Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 263 - AVS Forum | Home Theater Discussions And Reviews
 2031Likes
post #7861 of 22688 Old 01-10-2014, 09:00 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Originally Posted by artur9 View Post
I shouldn't have mentioned that as it's a distraction from my real question. Can ETC or something else in REW tell me which frequencies are the predominant reflections? If so, how would I go about using it to determine that?
For example, the band limited IR? Do I do a full range sweep then filter in REW or do I need to do something else?
Yes
Band limited IR is covered extensively earlier in this thread.
Do a full range sweep. Then use Ir band limiting with a touch of smoothing to make the graphs more easily read.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #7862 of 22688 Old 01-10-2014, 09:23 AM
Wireless member
pepar's Avatar
Quoted: 1029 Post(s)
Liked: 534
artur9 - I am looking forward to following your progress as I need a refresher course on what I already knew on REW as well as learning about all the stuff I never even scratched the surface on.
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #7863 of 22688 Old 01-10-2014, 12:05 PM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Originally Posted by cfraser View Post
^ I'm not nearly experienced enough to answer specifics. Or generalities lol. Maybe provide a room drawing/photo of subs and trap placement, perhaps Sanjay Durani etc. will help.
I just went back and forth with and without traps (4), making measurements and rearranging subs/traps. Pretty time-consuming. Those more organized and experienced (and being paid...) would have a more sensible workflow. Besides, starting with a blank slate is better, you don't have any attachment to things because of $$ already spent. So measure with and without traps and look at all the different types of graphs. Try to be ruthless in your judgment (I wasn't at first, wastes a lot of time/effort).
Looks like a lot of crap below 35Hz, the hardest to treat. A lot of piling-up in the corners. Your level falls off a lot above 80Hz, I'm guessing that's your bass management XO frequency. You did have both your main speakers on when you took that bass measurement? You need both front L/R and any subs on for sub-300Hz waterfall measurement.
Above 35Hz, to 300Hz, I'd say your waterfall doesn't look too bad at all. Maybe some noise or a mode in the ~60Hz area. I just question the level >~80Hz.
Yes, XO for Mains are set to 80Hz, and yes both mains were on when taking measurement, but I might have left center on as well, so will have to run again.
As for the level about 80Hz, I think the issue was there is a "BUG" in REW that was confusing me, so now I am clear what I need to do.  I will do a bit more setup and run some of the graphs again.
Man, do I have a ton to learn.
toofast68 is offline
post #7864 of 22688 Old 01-10-2014, 03:37 PM
artur9's Avatar
Quoted: 610 Post(s)
Liked: 215
Sorry, I can't find the discussion. Can you help out with a link? It doesn't help that the search engine returns first when I search for ir.
artur9 is online now
post #7865 of 22688 Old 01-10-2014, 03:42 PM
Quoted: 449 Post(s)
Liked: 153
Its starts around page 128
My Room
My Music
Jenzen Next
post #7866 of 22688 Old 01-10-2014, 04:22 PM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
Here is a good guide from @amirm on waterfalls: http://www.whatsbestforum.com/showthread.php?8203-Acoustic-Measurements-Understanding-Time-and-Frequency
Confirms my ramblings a few pages back. Would have been nice to know about this post sooner smile.gif
Audionut11 is offline
post #7867 of 22688 Old 01-10-2014, 04:32 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7095 Post(s)
Liked: 3942
AustinJerry is online now
post #7868 of 22688 Old 01-10-2014, 04:38 PM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
Yeah. It's amazing what can be earned when you're not blinded by misconceptions sprouted by others!
Read between the
post #7869 of 22688 Old 01-11-2014, 07:39 AM
KK in CT's Avatar
Quoted: 91 Post(s)
Liked: 61
Hi everyone. I'm in the process of getting everything I need to start down the REW measurement rabbit hole. My wife was nice enough to take my strong hint and got me a calibrated UMM-6 microphone from Dayton Audio for Christmas. That was my way of getting her buy-in to tolerating all of the activities soon to come out of the measuring process. Anyway, now I need to get a laptop with HDMI. My question is, what are the downsides to using a MacBook vs a Windows based system? I'm trying to determine if I get a cheap Windows based or go with the MacBook that could replace my need for the desktop. Since I'm brand new to measurements I don't want to make a bad decision that would really complicate things for me. I am good with computers if that makes a difference. I appreciate any feedback anyone has on this. Thanks!
