Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 1707Likes
post #901 of 21462 Old 02-02-2013, 09:50 AM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 739
Originally Posted by AustinJerry View Post
It is not clear to me how a USB mic would operate properly without the calibration step, so my understanding is that an SPL is required.  Keep in mind that an SPL is a pretty important part of any audiophile's toolkit, and there are many times when you will benefit from having the SPL to take a quick measurement.  It is money well spent.
I am unclear on the need to know the true SPL using REW especially if as you correctly say, we will have other means to set the levels correctly (i.e. SPL meter or AVR's auto-eq system). When looking at something like frequency response, what matters is the relative amplitude of different frequencies. What their absolute value is, is unimportant for that kind of analysis. When someone posts such a graph here, I perform the same relative analysis. Ditto for the hundreds of measurements if not more that I have done with REW.
Am I missing a usage here that you all have discovered?
amirm is offline
post #902 of 21462 Old 02-02-2013, 11:32 AM
Stealth3si's Avatar
Quoted: 32 Post(s)
Dido.
This is a point worth bringing up, since I intend to measure frequency response for finding out what issues I have and how big they are, so I can acoustically treat a room for a smooth response.
5.1 small-room size: 800 ft³+ 54 ft³ corner door space
AVR: Denon 1712
Fronts: Pioneer SP-BS41-LR /Center: Pioneer SP-C21 / Rear: Pioneer SP-BS21-LR
Subwoofer: SVS PC12-NSD
Screen: Samsung UN46EH6070 46" 1080p 3D LED 240 CMR TV
Viewing distance: 7.33 ft
Stealth3si is offline
post #903 of 21462 Old 02-02-2013, 01:11 PM
Theresa's Avatar
Liked: 51
I too see no need for knowing absolute levels under most circumstances and the need for a "cr@ppy" Rat Shack SLM has prevented me from doing much with REW.
Theresa is offline
post #904 of 21462 Old 02-02-2013, 01:57 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Apart from the characteristics of our ears that change FR as a function of level (refer to equal loudness curves), a microphone will always measure FR equally regardless of the strength of the test signal and will render a valid FR curve as long as it is above the noise floor but still does not enter clipping zone causing distortion in amp or speakers or both. Arbitrary level settings will also influence waterfall and spectrogram diagrams making them difficult for evaluation in case test signals are too low. REW does an automatic check-up and gives either a level OK confirmation or a level not-OK warning.
Precisely calibrated levels will become most important when we want to measure the effects of Audyssey's DynamicEQ or THX Loudness Plus, etc.
mogorf is offline
post #905 of 21462 Old 02-02-2013, 02:59 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6493 Post(s)
Liked: 3605
I took the question of the mic calibration step over to the HTS site, and here is the response I received:
"The SPL meter in REW has no idea what mic and sound card you are using and is designed to work with a wide range of devices. In order to be useful it needs a reference point for your particular setup. Of course, if you have a calibrated mic and have entered that calibration file then you've given REW a reference point (at all frequencies in the calibration file) and hence you do not need to provide another."
So, I stand corrected, and this eliminates the requirement for a SPL meter.
AustinJerry is online now
post #906 of 21462 Old 02-02-2013, 03:08 PM
mogorf's Avatar
Liked: 613
Oooops Jerry, I think we need to clarify the difference between level calibration and FR calibration (by way of a cal file), don't we? cool.gif
mogorf is offline
post #907 of 21462 Old 02-02-2013, 03:25 PM
sdrucker's Avatar
Quoted: 677 Post(s)
Liked: 449
Just to clarify, I thought that the SPL tool in REW wasn't sufficient to get an absolute sound level from the UMM-6, even with the calibration file, and an external one (i.e. Radio Shack) was necessary to conduct this accurately? Correct me if I'm wrong, but I thought that was the understanding from Jason?
Also, I just got my UMM-6 mic from Cross Spectrum this afternoon, but was going to pick up the Radio Shack meter before moving forward. And BTW, I successfully got the HDMI connection to work with my Denon 4311 with all eight channels being displayed in REW on a" Denon-AVP" display. The trick wasn't to use Realtek, but the Geoforce Graphics card that came with my Dell (i.e. enable the digital audio on that device in Windows 7) to control HDMI.
I did have to download the latest driver for Geoforce and physically switch the display from Intel to Geoforce, and to avoid display resolution issues on my VT50, designate my laptop display as primary for multiple display options.
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T2, Center, Imagine T Wides and Side Surrounds, Imagine S rear surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 subs (4) - 9.4.4
sdrucker is online now
post #908 of 21462 Old 02-02-2013, 03:59 PM
Liked: 3605
Feri, our discussion has nothing to do with the external calibration file, only whether the SPL tool in REW is required to set an absolute level for the mic.  I'm going to conduct some additional tests this evening, because I am still not convinced we understand the issue completely.
