Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 349 - AVS Forum | Home Theater Discussions And Reviews
 2195Likes
post #10441 of 23335 Old 06-16-2014, 07:55 AM
Alan P's Avatar
Quoted: 5032 Post(s)
Liked: 3709
REW is more than accurate for our purposes, and I don't care what fancy equipment KK is using to measure with, he should be able to read an REW FR graph.
And, "designed for corner placement" is pure BS IMO....all subs will benefit (SPL wise) from corner placement. Whether or not it will benefit any specific room can't be known until the sub is measured in said room.
Alan P is online now
post #10442 of 23335 Old 06-16-2014, 07:56 AM
KevinG's Avatar
Quoted: 337 Post(s)
Liked: 163
[quote=Audionut11;25003946]
Originally Posted by KevinG View Post
1) Should I expect these to diminish/go away entirely?
1. Diminish, yes to some extent. When you have signal from a source, the signal radiates in a 360 degree pattern. From the source position to the listening position, there are points around the room, where the signal bounces once, before reaching the listening position. These are the first reflection points.
Sounds waves lose power as they travel through air, and when they bounce. So these first reflection points are important, as they are only secondary (in power level) to the direct line of sight sound waves from the source.
At other points around the room, the sounds waves have had to travel further, and suffer loss from multiple bounces, so they are generally considered less important.
So if you were to sit at the listening position, and have someone clap where a speaker is located, the "ringing" would be reduced well. If you were to stand in some random spot in the room, and clap your own hands, the difference with the panels installed, is probably going to be minor.
Yep, this makes sense. Thanks.
Here's a couple of pics of the progress. I don't want to break out REW until I'm finished... ;-)
Warning, pics are big...can't figure out how to get new forum software to size them for inlining...
KevinG is offline
post #10443 of 23335 Old 06-16-2014, 08:09 AM
Rheagar's Avatar
Originally Posted by AustinJerry View Post
Well, whether it is bad, or too long, it doesn't work. If you can't figure out how to get the PC closer, then Redmere HDMI cables from Monoprice are what I use for long runs.
BTW, assuming you have a spare shorter cable, why don't you try it just to see if it works?
Message recieved. I moved the pc close to the avr and used a known good cable, with no change. I did happen to notice that when I would reboot window the bios and startup screen would show up on my tv(connected to avr) and then it would revert to the pc monitor at the log in screen. This tells me the cables work, its just some setting that I have wrong? My video card is a evga 650ti boost. Could it be an the HDMI driver problem?
Thanks for your suggestions.
Rheagar is offline
post #10444 of 23335 Old 06-16-2014, 08:12 AM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
You should break it out now, to ensure you are expending effort in the places of greatest need. A panel designed for a FRP, placed just outside of a FRP, is useless.
If impressing clueless mates is your thing, well, then maybe they are not so useless.
Audionut11 is offline
post #10445 of 23335 Old 06-16-2014, 08:15 AM
asere's Avatar
Quoted: 1521 Post(s)
Liked: 303
Originally Posted by Alan P View Post
Originally Posted by asere View Post
Ok so I moved the sub from the front middle wall to corner placement.
The first graph is middle wall and second is corner.
Please tell me which one is a better spot.
I personally think the middle wall was better than corner based on the graph or am I wrong?
Question Asere: Did you re-run Audyssey when you moved the sub to the corner? If not, your response definitely may improve with corner placement. When you are trying different placement options, you should measure with Audyssey off so you can get a good comparison. Audyssey EQ'ed your sub for one position and you moved it to another - the Audyssey EQ is no longer valid for the new position.
Ys I did REW with no Audyssey in the corner and then with Audyssey calibrated. The green graph I posted earlier is with Audyssey.
asere is online now
post #10446 of 23335 Old 06-16-2014, 08:19 AM
3ll3d00d's Avatar
Quoted: 1646 Post(s)
Liked: 621
I think, at least so far as I have gleaned from a few comments in various places from people familiar with his subs, KK has the same view as lyngdorf here (re their use of boundary woofers). Leaving aside the SPL boost from corner loading & maximal mode excitement, I believe the theory is that response will decay more consistently over time as the reflection is right on top of the direct wave. I've never seen this effect demonstrated via measurements though for a KK sub.
@asere if you post details of your room layout then you may get some more helpful advice as to how to place the sub to best effect.
3ll3d00d is online now
post #10447 of 23335 Old 06-16-2014, 08:41 AM
KevinG's Avatar
Quoted: 337 Post(s)
Liked: 163
Fair enough, but if the panels are already placed at the observed (using a mirror) FRP, what am I looking for? And, furthermore, does it make any sense to measure a given speaker (let's say front left) when only the left wall has been treated (still to come is the right wall, and the ceiling). Should I take the panel off the wall, measure, put the panel back, measure, and then compare the ETC? Is that the best way to show the results of what I am trying to achieve? I assume this is more about ETC then in is about FR. Right?
