10
audioguy is online now
post #424 of 23449 Old 01-18-2013, 03:22 AM
mogorf's Avatar
Quoted: 1117 Post(s)
Liked: 714
@batpig:
Excerpts from REW legacy setup page:
"Important notes:
You will require a soundcard with a line-in and a line-out jack.
LAPTOP Note:
If your laptop is limited to a mic-in port with no line-in, then you'll require an external USB soundcard. "
REW Cabling and Connection Basics"
Example of a simple and inexpensive external USB soundcard: Behringer UCA-202
mogorf is online now
post #425 of 23449 Old 01-18-2013, 03:48 AM
kbarnes701's Avatar
Liked: 5250
Originally Posted by mogorf View Post
@batpig:
"Important notes:
LAPTOP Note:
That is for the 'old' REW. The version of REW batpig (and the rest of us in this thread) are using does NOT need a separate soundcard if used with the USB mic. This post from Jason clarifies it:
"There are no other "black boxes" needed. You will NOT need a full duplex sound card because you aren't using the sound card's mic input and speaker/line output at the same time, as you'll be using the USB Mic. So the built-in sound card that every PC/Laptop has works fine. (Using it this way myself on a cheap laptop)
Yes, the output/jack on the sound card is 1/8" stereo mini and Yes, the input on the AVR is RCA, but that is taken care of by a $3.00 1/8" to RCA Splitter/Y-Adapter that I bet most of you already have."
post #426 of 23449 Old 01-18-2013, 04:01 AM
kbarnes701's Avatar
Liked: 5250
I would like to re-raise the issue earlier for those us of without HDMI outputs on our laptop, who will end up using the standard "headphone jack" of the laptop with an analog RCA connection to the AUX IN inputs on the receiver to generate tones for measurement. My earlier question in response to Jason's originally reply has long since been buried in this thread.
To recap: I asked if using a simple male-to-male RCA "y-cable" with a 3.5mm mini jack on one end and two RCA male jacks on the other end would be sufficient (with the understanding that I would only plug in one at a time to individually test FR/FL speakers, both at the same time with PLII Cinema engaged to test the center speaker).
Jason commented that I should instead use an RCA splitter, 3.5mm male to two RCA FEMALE, and then use an RCA male-to-male cable from the splitter to the AUX IN input on the AVR.
I still cannot understand for the life of me how a male>female y-splitter cable, then connected to a male>male cable is any different than simply using one male>male y-cable. Isn't male>famale>male>male the same thing as male>male.... but with one cable instead of two?
It is the same thing. You can use either.
This:
Connnected to two RCA male-male cables .... is exactly the same as this:
... which is, I think, what you asked. All discussion of 'legacy REW' and external soundcards is irrelevant because you will be using the USB mic which uses the laptop's internal soundcard (which is also the point of this thread as you pointed out somewhere). Phew!
post #427 of 23449 Old 01-18-2013, 04:04 AM
kbarnes701's Avatar
Liked: 5250
Not answering your cabling question, but raising a different concern. You cannot run REW in "legacy mode" using the audio in your laptop. You need a separate outboard USB sound card. This sound card would be connected to the AVR using a simple RCA-to-RCA audio cable (the sound card has RCA out, and the AVR has RCA in). Please read the REW cabling basics help file on the REW web site (a link is referenced in the intro in my guide).
I think you answered a question he didn't ask, Jerry. All baptig is asking is how to connect the cable between the laptop headphone jack output and the AVR RCA AUX input. AFAICS, 'legacy' doesn't come into it.
post #428 of 23449 Old 01-18-2013, 05:06 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7441 Post(s)
Liked: 4148
Sorry this has become so frustrating, and that I have added to the confusion. BP, thanks for quoting those posts by Jason--I guess my recollection was flawed. HST, Keith has answered your cabling and connection question. Now all that remains is to get the USB mic, and you should be good to test it out. Without the USB mic's, we are all still in uncharted territory.
AustinJerry is online now
post #429 of 23449 Old 01-18-2013, 05:53 AM
AV_mike's Avatar
Quoted: 111 Post(s)
Liked: 104
Hope I'm not simply repeating what has already been said, but here goes:-
For PC output to AVR input, the PC headphone/speaker jack via any lead that converts 3.5mm to RCA will be fine.
For temporary use of the Audyssey mic, the PC microphone input will be fine.
If you want to use the REW Timing Reference loopback system (to accurately measure time delays/impulses, etc) you will need to feed an AVR pre-amp output back to the PC - but you can't use the microphone input due to its high gain, and DC voltage output (to power the microphone capsule) that's where the external USB sound card come into the equation (they have line level inputs - with no DC voltage output)
Most of the people on the REW forums are using 'proper' microphones that require Phantom power and a pre-amp (similar to Audyssey Pro?) and then the mic pre-amp feeds the line level input of an external soundcard (again NOT the mic input of a PC). The interconnection systems they employ are also configured to provide permanent loopback (hence the adaptor and cable recommendations)
Regards, Mike.
