Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 296 - AVS Forum | Home Theater Discussions And Reviews
 1789Likes
Old 02-21-2014, 06:54 AM
markus767's Avatar
Quoted: 3714 Post(s)
Liked: 1333
Why not ask Parts Express? They sold it so they should know.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old 02-21-2014, 06:55 AM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Funny you asked that...I have an email into them...waiting response...just hoping there was a "faster answer".
toofast68 is offline
Old 02-21-2014, 07:07 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
I'm fairly certain the PE cal file is for 0 degrees BICBW.  Send it to Herb and he'll calibrate all 3 positions for you.  As I recall, there wasn't a HUGE difference between using the 0 and 90 degree cal files when this question came up about 50 pages ago (at 100 posts per page).
jkasanic is offline
Old 02-21-2014, 07:16 AM
markus767's Avatar
Liked: 1333
I'd say the difference at high frequencies is quite significant. Here's my EMM-6:
Markus
Old 02-21-2014, 08:11 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6737 Post(s)
Liked: 3719
http://www.avsforum.com/t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/4920_20#post_23808303
shpitz likes this.
AustinJerry is online now
Old 02-21-2014, 08:17 AM
LastButNotLeast's Avatar
Quoted: 1520 Post(s)
Liked: 1125
Originally Posted by AustinJerry View Post
Bookmark this post so you can answer the question, because it is bound to come up over and over again.....
Psychic?
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
Old 02-21-2014, 08:22 AM
Theresa's Avatar
Liked: 51
Directly at the speaker being tested, I always aim for the area between tweeter and mid-woofer.
Theresa is offline
Old 02-21-2014, 08:25 AM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Ok, but I think you are wrong :eek:
At least according to the experts on this thread....or am I more confused than ever.
Old 02-21-2014, 08:36 AM
Theresa's Avatar
Liked: 51
Mine too is "calibrated" only for on axis so I point it at the speaker being tested.
Theresa is offline
Old 02-21-2014, 08:40 AM
markus767's Avatar
Liked: 1333
For diffuse field measurements (like measurements at the listening position) the mic should be pointed upward. For free field measurements (like measuring a speaker driver) the mic should be pointed at the speaker. That's why different calibration files are needed. If only one calibration file is available then point the mic in the direction the calibration file is valid for.
Markus
Old 02-21-2014, 09:16 AM
Theresa's Avatar
Liked: 51
Depends on what you are trying to measure. I measure my speaker's individual responses to adjust miniDSPs. For room response I use Audyssey XT32 and use it's measurement mic pointed upwards. So it depends whether you are measuring diffuse room response or individual speakers. So we're both right.
Theresa is offline
Old 02-21-2014, 09:30 AM
markus767's Avatar
Liked: 1333
What post are you referring to?
Markus
Old 02-21-2014, 09:59 AM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Sooooooooooooooo confused....if I am trying to use REW to measure (forget every other reason) FR/Waterfall, etc. the GUIDE says point the MIC UP (something I got wrong earlier) no matter HOW MIC is calibrated - that is what I understand now.
Yes ?
Or if my MIC has 0 degree, then I MUST point it toward the "front" for REW type measurements.
Buy the way just verified from Dayton Audio direct this for everyone else benefit...for those who screwed up and bought through parts express.
The UMM-6 USB measurement mic is tested on-axis (zero degrees) for calibration.
Old 02-21-2014, 10:17 AM
markus767's Avatar
Liked: 1333
Point the mic in the direction it is calibrated for.
Markus
Old 02-21-2014, 10:18 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
How do other locations within the listening area look like? Is that graph smoothed?
Black = Left channel - mic at Left ear location
Green = Left channel - mic pointing forward
Orange = Left channel - mic at Right ear location
Red = Right channel - mic at Right ear location
Green = Right channel - mic pointing forward
Gray = Right channel - mic at Left ear location
All measurements with 1/24th oct smoothing and 250ms gate.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
Old 02-21-2014, 10:21 AM
markus767's Avatar
Liked: 1333
Without gating <300Hz? Does your software support exporting IRs?
Markus
Old 02-21-2014, 10:26 AM
Quoted: 449 Post(s)
Liked: 153
Yes, but id have to remeasure everything. You will just have to trust me that removing the gate entirely doesn't change anything in the bass region more than 1db.
Here is an older measurement. (both channels driven, mic pointed forward)
Black = no gate, no smoothing
Red = 250ms gate, 1/24th oct smoothing
My Room
My Music
Jenzen Next
Old 02-21-2014, 10:34 AM
markus767's Avatar
Liked: 1333
What? You can't/didn't save those measurements??
