Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 172 - AVS Forum | Home Theater Discussions And Reviews
 1795Likes
Old 10-11-2013, 10:09 AM
bao01's Avatar
Liked: 24
Also, are there any drawbacks to placing a powerful sub under / near a plasma TV?
B&W 802 Diamond mains, B&W HTM2 Diamond center, B&W 804 Diamond surrounds, Parasound HALO A 51, Krell KAV-300i , Integra DHC-80.3 pre-pro, two JL Audio Fathom f113 subs, Panasonic TC-P65VT50 65" plasma
bao01 is offline
Old 10-11-2013, 10:20 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6747 Post(s)
Liked: 3724
Originally Posted by JasonT35 View Post
Hi all
If I get one of the USB mics mentioned in the help guide, do I need to get a radio shack SPL meter also? Or is the USB mic, mic boom stand, REW software and HDMI cable all I need to start taking measurements?
I am of the opinion that an SPL is an essential tool for anyone involved in this hobby. HST, whether you NEED an SPL depends on the calibration file that you received with the mic. If it has a sensitivity parameter, REW will read the parameter and allow you to bypass the mic calibration step.
How do you know if your file has a sensitivity parameter? Since it is a text file, you can open the file using a text editor, e.g. Notepad in Windows. The first line in the file will contain the word "Sensitivity" with a numerical value. If the file doesn't have this parameter, you will need to calibrate your mic in REW before you can use it. Any SPL meter will do the trick.
AustinJerry is offline
Old 10-11-2013, 10:29 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
when loading the calibration file...you upload the txt file correct? if its sitting in the calibration window...it is loaded? the only reason I ask is because it doesnt show you its loading the parameters...and I wanna make sure the files are loaded into REW
Brian Fineberg is offline
Old 10-11-2013, 10:32 AM
jlpowell84's Avatar
Quoted: 1665 Post(s)
Liked: 731
Originally Posted by kbarnes701 View Post
Did you remember to turn DEQ off?  Are these with Audyssey on or off?
As Jerry says, it is important to be consistent with the parameters because otherwise any comparisons are difficult. Try annotating the graphs when you save them - eg, Aud ON, DEQ Off, 1/6th smoothing, Subs + R + L etc.
One starts at 5Hz and one at 15Hz... that confuses the picture somewhat.
I bet the ringing will look really bad even at 450ms or 600ms.
Ok I will label graphs too and use all the same parameters. I admit I was a bit excited and rushed to get my first ever measurements posted. Keith what is your bottom with Submersives?
I will be consistent from here on out for you all. It really is a great tool and privilege to have all the input and assistance on this thread.
It was all pre audyssey. I realized later I should have run Audyssey and then just toggled on and off. That way my distances and timing would have been right. I will do so this weekend
jlpowell84 is offline
Old 10-11-2013, 10:35 AM
jlpowell84's Avatar
Liked: 731
Oh yea, about the ringing in my waterfall (or what you can see). Is that combatted with room treatments only?
Old 10-11-2013, 10:41 AM
Liked: 3515
dont worry i was doing the exact same thin g...everything rushed due to excitement ...I will redo all of them and post soon smile.gif
Old 10-11-2013, 10:53 AM
jlpowell84's Avatar
Liked: 731
Nice! Just got confirmation my Open DRC-AN from mini dsp will be here today! That's 2 day shipping from Hong Kong!
Now I get get some shelf filters in there if needed! Plus any single frequency boost or cut!
Here it is
Old 10-11-2013, 10:55 AM
Liked: 3724
In REW, "loading the calibration file" simply means that you have specified the name and location of the calibration file on the Mic/Meter tab of the Preferences screen.
Old 10-11-2013, 11:08 AM
Liked: 3515
ok perfect...then it was "loaded" smile.gif thanks!