AV_mike is online now
post #430 of 23449 Old 01-18-2013, 06:32 AM
J_Palmer_Cass's Avatar
Quoted: 394 Post(s)
Liked: 118
@batpig:
"Important notes:
LAPTOP Note:
If that works out, then that is the simplified basic REW setup. I have a duplex soundcard in my PC, but I am considering buying the USB microphone due to the simplicity of the hookup.
J_Palmer_Cass is offline
post #431 of 23449 Old 01-18-2013, 06:59 AM
ggsantafe's Avatar
Quoted: 215 Post(s)
Liked: 174
Regards, Mike.
Let me share my experience so far - based on Batpigs initial question regarding using a netbook to take advantage of the new REW USB microphone capability, and the subsequent positive response that it was possible to use a netbook with this configuration, I purchased a used Dell Mini 1010 Netbook with HDMI on eBay, and thanks to Austin Jerry's very helpful step by step directions entered the rabbit hole. To be clear, my only previous measurement experience involved taking Audyssey measurements on my Denon 4311. I am at the point in Jerry's setup manual where you test the REW Timing Reference loopback system - and so far, despite several hours, and assistance from Jerry, I am unable to connect and get a valid measurement. I have loaded REW and ASIO4ALL successfully, and completed all the setup steps in Jerry's setup guide up to the REW Soundcard Calibration (page 34-35) This step requires sending a signal from the Netbook(laptop, etc) via microphone jack/RCA cable to the AVR preout - I continue to get clipping messages indicating that the measurement is invalid. Efforts to reduce/increase the microphone volume have had no impact on the outcome.
So my experience seems to confirm AV Mike's comment that you can't use the microphone input due to it's high gain, and therefore an external soundcard and "proper microphone" is required. I would hope that this is not the case - but my experience seems to indicate that it is. Has anyone successfully configured a netbook/laptop with HDMI capability using Jerry's guidelines? Are there other steps, techniques that are suggested? Any input is appreciated!
ggsantafe is online now
post #432 of 23449 Old 01-18-2013, 07:08 AM
kbarnes701's Avatar
Liked: 5250
:)  You can say that again!  And we're in a sort of limbo now as well, till the mics arrive. You guys will get yours at least a week before I do due to postal delays in getting mine to the UK. I am *very* much looking forward to the posts that will be made in that interval ;)
post #433 of 23449 Old 01-18-2013, 07:11 AM
kbarnes701's Avatar
Liked: 5250
@batpig:
"Important notes:
LAPTOP Note:
It definitely works with HDMI as several of us have tested it already, using any old mic (or in my case my OmniMic USB mic) just as proof of concept. Of course there's no point taking real measurements until we get the proper calibrated USB mics, but it certainly works and is definitely simpler.
post #434 of 23449 Old 01-18-2013, 07:15 AM
kbarnes701's Avatar
Liked: 5250
The author of REW has made a preconfigured setting in the latest beta of REW for the UMIK-1 USB mic and has, AFAIAA, confirmed to Jason that the soundcard calibration can be performed the way Jerry describes. If an external soundcard was needed, then there isn't really any simplification and the purpose of REW 5 beta is negated. HST, I have not tried to calibrate the soundcard following Jerry's instructions as I was waiting for my 'proper' mic to arrive. I will try to do this over the weekend using my OM USB mic as a test instrument and will report back.
post #435 of 23449 Old 01-18-2013, 08:06 AM
batpig's Avatar
Liked: 3548
Thanks Jerry, and again to be clear I was never angry/upset with you. I just became frustrated because I felt like was asking a simple clarification question about step 5 in a process, and then was being told, "sorry, actually you have to go back to step 2!"
Can someone explain then what functionally is lost by not being able to access the Timing Reference loop back functionality? Does that render REW useless or does it just limit what measurements I am able to perform? e.g. maybe I can't test impulse response but I can still do frequency response, waterfall charts, etc. Please spare no effort in keeping it very dumbed down for me as I try to grasp these basics smile.gif
Setup Guide and FAQ
batpig is offline
post #436 of 23449 Old 01-18-2013, 08:10 AM
ggsantafe's Avatar
Quoted: 215 Post(s)
Liked: 174
I have a UMIK-1 on order, and understand that the soundcard calibration will be loaded in REW - hurray! I was under the impression that I could "play" around with REW prior to receiving the UMIK-1, but apparently the limitations of my current microphone configuration will not let that happen. I'll stay tuned, unless any one can suggest any intermediate steps prior to loading the UMIK calibration.
post #437 of 23449 Old 01-18-2013, 08:18 AM
Liked: 4148
I repeat my original statement--we are in uncharted territory until we get our USB mics.  I would not fret about not being able to get the interim solutions working.  If I interpret Jason's posts properly, until a USB mic is connected, you will not be able to use the line out/mic in on a typical laptop for full REW functionality.  ICBW.
post #438 of 23449 Old 01-18-2013, 09:42 AM
kbarnes701's Avatar
Liked: 5250
Hop diggity dawg... would you believe it?  I don't have (or can’t find) the 3.5mm to RCA adapter that I need to do the soundcard calibration test I said I would do this weekend. I have ordered a new one from Amazon but it won’t be here till next week now... darn...
post #439 of 23449 Old 01-18-2013, 10:02 AM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 740
You can pick one up from Radio Shack or Guitar Center near you.
amirm is offline
post #440 of 23449 Old 01-18-2013, 10:04 AM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Don't know that they have those everywhere in merry old England.