Markus
Old 02-21-2014, 10:36 AM
Quoted: 449 Post(s)
Liked: 153
The software doesnt save IR data unless you ask it to. The graphs are what is saved with whatever parameters you apply. Omnimic works very differently than REW.
edit: Even when you DO ask it to, it only saves one sweep of one short sine wave. It doesnt average several long sine sweeps together over time like REW does. So, the IR data is of limited value.
Omnimic is designed to work in real time. While this has advantages, it has disadvantages also.
My Room
My Music
Jenzen Next
Old 02-21-2014, 10:40 AM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Ok, this this goes against what AustinJerry posted 1540 posts ago :eek:
Not trying to cause trouble, just trying to understand.
Old 02-21-2014, 10:46 AM
Wireless member
pepar's Avatar
Quoted: 946 Post(s)
Liked: 508
The Audyssey mic, consumer or Pro, IS calibrated on the 90° axis, therefore pointing it at the ceiling is the correct orientation. Unless you are measuring a speaker on the ceiling. wink.gif
Mics purchased from Parts Express are calibrated on the 0° axis and need to be pointed AT whatever is being measured. This is unsuitable for some/many measurements being done here on this thread. The same mics, when purchased from Cross Spectrum, have calibration files for 0°, 45° and 90°, so users load the appropriate file for the particular measurement being done.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
Old 02-21-2014, 10:48 AM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Originally Posted by pepar View Post
The Audyssey mic, consumer or Pro, IS calibrated on the 90° axis. Therefore pointing it at the ceiling is the correct orientation.
Ok, so maybe this is why we (or I) am confused.
yes got that for the Audyssey Mic supply with the AVR
I am asking about the USB MIC that I (we) are using to measure FR, etc.
Old 02-21-2014, 10:55 AM
Kelvin1965S's Avatar
Quoted: 266 Post(s)
Liked: 166
Damn...I've been using my UMC-1 mic with it pointing up as I thought it should be the same as my Audyssey mic. I only have one calibration file for it so I'm thinking that I may need to point it towards the speaker(s) next time I do some measurements. redface.gif
I'd just run through a batch of left + sub, centre + sub & right + sub measurements having finally go my matching MK MP150 centre speaker (and spent yesterday installing a special TV lift so that the centre can hide behind the TV when not in use cool.gif). I was mostly just playing around with checking sub distance settings (ended up back at the Audyssey ones anyway) and different crossovers.
I was feeling pretty pleased with the results and that it sounds really good as well, but I've made another 'school boy' error: I ran Audyssey without the TV in place above the centre, so it may make some difference (I've measured with the TV at different heights and there is an impact on the response, so it makes sense to do the Audyssey set up and any fine tuning with the TV fully raised as it will be for 'serious' viewing.
Oh well, here are the results for today anyway. I still need to add stuffing to my home built subs, but the TV lift took longer than I thought so the subs haven't been touched this week while I've been off work. frown.gif
I've shown the left and right (both measured with the subs) and then the centre and left (again both with subs). The centre has a bumpier response between 100-200Hz possibly due to the TV now being above it. The left and right responses seem better than my previous attempts too, so things are getting better. smile.gif
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
Old 02-21-2014, 11:03 AM
Wireless member
pepar's Avatar
Quoted: 946 Post(s)
Liked: 508
pepar is online now
Old 02-21-2014, 11:05 AM
markus767's Avatar
Liked: 1333
Sounds confusing. Maybe it's time to upgrade to REW? Works in real time too and generates plots that are more in line with what we're used to wink.gif
Markus
Old 02-21-2014, 11:06 AM
Quoted: 449 Post(s)
Liked: 153
And mine
My Room
My Music
Jenzen Next
Old 02-21-2014, 11:10 AM
Quoted: 449 Post(s)
Liked: 153
I have REW. And sometimes import into it. I just cant measure with REW (no PC hooked up to main system)
Edit: If there is something specific you want to see, I might be willing to create IR files for you to look at smile.gif
My Room
My Music
Jenzen Next
Old 02-21-2014, 11:20 AM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Ok I will be the bad guy....ALWAYS POINT YOUR MIC AT 90 DEGREES TO MEASURE FR USING REW
Old 02-21-2014, 11:37 AM
Wireless member
pepar's Avatar
Quoted: 946 Post(s)
Liked: 508
AND BE SURE TO LOAD THE 90° CALIBRATION FILE.
shpitz likes this.
pepar is online now
Old 02-21-2014, 12:09 PM
3ll3d00d's Avatar
Quoted: 1576 Post(s)
Liked: 564
For sub + mains integration work it doesn't really matter as the differences occur at high frequencies.
Kelvin1965S likes this.
3ll3d00d is online now
Dayton , Dayton Audio , Room Equilizer Wizard Rew