@Stuart, could you take a few screen shots describing the steps you took to get your laptop to recognize the Denon?  I am not following it completely.
post #909 of 21462 Old 02-02-2013, 05:34 PM
Liked: 3605
OK, I ran a few tests to try and clarify the requirement for a microphone level calibration.
First of all, it you attempt to run a measurement without having run the microphone level calibration, you get this warning:
To me, this is an indication that it might be a good idea to calibrate.  For testing, I clicked "Continue anyway".
To review, there are several volume controls that affect the measurements.  They are:
- The Windows Audio playback device level (recommended level is 100%)
- The Windows Audio microphone level (ball-park level is 75%)
- The Master Volume on the AVR (no recommended level--it can be anything you want)
So, without calibrating the microphone, I ran several measurements:
The black line is with MV -30, the red line is with MV -15, the green line is is with Windows Audio Recording volume at 25% (instead of 75%), and finally, the blue line is after I calibrated the mic to a level of 80dB.
The point is, depending on where you set the AVR MV, or the Windows Audio levels, the vertical positioning of the measurement line is affected, but not the shape of the measurement itself.  So, Amir is correct in saying that calibrating the microphone volume does not affect the relative measurements.
However, repeatability is important, so once you determine the combination of Windows Audio level settings and AVR MV setting that results in measurements displayed where you want them. remember the settings and use the same ones every time.
post #910 of 21462 Old 02-02-2013, 06:17 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
That's interesting about the SPL not calibrated dialog box.  I'm 99.9% certain I didn't get that message when I ran my measurements with my OM mic.
jkasanic is offline
post #911 of 21462 Old 02-03-2013, 04:42 AM
Theresa's Avatar
Liked: 51
You're right, it does not prompt with that message with OM mic anymore for me either.
Theresa is offline
post #912 of 21462 Old 02-03-2013, 04:44 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5069
I can't see what the fuss is about, personally. It takes a few seconds to do what REW itself tells you to do in that dialog box you captured. Almost all of us have SPL meters, and for those who don't (Theresa ;)) the cost is negligible as a percentage of our total system cost. And, as you have said more than once, a SPL meter is a darned handy tool to own anyway.
So whatever anyone says, anywhere, I will still be taking the few seconds to match REW with my SPL meter - that way I know I cannot possibly go wrong, regardless of which 'theory' is gaining ground on any particular day, from any particular member.
I would commend my method to all :)
kbarnes701 is offline
post #913 of 21462 Old 02-03-2013, 04:51 AM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Originally Posted by djbluemax1 View Post
Although we're aware that for new users, the "Audyssey killed my bass" comment is often due to not being used to flat bass...
You definitely make a good point that people who have never optimized low frequencies in their room can have the impression that the correct bass performance is not right. Whether it is by use of EQ or acoustic products, reduction of resonances (peaks) in the low frequency response will take away low frequency energy and with it, give the impression of less bass. This is especially felt in movies where the reduction in ringing (notes lasting longer than they should) can reduce what one feels in addition to hears. Hopefully they notice the better performance with tighter low frequency notes.
That said, we have to be careful to not take the lead from Audyssey and/or going by our gut feeling that "flat" response is the correct one. It is not perceptually nor based on research in the field.
Think about our everyday lives. We live in closed environments that don't remotely resemble an anechoic chamber. As such, the sounds that we hear are all benefiting from "room gain," i.e. exaggeration of low frequencies. Let's agree that it doesn't get higher fidelity than hearing those sounds as is. Recording them, then taking out the effects of the room gain when we play them by flattening the response will therefore degrade from our memory of what the real sound is like.
Here is a set of published measurements performed on a number of "room eq" systems with the overall double blind subjective listening test results overlaid on them:
image?pagenumber=24&w=800
The dashed black line in the middle is the room response with no EQ. We see the room gain in the form of that peak around 50 Hz. Notice the system in the bottom in teal which did exactly what you said: flat response in bass. Now notice the winning systems at the top. None of them used flat response. They had a tilting curve where the bass output was distinctly higher than the frequencies higher than them. We see clear correlation between doing that and subjective scores and verbal feedback from listeners. This was across 6 listeners and the outcome was consistent across all of them. Here is the break down on per frequency basis:
image?pagenumber=18&w=800
We see that they indeed voted RC6 and RC5 that aimed for flat response as having too little bass. Again these are trained listeners and not newbies.
Net, net, the goal as you use REW to optimize your system should be to get a *smooth* response, not *flat*. We crave more low frequencies than flat response gives us. The more precise way to say what you are saying then is that we like to see a smooth response, not flat.
Stepping up a few levels, we should keep in mind that correlation between acoustic measurements and what we like can range from very good to absolutely dreadful. While low frequency measurements are in the "very good" range of that spectrum, there can be surprises like above.