Max
djbluemax1 is offline
post #441 of 23449 Old 01-18-2013, 10:18 AM
amirm's Avatar
Liked: 740
Max
Oh, I forgot he is in UK. smile.gif I think they closed all the Radio Shacks that used to be there. I can't stand Curry's but if there one near him, they seem to have something close to get him by: http://www.currys.co.uk/gbuk/logik-3-5mm-mini-jack-to-2-rca-audio-cable-1-5m-07059827-pdt.html
It is a cable and rather short but he may be able to get extenders. And or find the adapter in person as their web site search capability stinks.
amirm is offline
post #442 of 23449 Old 01-18-2013, 11:53 AM
kbarnes701's Avatar
Liked: 5250
Max
True - but the main reason is that the country is now paralysed as a result of a few inches of snow. Roads are blocked, airports closed, trains cancelled. UK infrastructure spending is very low and the result is third-world levels of public services. /[rant]  Not to mention I live miles from anywhere in the middle of open countryside.
So hopefully Amazon will deliver one to my door and I will be able to do the test next week.
post #443 of 23449 Old 01-18-2013, 02:02 PM
Liked: 4148
I have seen several notes regarding the cable/plug to convert the stereo mini-jack to dual RCA connectors. However, I haven't seen anyone mention what is required at the other end of the connection.
Keep I mind that REW outputs a mono signal. So, on one end of the connection between the laptop and the AVR is the stereo mini-plug to RCA converter that we have been discussing. To this, you need to connect a single RCA cable of the appropriate length to reach the AVR. On the AVR-end of this cable, you will need a simple RCA Y-cable, which you will use to route the mono signal from REW to both the left and right RCA AUX inputs on the AVR. IOW, don't forget the Y-cable.
post #444 of 23449 Old 01-18-2013, 02:33 PM
batpig's Avatar
Liked: 3548
OK, so now we can route back to my original question which started this discussion:
Isn't the simple male>male 3.5mm to stereo RCA y-cable sufficient?
My understanding was that, with this cable, you plug into the left RCA AUX input to test the left front speaker, the right RCA AUX input to test the right front speaker, and BOTH of the AUX inputs (with PLII Cinema enabled) to test the center channel speaker. Is my understanding correct?
Setup Guide and FAQ
batpig is offline
post #445 of 23449 Old 01-18-2013, 03:08 PM
cadett's Avatar
Quoted: 43 Post(s)
Liked: 102
For the sake of the this thread someone please confirm!!! I would like to know too tongue.gif
cadett is offline
post #446 of 23449 Old 01-18-2013, 03:32 PM
AV_mike's Avatar
Quoted: 111 Post(s)
Liked: 104
Well I've been using the same cable for about a year, treating it as mono. REW input/output 1 is Left. With both RCA plugs connected (left & right), you use the Timing Ref Output to drive the "other" channel.
Regards, mike. (Sorry for lack of detail, sick in bed at present) - where's Jason when you need him?
post #447 of 23449 Old 01-18-2013, 04:11 PM
Liked: 4148
Not quite. If you use the cable above, only the right channel, I.e. the red cable, will carry a signal (recall that REW is a mono signal). So, you would plug the red cable into the right channel input on the AVR to measure the right channel, and move the red cable to the left input on the AVR to test the left channel. However, to test left+right, you need to plug the red cable into a Y-cable, and feed both the left and right AVR channels simultaneously. Setting the AVR to PLII Cinema will combine the left and right signals and output to the center channel.
Does this clear it up?
post #448 of 23449 Old 01-18-2013, 04:16 PM
batpig's Avatar
Liked: 3548
Silly me, the reason it wasn't clicking was that I assumed the mono signal output would be dual-mono, not just isolated to one of the RCAs. Cheers!
Setup Guide and FAQ
batpig is offline
post #449 of 23449 Old 01-18-2013, 04:53 PM
JChin's Avatar
Quoted: 367 Post(s)
Liked: 210
Couldn't you use "Stereo" mode?
JChin is offline
post #450 of 23449 Old 01-18-2013, 05:10 PM
batpig's Avatar
Liked: 3548
Not for the center channel!
In terms of the FR/FL, with a single mono input (i.e. right channel only) the STEREO mode will only play out of the right speaker because there is no signal info in the left channel.
Setup Guide and FAQ
batpig is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