Old 10-11-2013, 11:10 AM
Liked: 3724
Optimizing bass consists of several steps:
- Finding the best placement for the subs
- Optimizing phase with the mains (the so-called distance tweak)
- Treating the room to reduce ringing
Of these, the last step can be the most demanding. The initial assessment of bass ringing is, of course, the waterfall. As mentioned in the Guide, your objective should be to reduce resonances below the noise floor (~40dB) within 450ms (300ms would be really excellent, 450ms is not too shabby).
Resonances are controlled, for the most part, by bass treatments. Treatments can be DIY, or purchased from a number of reputable companies like GIK Acoustics, RealTraps, ATS Acoustics, etc. Number of treatments and placement are part of an iterative process that involves mounting the treatments, taking new measurements, and enduring strange looks from the Significant Other, if that applies in your case. wink.gif
Over the last several years, I have added more and more treatments, and am now at sixteen 4'x2' 4-inch wall panels, with no room on the walls for any more. My resonances are at or below the noise floor within 450ms, but I fear the 300ms level is unattainable for me.
Old 10-11-2013, 11:29 AM
jlpowell84's Avatar
Liked: 731
I see, I may flip the Submersives over (easy to slide) and get some measurements and impressions. I am curious what behind the couch near field would be like smile.gif
I plan on 5 AST 4 inch panels and bass traps for the right front and right rear corners. The left side is open to the kitchen and dining area. Also the right rear has an AC on the top half so I will only be able to put a 4 ft one in that corner. Actually I could put another little 2 ft one up top.
Old 10-11-2013, 11:31 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
One thing I might add (particularly in jlpowell84's situation where he has a bunch of new goodies to improve his SQ) is not to underestimate the importance of step one - finding the best placement for the subs prior to any EQ.  I know your excited to run Audyssey and get your Open DRC-AN in the chain but I think most would agree that you'd be doing yourself a dis-service by not spending enough time finding the best location to start from.  It has been shown time and again that the bettter the starting point the better the results.  Have fun...exciting (at least that's what we like to call it down here in the rabbit hole) times are ahead!  Good luck!
kbarnes701 likes this.
jkasanic is offline
Old 10-11-2013, 11:39 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Disclaimer:  My room is STILL untreated.  HST, I would try to go into your room treatment plan with no preconceived notions about what treatments you might use/need.  The REW measurements should be your guide to applying treatments to address your specific issues.  Of course, I think there are some basic treatment ideas (e.g. first reflection points) that might apply universally but keep your options open until you have time to evaluate your "bare" room response.  I'm in my 8th month of "evaluation" so maybe not the best example! :p
jkasanic is offline
Old 10-11-2013, 11:49 AM
sdrucker's Avatar
Quoted: 695 Post(s)
Liked: 471
+1: even though I have the UMM-6 mic's calibration file loaded and/or "confirmed" by REW, I always pull out my Radio Shack SPL to verify that what I'm getting from REW is what it's supposed to be. Even though you can bypass the mic calibration step with the cal file loaded, since I've got the SPL meter anyway, it takes no more than a few minutes to do that extra step. Maybe silly, but I feel better in case it turns out that there's an unseen issue with using the calibration file accurately for some reason. Especially since we tend to forget that both REW and ASIO4ALL are essentially beta software...
The SPL's right next to my tape measure in my kit. Jerry has taught us well the value of OCD...smile.gif
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T2, Center, Imagine T Wides and Side Surrounds, Imagine S rear surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 Mk 2 subs (4) - 9.4.4
sdrucker is offline
Old 10-11-2013, 11:52 AM
Liked: 3724
Also important to add that there is a clear distinction between the modal region (below approximately 500Hz) and the spectral region (above 500Hz), and the approach to treatments for these two areas is quite different.  Bass traps placed at the intersection of two or three walls address the modal region, while full-spectrum panels strategically placed at reflection points address the spectral region.  Waterfall is the measurement for the former, the impulse (ETC) is the measurement for the latter.
Saril likes this.
