Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 238 - AVS Forum | Home Theater Discussions And Reviews
 1804Likes
post #7111 of 21831 Old 11-19-2013, 08:51 AM
LastButNotLeast's Avatar
Quoted: 1523 Post(s)
Liked: 1134
BTW, just in case there may be some interest here, a new bass demo disc is available:
post #579
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #7112 of 21831 Old 11-19-2013, 09:08 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
post #579
anyone wanna make me a blu-ray of it? I will pay for your troubles of course!
Brian Fineberg is offline
post #7113 of 21831 Old 11-19-2013, 10:23 AM
sdurani's Avatar
Quoted: 4563 Post(s)
Liked: 2977
Originally Posted by artur9 View Post
On the left speaker moving it back and forth changes the dip from 3k to 8k.
When you say back and forth, do you mean moving the speaker front to back (away and towards the front wall) or do you mean moving the speaker left to right? With SBIR, when you move the speaker away from the wall, the cancellation frequency goes down, not up (3k to 8k). Is the speaker near any other wall (e.g., side wall)?
On the right side all the dips are gone if the speaker is placed 15.5 cm or so from the back wall.
Just to keep our terminology consistent, when you say "back wall" do you mean the wall at the front of the room or back of the room?
Dip came back after I toed in the right a little.
That sounds like it could be the front wall or the side wall, since toe in affects both. BTW, these measurements you're talking about are one speaker at a time, right? Not both speakers together?
I think the true recourse here is 2" acoustic panels behind the speakers?
IF the front wall does turn out to be the source of the cancellation, then 2" panels should absorb enough at 3kHz to take care of it. If you're willing to put absorption on the front wall, I would encourage you to go thicker (4-6 inches) AND cover a large area (at least the spread of your L/R speakers).
Sanjay
sdurani is offline
post #7114 of 21831 Old 11-19-2013, 10:56 AM
artur9's Avatar
Quoted: 559 Post(s)
Liked: 193
Correct, towards the front wall and away from the front wall.
On the left hand side, there is no side wall. There's a half wall about 5 ft away with its end pointing more or less right at the speaker.
On the right hand side, there's a bit of wall lower down at a very shallow angle. That side has the stairwell so then there are spindles there as well and the steps.
Sorry about the switch. By "back wall" I meant the front wall behind the speaker. I should never have said it that way.
Correct, one speaker at a time. Makes me wish I were Mr. Fantastic to better reach the speaker jacks on the amp smile.gif
4-6"? Really? That might not be practical. I was planning on doing the whole front wall in black panels/curtain for light and sound absorbtion. That section of wall is maybe 8-9' wide and just under 8' tall. But the TV and cabinetry are there so I wouldn't even need that much.
artur9 is offline
post #7115 of 21831 Old 11-19-2013, 10:58 AM
artur9's Avatar
Quoted: 559 Post(s)
Liked: 193
Or maybe just to stop measuring:
http://www.avsforum.com/t/1478854/the-science-of-the-room-with-paul-hales
artur9 is offline
post #7116 of 21831 Old 11-19-2013, 11:04 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6775 Post(s)
Liked: 3736
Just curious, does your AVR/amp not have RCA AUX inputs on the front panel?  Having to access connections in the back would add a layer of complexity to REW measurements for sure.
AustinJerry is offline
post #7117 of 21831 Old 11-19-2013, 12:38 PM
JasonT35's Avatar
Quoted: 48 Post(s)
Liked: 54
Originally Posted by kbarnes701 View Post
You absolutely need a mic stand. You don't need the cm01.
Ok is there a special kind of clip I need for the mic stand to hold the UMIK 1?
I was thinking of this http://www.amazon.com/gp/product/B00347A44I/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Will this be ok?
JasonT35 is offline
post #7118 of 21831 Old 11-19-2013, 01:28 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Will this be ok?
You don't need this for the UMIK-1.  See here or picture below:
jkasanic is offline
post #7119 of 21831 Old 11-19-2013, 01:45 PM
sdurani's Avatar
Liked: 2977
Wasn't it Toole that said 'our rooms didn't sound bad until we started measuring them' (or something to that effect).
Sanjay
sdurani is offline
post #7120 of 21831 Old 11-19-2013, 02:29 PM
sdurani's Avatar
Liked: 2977
I'm having trouble visualizing the front of the room based on your descriptions, but at least it explains the inconsistency (why you're only getting the cancellation on one side). The first thing I would do is try to make the front of the room as acoustically symmetrical as possible. I'm going to guess that it will require more treatment than you were expecting to put up.
4-6" so that the absorption is somewhat broadband. If you don't want to go thicker than 2 inches, then consider using denser material (OC705 instead of the typical OC703).
Sanjay
sdurani is offline
post #7121 of 21831 Old 11-19-2013, 02:38 PM
JasonT35's Avatar
Quoted: 48 Post(s)
Liked: 54
Ok so the clip that comes with the umik will fit on the mic boom stand that is recommended in the Audyssey thread?
JasonT35 is offline
post #7122 of 21831 Old 11-19-2013, 03:20 PM
Liked: 1134
Yeah, but what does he know.
:D
post #7123 of 21831 Old 11-19-2013, 03:36 PM
Liked: 3736
And therein lies the rub.
Using the generator function, I am, indeed, getting output only from the center channel.
However, running the sweeps, the left and right are also participating.
Oh, well.