LG OLED65E6P | Oppo UDP-203 | Denon X5200W 7.2.4 | Darbee DVP-5000 | Emotiva XPA-3 | Sony PS4 | Xfinity X1
KK in CT is offline
post #7870 of 22688 Old 01-11-2014, 08:05 AM
artur9's Avatar
Quoted: 610 Post(s)
Liked: 215
Several of us use Macs but this thread supports Windows better. Get the guide by following the link in AustinJerry's post. That'll give you an indication of what you'll need to do.
post #7871 of 22688 Old 01-11-2014, 08:44 AM
Wireless member
pepar's Avatar
Liked: 534
Unless you are already in the Mac world (or want to be), save your money and buy a Windows PC. This is advice coming from someone posting from an iPad Mini Retina with an iPhone 5s in my pocket.
Jeff
pepar is offline
post #7872 of 22688 Old 01-11-2014, 08:58 AM
KK in CT's Avatar
Quoted: 91 Post(s)
Liked: 61
Jeff
Thanks that helps. No I don't currently have a Mac - just iPhones and iPads. And from the other reply I got it seems the help will be greater with Windows as most are on that. Thanks to both for your help.
KK in CT is offline
post #7873 of 22688 Old 01-11-2014, 09:40 AM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
I have both a Mac winbook and a Windows 8 PC I could not get it going properly on the Mac when book
Sent from my DROID RAZR HD using Tapatalk
post #7874 of 22688 Old 01-11-2014, 10:00 AM
KK in CT's Avatar
Quoted: 91 Post(s)
Liked: 61
Thanks. I appreciate the feedback. Looks like Windows it is.
KK in CT is offline
post #7875 of 22688 Old 01-11-2014, 10:24 AM
RickD1225's Avatar
Quoted: 16 Post(s)
Liked: 69
I fired up my MoniDsp and REW this morning and for some reason REW won't open an EQ window. It just spins thinking for a min or two and stops. The rest of REW still works. Any ideas?
RickD1225 is offline
post #7876 of 22688 Old 01-11-2014, 10:40 AM
kbarnes701's Avatar
Quoted: 6780 Post(s)
Liked: 5138
Jeff
I am a long time Mac user, but I bought a cheap Windows laptop for use with REW. Sole reason really was the additional support that Windows has in this thread. Jerry's guide has a useful link to a detailed examination of how REW can be used with a Mac, which may be worth looking at.  Once you are configured, there's no real difference between the two platforms, so all you need concern yourself with is getting up and running. In fact, I use Windows to make all my measurements with REW but then transfer them to my Mac for evaluation, manipulation etc etc. Mainly for the 23 inch screen on my desk rather than any real difference in workflow etc.
kbarnes701 is offline
post #7877 of 22688 Old 01-11-2014, 10:55 AM
KK in CT's Avatar
Quoted: 91 Post(s)
Liked: 61
Thanks. So when choosing a cheaper laptop, other than ensuring there is an HDMI port and a USB port, are there any other must haves I should be aware of?
KK in CT is offline
post #7878 of 22688 Old 01-11-2014, 10:58 AM
kbarnes701's Avatar
Liked: 5138
Sorry, I know next to nothing about Windows laptops. I was lucky I guess - mine is the cheapest I could find - it came with Windows 7 and that's about all I know about it - but it works just fine. I also use it for Audyssey Pro and OmniMic which are Windows-only. It's an Asus - that's about all I know about it :)
post #7879 of 22688 Old 01-11-2014, 11:15 AM
sdrucker's Avatar
Quoted: 770 Post(s)
Liked: 527
Jeff
Tell that to anybody under 30. Where I live (an urban area near Northwestern's law and med schools), the only people using Windows laptops are older people and pharma reps. smile.gif We have three iPads, three iPhones, and a MacBook for the teenager, who ignores our Dell laptops as 'boring' and not as fun to use as the iToys. The four month old may grow up never knowing the blue screen of death LOL..