Again, you made a good point regarding correct bass and hopefully I did not take away from it by expanding the point smile.gif.
Yes, I'm familiar with the Harman curve and tests. It's one of the reasons I've considered XT32 Pro, for the curve editor, but there doesn't appear to be quite enough range in the adjustments. DEQ produces a similar effect, but not quite.
Many untrained listeners though, tend to gravitate towards a house curve with a seriously boosted low end, that far exceeds the Harman Preferred Curve.
Max
djbluemax1 is offline
post #914 of 21462 Old 02-03-2013, 04:57 AM
kbarnes701's Avatar
Liked: 5069
I think that is the best reason of all to perform this simple, one-off, additional step. The relative levels might not be affected but the measurements will be all over the place if the SPL used is different each time and comparing graphs will be made that much more difficult.
post #915 of 21462 Old 02-03-2013, 05:09 AM
localhost127's Avatar
Quoted: 25 Post(s)
Liked: 58
Originally Posted by kbarnes701 View Post
I can't see what the fuss is about, personally. It takes a few seconds to do what REW itself tells you to do in that dialog box you captured. Almost all of us have SPL meters, and for those who don't (Theresa wink.gif) the cost is negligible as a percentage of our total system cost. And, as you have said more than once, a SPL meter is a darned handy tool to own anyway.
you use the SPL meter to set the relative gain of each SOURCE to be consistent across the board; but it does not imply that the SPL is in any way accurate with respect to the ambient noise floor (unless calibrated and often done so with respect to the listening environment).
localhost127 is offline
post #916 of 21462 Old 02-03-2013, 10:27 AM
sdrucker's Avatar
Quoted: 677 Post(s)
Liked: 449
Will do, once I get a project deadline met. Sadly today's a work day until the Super Bowl...
post #917 of 21462 Old 02-03-2013, 11:04 AM
kbarnes701's Avatar
Liked: 5069
Not sure what you are saying LH - are you agreeing with Amirm (!) that there is no purpose in calibrating REW to a given SPL by using an independent meter, or agreeing with me that as it is a trivial step, and one apparently recommended by REW, there is no point in NOT doing it?  Or, of course, a third position which has escaped me (highly possible)?
post #918 of 21462 Old 02-03-2013, 11:30 AM
gibsonpa's Avatar
Thanks AustinJerry for the great doc. I have used REW a few times the over the last year, but with the whole analog output method. With your "how-to" doc, I was able to get my laptop hdmi configured no problem, with 8 channels.
gibsonpa is offline
post #919 of 21462 Old 02-03-2013, 01:06 PM
mogorf's Avatar
Liked: 613
Ok Guys, now that we have clarified that there are two kinds of calibrations involved with REW, namely:
1. Microphone calibration file that takes care of frequency response of the test mic, and
2. System level calibration of REW,
we can discuss how to calibrate #2, i.e. system level.
Open REW:
Click on the icon second from left called "SPL Meter".
You get this:
Please note, I'm doing the screen shots on another PC that is not in my HT living room, so the dB values are only for demo purposes.
Now click on Record (red button on the lower right side):
Then click on "Calibrate" (easy to find) and you immediately get this pop-up panel:
Click OK, then you will see this:
Then all you need to do is set the dB value until it matches the reading on your SLP meter and you're finished:
Let's not confuse "SPL meter", in this case it's not the separate Radio Shack device, but the built-in "SPL meter " of REW.
So, finally, nobody really needs to have a separate RadioShack SPL meter to calibrate REW measurement levels, ...well, ...maybe only Keith, eh? smile.gif
P.s.. Please only argue with me if you have valid points with reasoning. No red herings allowed. LOL
mogorf is offline
post #920 of 21462 Old 02-03-2013, 01:23 PM
kbarnes701's Avatar
Liked: 5069
You're calibrating the mic using the same mic?  I thought the definition of calibrating was that you measured one instrument against a known standard?  What exactly is being calibrated here?  I think I'll stick with the way REW recommends it - I already have the SPL meter so it's no trouble to use it.
post #921 of 21462 Old 02-03-2013, 01:27 PM
mogorf's Avatar
Liked: 613
Try the method described above Keith and compare it to "your way". Report back your findings please.smile.gif
mogorf is offline
post #922 of 21462 Old 02-03-2013, 02:38 PM
Liked: 3605
Sorry, Feri, it doesn't work the way you describe.  The sound level displayed by the REW SPL meter when you press the red record button is dependent on having been calibrated to a known external sound level before it will display a proper value.  Take this test, for example:
- I set the AVR master volume to a value of -14, which on my system produces an 80dB sound level at the MLP (I know this because I have been doing this a long time).
- I launch REW and make sure everything in Preferences is configured properly.