Michael
I stand corrected.  With the AVR in PLII Cinema mode, and when feeding a mono REW sweep to both left and right channels, there is still an audible signal coming from the left and right speakers.  However, in my tests, the left and right signals were down -30dB from the signal coming from the center channel.  So, I claim that with the left and right signal this low, you are still getting a meaningful measurement of the center channel.  Would you agree with this?
post #7124 of 21831 Old 11-19-2013, 03:49 PM
sdrucker's Avatar
Quoted: 702 Post(s)
Liked: 474
IMO there's some truth to that. If you take the risk of measuring, you take the risk of enjoying your system less because the measurement of, say, impulse response or bass decay may challenge your definiton of 'good'. When you see ringing at 600 ms at 50 Hz, it's easy to question whether you got your money's worth. smile.gif
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T2, Center, Imagine T Wides and Side Surrounds, Imagine S rear surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 Mk 2 subs (4) - 9.4.4
sdrucker is offline
post #7125 of 21831 Old 11-19-2013, 05:19 PM
Roger Dressler's Avatar
Quoted: 1530 Post(s)
Liked: 717
What is the difference between the generator and the sweeps? In REW I thought they were the same.
How does "participation" manifest itself?
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #7126 of 21831 Old 11-19-2013, 05:24 PM
Liked: 1134
I'll use an SPL meter tomorrow (too late tonight - watching Monsters U, instead).
But you can have this in the meantime:
post #7127 of 21831 Old 11-19-2013, 06:26 PM
Liked: 3736
What exactly are we looking at? Are we supposed to guess?
post #7128 of 21831 Old 11-19-2013, 07:16 PM
artur9's Avatar
Quoted: 559 Post(s)
Liked: 193
No, no jacks of any kind on the front other than a headphone jack. I was hoping I could do multichannel from my Mac laptop to control the channels but seems that it's too old to do other than 2-channel.
I'm going to try turning speakers off in the prepro to see if that works.
artur9 is offline
post #7129 of 21831 Old 11-19-2013, 08:24 PM
Liked: 1134
Just doing what I was asked. Top line is left and right speakers, bottom line is PLII Movie, which is supposed to be center channel only but isn't. My whole point is that it seems to mess up the FR; I thought we were trying to figure out why. At least confirmation that another system also produces sound left/right (when my understanding until now was that there shouldn't be any) in PLII mode makes me feel better.
Since everything looks good (not shown here) in Extended Surround (which, I think, sends the same mono signal to all speakers), I'm not worried about it.
post #7130 of 21831 Old 11-19-2013, 08:47 PM
Liked: 1134
So why don't you post your extended surround (not sure what that means) measurements?
Sure, sleep is overrated, anyway. ;)
From the manual: "Ext. Stereo - Gives multichannel sound to a stereo source, using all of your speakers."
post #7131 of 21831 Old 11-20-2013, 12:42 AM
markus767's Avatar
Quoted: 3737 Post(s)
Liked: 1338
There's a some truth in that but if we know our goals then measuring is a prerequisite to reaching them. The problem is to define a meaningful goal. On the one hand there are no meaningful standards and on the other there's a lack of psychoacoustic research when it comes to perception of multichannel recordings in acoustically small rooms.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #7132 of 21831 Old 11-20-2013, 12:52 AM
markus767's Avatar
Liked: 1338
Did you adjust the center width setting?
Markus
post #7133 of 21831 Old 11-20-2013, 04:10 AM
artur9's Avatar
Quoted: 559 Post(s)
Liked: 193
Here's a photo of the front from another forum. You can see the staircase on the right hand side that angles out.
And a model of the room. Since this was done I've moved the one sub to the other end of the sofa, behind the MLP.
The MLP is the end of the sofa next to the easy chair.
The polygon in the middle is a stairwell with a closet beneath it. I use that closet to keep some of the electronics.
There are 3 subs. One is at the end of the sofa, and the other two are at either end of the entertainment center. I want those two close to the mains for when the sub amp gets replaced/repaired.
artur9 is offline
post #7134 of 21831 Old 11-20-2013, 04:19 AM
markus767's Avatar
Liked: 1338
Looks like a reversed polarity issue.
Markus
post #7135 of 21831 Old 11-20-2013, 05:27 AM
Liked: 1134
Nope.
Tried that. Red line with deep dip at 85.
Even tried turning the center on its side (vertical); green line with dip at 110.
Purple is stereo, gold is ext. stereo.
My solution? DON'T USE PLII.
:D
post #7136 of 21831 Old 11-20-2013, 05:36 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
:D
Well, you might as well unhook your center speaker then. :D  Does it sound as bad as it looks?
jkasanic is offline
post #7137 of 21831 Old 11-20-2013, 05:41 AM
Liked: 1134
No, it sounds great (see "ext. stereo," above; Neo 6: Music looks good, too [but not Neo 6: Movie]).
Which led me to think it might be a processing problem, but I've gotten no response on the SC-1222 thread.
post #7138 of 21831 Old 11-20-2013, 05:47 AM
markus767's Avatar
Liked: 1338
Nope.
That's probably the reason why you see some content in L and R and not just C.
Did you measure preamp outputs to see which signal gets routed where?
Connect your center to the left output and disconnect all other speakers - what does the response for the center speaker look like? The problem might be your center and not PLII.
Markus
post #7139 of 21831 Old 11-20-2013, 05:55 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Nope.
That's a good suggestion.  Take PLII out of the equation altogether and measure the center channel hooked up to the left output in regular stereo mode as Markus suggests.
jkasanic is offline
post #7140 of 21831 Old 11-20-2013, 05:57 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
I meant how bad does PLII sound but nevermind that...just get a raw measurement of the center channel as suggested.
jkasanic is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