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Video (early May): JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro TBD
Misc.: Oppo 103, Oppo 203 UHD player, JRiver
Speakers: PSB Imagine T3 LCR, Imagine T Wides and Rears, T2 Side Surrounds
PSB Imagine XB Speakers (4), HSU ULS-15 Mk 2 subs (4) - 9.4.4
sdrucker is online now
post #7880 of 22688 Old 01-11-2014, 12:05 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
LMFAO...
jkasanic is offline
post #7881 of 22688 Old 01-11-2014, 01:20 PM
kbarnes701's Avatar
Liked: 5138
Read between the
Am I missing something?  I read all of the article you linked to and the main thing it seems to say is that if you bring down a peak in the FR, you will get a corresponding improvement in the ringing/time domain (waterfall). Isn't this blindingly obvious?
There is also some stuff regarding the noise floor but ever since the inception of this thread, we have been working on the basis of a 40/45dB lower limit as this corresponds to the typical noise floor in our rooms and when following the guidelines of measuring at 80dB, delivers the +35dB which we now regard as good practice (and which can be used as a guide for anyone measuring above 80dB levels).
I admit to not being the biggest fan of amirm, but the article I just read hasn’t done much to convince me I am mistaken in my impressions.
post #7882 of 22688 Old 01-11-2014, 01:30 PM
sdrucker's Avatar
Quoted: 770 Post(s)
Liked: 527
So we're now saying 85 db is OK for waterfalls, with a measured noise floor of 50 db, with at least 35 db above that floor? Or as my preference for accessing bass decay, spectrograms? Fine with me....
post #7883 of 22688 Old 01-11-2014, 01:43 PM
Quoted: 449 Post(s)
Liked: 153
I don't know about the rest of you, but I find myself caught between narrowing my view to the meat and potatoes of things (elimination of early reflections and a fairly flat FR) and chasing down all sorts of theoretical and psychoacoustic data hoping for some new acoustic epiphany.
I spent 3 hours this morning looking over and hunting for some new piece of data or insight. While there was lots of interesting studies and data and such, non of it translated into something I can walk into my sound room and apply.
Perhaps I have reached the near end of the macro Rabbit hole. Perhaps I need to ignore the micro Rabbits.
My Room
My Music
Jenzen Next
post #7884 of 22688 Old 01-11-2014, 01:54 PM
kbarnes701's Avatar
Liked: 5138
Whatever Jerry has in the latest issue of the Guide... but yes, I think that was our recent consensus wasn't it?  Audionut rightly pointed out that there is no point in measuring/graphing into the noise floor, and IIRC 35dB 'clearance' was regarded as enough. I personally measure at 85dB (or more) and use 45dB as my 'bottom' just to be on the safe side.
post #7885 of 22688 Old 01-11-2014, 01:55 PM
kbarnes701's Avatar
Liked: 5138
Time to just sit back with your beverage of choice and enjoy the fruits of your labors?
post #7886 of 22688 Old 01-11-2014, 02:40 PM
Wireless member
pepar's Avatar
Liked: 534
I don't mean to be heretical (for this thread), but HOW DOES IT SOUND? wink.gif
Jeff
pepar is offline
post #7887 of 22688 Old 01-11-2014, 02:46 PM
Wireless member
pepar's Avatar
Liked: 534
As an Apple shareholder, I revel in your family's falling under Jobs' spell.
Jeff
pepar is offline
post #7888 of 22688 Old 01-11-2014, 02:49 PM
sdrucker's Avatar
Quoted: 770 Post(s)
Liked: 527
Thank an iOS that has high consistency across platforms, and the App Store smile.gif.
post #7889 of 22688 Old 01-11-2014, 03:37 PM
Quoted: 449 Post(s)
Liked: 153
Jeff
How does what sound?
My Room
My Music
Jenzen Next
post #7890 of 22688 Old 01-11-2014, 04:27 PM
Wireless member
pepar's Avatar
Liked: 534
Your "sound room."
Jeff
pepar is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