Thanks again!
KevinG is offline
post #10448 of 23335 Old 06-16-2014, 09:32 AM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
Your description is consistent with your computer using a screen resolution which is not compatible with the AVR. Most AVRs will pass only the standard home entertainment video resolutions. E.g. 1920x1080, 1280x720, 720x480 & 640x480 or the PAL equivalents for the latter two.
BIOS and startup screens are 640x480, so they're fine. However, if your computer's default screen resolution is, for example, 1366x728, that can't get through.
Most video cards support a second video output which can be set to any resolution, so that might be an option for you.
Selden
Selden Ball is offline
post #10449 of 23335 Old 06-16-2014, 09:49 AM
Alan P's Avatar
Liked: 3709
Hey guys,
I'm looking to get a cheapo laptop for the sole purpose of running REW - I'm sick of stringing analog cables across my living room from my AVR to my PC - will this one get the job done you think?
http://www.newegg.com/Product/Produc...9SIA3SB1F15558
post #10450 of 23335 Old 06-16-2014, 12:14 PM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Hey guys,
I have a 1.3G Celeron that runs REW just fine. That LT will work fine.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #10451 of 23335 Old 06-16-2014, 03:08 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7414 Post(s)
Liked: 4120
Hey guys,
Just make sure it can be returned if it doesn't pass the REW test. 7.1 HDMI support in particular.
AustinJerry is online now
post #10452 of 23335 Old 06-16-2014, 03:16 PM
cfraser's Avatar
Quoted: 128 Post(s)
Liked: 73
Ken Kreisel told me yesterday...[snip] I showed him the REW graphs and he said they are meaningless to him because of how REW measures the room. He uses of course more sophisticated equipment.
Don't know who that KK joker is (I've heard of him), but JIC nobody else says it: ignore him and go to a more informed source. If he really said that. I'm sure I'm speaking for many other people who may have reason to hold their tongue.
cfraser is offline
post #10453 of 23335 Old 06-16-2014, 03:20 PM
Alan P's Avatar
Liked: 3709
Thanks Jerry. Just checked and it's 30 days no questions asked...order placed!
I'm gonna have to read up on REW + HDMI now I guess. Should be a lot easier than what I've been doing though!
post #10454 of 23335 Old 06-16-2014, 03:23 PM
Alan P's Avatar
Liked: 3709
Yes, but did you re-run Audyssey after you moved the sub to the corner, or did you just turn it back on?? It's not clear from your reply.
post #10455 of 23335 Old 06-16-2014, 04:37 PM
asere's Avatar
Liked: 303
Yes I reran Audyssey after I placed it on corner.
asere is online now
post #10456 of 23335 Old 06-16-2014, 07:34 PM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
It's all about the ETC.
Since you're using the mirror method, you should have the locations for the treatments nailed. If you can remove the panels easily, I would do so, so you have a baseline measurement with no treatment.
What makes sense for the measurements, depends on how willing you are to understand the effects the panels have. If you run a measurement now, you can at least confirm your placement of the panels.
The general consensus is to have all unwanted reflections at -20dB as soon as possible in the time domain.
Here is a random ETC from google.
And my own.
I'm a little overboard with my treatments, but you can see in the above graph, there are a few reflections above -20dB.
post #10457 of 23335 Old 06-16-2014, 08:09 PM
steveting99's Avatar
Quoted: 1840 Post(s)
Liked: 638
^ Guys,
Need some advice on the bass. If there was a priority, what's more important; a smooth frequency from 15Hz to 300Hz or having the decay as short as possible below 450ms?
The sub position and the MLP are fixed. There are no room treatments.
When experimenting with the MiniDSP the question was to include pre or post room correction? I'm finding out that when implementing the cuts first in the pre step, then doing the room correction I get a nice frequency response, but the decay is terrible. Checking the spectrogram confirms this. I don't understand what's causing this extended decay...
When doing the room correction first followed by the MiniDSP in the post step, the frequency response is okay but the decay is much better. Looking at the spectorgram confirmed this.
With each experiment, I had a listen to some tunes and watched a few TV shows. I'm liking the post room correction more due to the faster bass decay which makes it sound less boomy.
If anyone has the MiniDSP (or similar device) in the LFE chain, would appreciate your thoughts on the pre and post results.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #10458 of 23335 Old 06-16-2014, 08:22 PM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
FR and decay go hand in hand, although I would probably preference towards decay. There is no point having a flat FR, when you have large levels of decay. Decay isn't visible in the FR, but obviously produces a profound effect on the listening experience.