- I then launch the REW SPL, and start the calibration tone.
- The REW SPL meter is reading 63dB, so (according to your instructions) I enter 63dB into the SPL Reading Calibration box and click Finished.
- Now I run the calibration tone again, and this time the SPL reads 63dB.  So, like your say, we have synchronized REW with itself.
- Now, since I know that the test tone is really playing at 80dB, I enter 80dB into the SPL Reading Calibration box, and click finished.
- Now I run the calibration tone a third time, and now the REW SPL shows 80dB.
So, how does the REW SPL show two completely different SPL readings, 63dB and 80dB, when the loudness of the test tone playing through the AVR has stayed the same?  It's because the reading on the SPL is dependent on the mic being calibrated.  Since I knew the tone was really 80dB, and calibrated REW properly, the SPL now reads 80dB, which is correct.
So, my friend, a very nice try, but your method involves circular logic (or circular calibration, as the case may be).  An external SPL is still required for proper calibration.  Thanks for sticking with me on this, Keith.
post #923 of 21462 Old 02-03-2013, 03:00 PM
mogorf's Avatar
Liked: 613
Oh my dear Jerry, if you have the MV on your AVR set to -14 dB you should not get 80 dB SLP at the MLP!!! Altough you did not specify what the input level is in this case! biggrin.gif
0 dB MV setting means you should get a 75 dB SPL at the MLP with a test tone at -30 dBfs. Now, turn it down to -14 dB and you get an SPL at the MLP at 75 -14 = 61 dB, right?
BTW, REW has it's own internal calibrated known sound level, so no need for an external known level source in this case.
mogorf is offline
post #924 of 21462 Old 02-03-2013, 03:27 PM
Liked: 3605
I have no idea what you are talking about, Feri, but you are wrong.  To settle this once and for all, I have received the following response on the HTS Forum from John, the author of REW:
"The UMIK-1 cal file includes a sensitivity figure which REW can use, along with the Windows mic volume setting, to know what the actual SPL in the room is. For other mics the SPL Level Calibration is needed to tell REW how the signal level it sees relates to actual SPL, and that calibration remains valid only if the input path gain remains the same (i.e. input volume setting is not altered, preamp gain not altered if using a preamp)."
Case closed.  You may read the post here:  http://www.hometheatershack.com/forums/rew-forum/65260-using-usb-mics-hdmi-several-questions.html#axzz2JsRELEV1
post #925 of 21462 Old 02-03-2013, 03:34 PM
goneten's Avatar
I apologise in advance if this has already been covered, but has anyone made a step-by-step tutorial on how to get the USB mic to work with REW with little to no hassles?
goneten is offline
post #926 of 21462 Old 02-03-2013, 03:36 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Feri, don't misunderstand this as folks ganging up on you, but boiling this whole issue down to you last sentence about REW having its own calibrated sound level and therefore, not needing an external known level source:
Let's take, for example, system A) setup with Audyssey in a room with 98db/w/m speakers powered by the 100wpc receiver. MLP 10' away. Audyssey set it up with a -30db test tone so it SHOULD read 75db at the MLP. With the speakers sensitivity, the avr can hit THX Reference at the MLP, but you don't know the microphone's sensitivity. You also don't know the soundcard's input sensitivity or range. You don't know what the playback level in Windows was set at, or the input trim/gain.
How can you tell if what REW thinks is being output at 75db actually is being measured at 75db at the MLP? What if the speakers have an 88db/w/m sensitivity and the avr has 100wpc with no Audyssey to even try to calibrate the system to a known Reference?
There's no reference point anywhere in there. That's where using a separate meter allows calibrating to a known value.
Max
post #927 of 21462 Old 02-03-2013, 03:40 PM
kbarnes701's Avatar
Liked: 5069
Jerry beat me to it!
post #928 of 21462 Old 02-03-2013, 03:41 PM
Liked: 3605
Please open the link in my signature.  We will look forward to your feedback.
post #929 of 21462 Old 02-03-2013, 03:42 PM
mogorf's Avatar
Liked: 613
Tell me Jerry, in case of Audyssey setup, how does the Audyssey mic know how to set the speakers trims to reference level? Is there a need for a separate SPL meter or not? I can't remember anything mentioned in the setup guide to this extent! Case not closed, let's discuss till we can come to agreement! Deal?
mogorf is offline
post #930 of 21462 Old 02-03-2013, 03:43 PM
kbarnes701's Avatar
Liked: 5069
I think there are some of the famous red herrings in there Feri. Forget all that - if you take a test tone measurement with a SPL meter and set the AVR so it delivers a reading of 80dB, and then do it the way you suggested, the REW SPL meter will still be wrong and will not read 80dB. Why?  Because it hasn't been calibrated to the known reference level of 80dB.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