Old 10-11-2013, 12:50 PM
jlpowell84's Avatar
Liked: 731
Yes I will do this first. Basically I have 4 positioning options. I don't have any resistance from her wink.gif. Picture yourself siting in the middle seat of the couch as the MLP 9 ft from the tv. Right now I have one sub on either side of the tv stand. Other options include as follows. 1-Both behind the couch, 2-one up front to the right or left of the tv stand (most likely the right to corner load it) and the other behind the couch, 3-one up in the right confer and the other about six ft down the same wall (could move that placement a few ft either way), 4-I could put one to the left side of the couch and the other in one of the already mentioned places. Now an important note is thank God for the mini dsp because now I have time delay because I only have multi eq XT and no sub eq ht
Old 10-11-2013, 12:56 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
I'm sure you've read enough by now to know that a couple good starting points on dual sub placement is 1/4 and 3/4 points of screen wall, mid wall on adjacent walls and mid wall on opposing walls.  Sounds like the 1/4 and 3/4 might be a good starting point.  Not sure how much benefit you would see from colocatng behind the couch but that's why we have mics and REW to measure! ;)
jkasanic is offline
Old 10-11-2013, 01:20 PM
jlpowell84's Avatar
Liked: 731
I'm sure you've read enough by now to know that a couple good starting points on dual sub placement is 1/4 and 3/4 points of screen wall, mid wall on adjacent walls and mid wall on opposing walls.  Sounds like the 1/4 and 3/4 might be a good starting point.  Not sure how much benefit you would see from colocatng behind the couch but that's why we have mics and REW to measure! wink.gif
Well that's basically where they are now.
And we got this graph, although I realized after that the distance setting was not corrected after I moved
Old 10-11-2013, 01:27 PM
Liked: 3724
"Basically where they are now" is not very precise.  If you are going to try 1/4 and 3/4, which is a very good suggestion, and where I have my two front subs, you need to get out the tape measure and position them precisely.  Several inches can make a measurable difference in bass response.
And WRT corner placement, this is usually one of the worst spots because it excites all the room modes, which is normally a bad thing.
Old 10-11-2013, 02:06 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Just a couple of things to add.
1) yes, I've tended to do measurements from 5Hz to 20kHz because I wanted to see how deep the SubM HPs could dig in my room.
2) DON'T turn the SubMs on their side to slide them around. Even a small grain of sand/dirt will scratch them up. Get furniture sliders. They're super cheap (compared to a SubM) and you can even get them at 4a.m. from a 24-hr Walmart.
Max
djbluemax1 is offline
Old 10-11-2013, 02:15 PM
sdurani's Avatar
Quoted: 4557 Post(s)
Liked: 2967
That would be my 1st choice.
BTW, is that an open passageway on the left side of your room? Also, do you have a similar pic of the back half of your room (to show the couch in relation to the side walls)?
Sanjay
sdurani is offline
Old 10-11-2013, 02:18 PM
jlpowell84's Avatar
Liked: 731
Ok, I will measure. It "looks," like they are close to 1/4 and 3/4. I can shift if needed. I. Was planning on building my own tv stand to make a home for a 212 Noesis center channel and hold my 100lb 7 channel amp as well as my other gear. Like I said I will measure and get as close as possible but I don't think I will have to move very much.
So let me ask, how does the left side of my front wall being open come into play?
Old 10-11-2013, 02:23 PM
jlpowell84's Avatar
Liked: 731
Max
You made me laugh out loud with the 4 am comment smile.gif. Will do. I've heard Mark has rolled them up the stairs. Top, driver side, bottom, driver side, top, etc.
Old 10-11-2013, 02:34 PM
jlpowell84's Avatar
Liked: 731
I will get complete room pics. Actually I have some before anything was in there I'll load here in a few. I'll get pics of our oversized love seat in relation to the walls. I actually would really like your opinions on that. I have heard you want to stay off the back wall because boundary gain but I have also heard 3/4 is bad for cancellations. I'll get pics and we can collaborate. Thanks guys wink.gif
Old 10-11-2013, 02:36 PM
bao01's Avatar
Liked: 24
Each time you move a sub, are you supposed to update the distance setting in the pre-pro?
I am using "Direct" mode which means no Audyssey but the Integra DHC-80.3 user guide says that spkr distances and levels are used in Direct mode. I am not sure what they are used for in Direct mode. But if you are moving your subs around quite a few feet, maybe you should update prepro distance settings?
thanks
bao01 is offline
Old 10-11-2013, 02:39 PM
jlpowell84's Avatar
Liked: 731
Disclaimer:  My room is STILL untreated.  HST, I would try to go into your room treatment plan with no preconceived notions about what treatments you might use/need.  The REW measurements should be your guide to applying treatments to address your specific issues.  Of course, I think there are some basic treatment ideas (e.g. first reflection points) that might apply universally but keep your options open until you have time to evaluate your "bare" room response.  I'm in my 8th month of "evaluation" so maybe not the best example! tongue.gif
Yes I agree. I want to take a strategic approach and not just hang treatments up anywhere smile.gif
Old 10-11-2013, 02:42 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Max
IIRC, the comments about rolling them up a flight of stairs was with them IN the boxes: a testament to how well packed they are for shipping, AND if someone HAD to do that to move them up a flight of stairs, I'd recommend rolling them on the sides without the drivers. There's not much you can damage on the amp plate the way they're packaged.
Once again though, if someone's spending ~$2500 on a sub after shipping, why wouldn't they just get a $100-$150 handcart to move them? I can understand if Mark showed up to help install them and the owner didn't have one and wasn't physically able to help carry them up the stairs. Mark, knowing how well packed the subs are may have elected to do that to save time/trouble.
When I got my first SubM, I promptly bought a handcart from Lowe's (or Home Depot?), knowing that I'd be moving it on my own (happened to be in Chicago so I picked it up and got to meet Mark). I got the kind that can be configured into a trolley, or locked in a 4-wheeled position at a 45-degree angle. Came in really handy when I got my Focus SEs too as these weigh as much or more than the SubMs, but the boxes are even bigger and more awkward to handle.
Max
Old 10-11-2013, 02:49 PM
Selden Ball's Avatar
Quoted: 3141 Post(s)
Liked: 1539
bao01,
Yes, if you move a sub, you need to rerun Audyssey. That's why you should find the best location first.
The distance values determine the amount of delay applied to each audio channel. This is so that the sound waves arrive at the proper phase (as they are in the original audio tracks) at the primary listening position. The delay distance is determined both by the physical distance between the speakers and the primary listening position plus the delay introduced by any electronics in each channel. Subwoofers often include such an electronic delay.
For the best soundstage, the distance values set for the front main speakers should be identical, and the speakers themselves should both be at exactly the same physical distance from the main listening position.
The individual trim levels determine the relative amplitudes the sounds in each channel will have at the primary listening position. The different trim level values are determined by the speakers' different distances, efficiencies, reflected energy, etc.
Selden
Selden Ball is offline
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
thanks
You need to change the distances to get the correct time delays, otherwise, the sound from the speakers and sound from the subs will arrive at different times.
Since the subs inherently have a delay due to internal circuitry, you can't just use the measured distances. You need to run an Audyssey calibration even if you prefer Direct mode. This will properly measure and set the time delays (as distances) as well as trims for the MLP.
Max
Old 10-11-2013, 02:55 PM
Liked: 3515
Opinion time
Audyssey before or after minidsp is in the chain?
Audyssey was off for measurements. Then i eq'd based on that. Should i go the other route?
1.run audyssey. Take measurements. Eq based on that
2 take measurements. Eq based on that. Run audyssey
Dayton , Dayton Audio , Room Equilizer Wizard Rew