And similarly the other way also. There is no point generating an excellent decay plot, if it produces a large peak/null in the FR. This also deteriorates the listening experience.
I don't see the point in pre-eq, it's better IMO, to EQ the response in-room.
All things being equal, you can EQ out room modes.
post #10459 of 23335 Old 06-16-2014, 08:29 PM
Liked: 638
Does anyone know how to insert pictures into posts before AVS changed their platform?
Would like to include the spectrograms in my previous post to show what I meant, but when clicking on the insert picture icon, all I get is a URL link...
post #10460 of 23335 Old 06-16-2014, 08:32 PM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
Upload the image to an image host first (I like imgur), and post the direct image link in the url link.
Or use the manage attachments feature, and upload directly from your computer.
post #10461 of 23335 Old 06-17-2014, 03:07 AM
3ll3d00d's Avatar
Liked: 621
try these instructions - How to put an image in a post!
post #10462 of 23335 Old 06-17-2014, 04:07 AM
KevinG's Avatar
Quoted: 337 Post(s)
Liked: 163
Okay. My panels were designed for extremely simple removal/attachment/placement. They are just hanging on french cleats, so it's trivial to take them down and get a measurement before and after.
I'll do that as soon as I can get some time (and have a quiet house). Thanks!
KevinG is offline
post #10463 of 23335 Old 06-17-2014, 09:13 AM
asere's Avatar
Liked: 303
Room Layout
Alan, here is a crappy drawing for now for my room. The sub was in between the components and the window and then I moved it to A corner placement and the REW is still off.
asere is online now
post #10464 of 23335 Old 06-17-2014, 09:44 AM
Alan P's Avatar
Liked: 3709
That helps, but what are the dimensions?
post #10465 of 23335 Old 06-17-2014, 10:21 AM
asere's Avatar
Liked: 303
30x20x9. The ceiling is partially vaulted to I took the highest measurement of 9ft.
asere is online now
post #10466 of 23335 Old 06-17-2014, 11:01 AM
Alan P's Avatar
Liked: 3709
Well asere, that's quite a large room (~5400 cu. ft.) for your dual-opposed 12" drivers - I don't care what Kreisel says (which isn't much...there's precious little info on his subs online). I particularly love this quote from his site; "produces an explosive 3D sound pressure wavefront in the studio or home theater". Wha...??
You may need more woofage....but first, let's get some measurements we can trust. You order that mic boom yet?
post #10467 of 23335 Old 06-17-2014, 11:13 AM
Alan P's Avatar
Liked: 3709
OK asere, I found some specs on your DXD-12012 and they reflect exactly what you're seeing in your graphs as far as the steep rolloff at 30hz goes:
Bass output (CEA-2010A standard)
• Ultra-low bass (20-31.5 Hz) average: 109.8 dB
20 Hz 104.7 dB
25 Hz 110.3 dB
31.5 Hz 112.7 dB L
• Low bass (40-63 Hz) average: 122.5 dB
40 Hz 121.2 dB L
50 Hz 123.1 dB L
63 Hz 123.2 dB L
This sub is down 16.5db from 40hz to 20hz! Not good for movies my friend, you want solid extension down to at least 20hz.
This review points out that it's a very musical sub though, although the reviewer admits that much better can be had for much less.
post #10468 of 23335 Old 06-17-2014, 12:27 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
thanks to AustinJerry for the "push' to spend some time with the REW Room Sim.
The 15 x 28'1" x 8 is about 3.3K ft^3 and with the attached dining room , kitchen and hallways totals about 5K
So working primarily with just the LR spaces, I see where the problems might be and fussing with movement/placement and DSP on the Inuke
The question will be: In the selection of sub type you get either sealed or ported but no "horn", either TH or FLH or anything
So which setting may present the best actual starting point?
there is a fresh REW post of my current effort (sub + mains, xo80, a HPF and 4 PEQ's), posted last night over on the "Submaximus" thread.
I realize "flat" isn't necessarily the "best" for every set-up answer but I'd like to think this a good start toward integration with the mains.
Is my question "sealed or ported" moot?
I'm going to run the YPAO for the system today and break out the REW again.
critiques welcomed
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #10469 of 23335 Old 06-17-2014, 12:35 PM
asere's Avatar
Liked: 303
20 Hz 104.7 dB
25 Hz 110.3 dB
31.5 Hz 112.7 dB L
40 Hz 121.2 dB L
50 Hz 123.1 dB L
63 Hz 123.2 dB L
Thanks for the link on the review. The sub is really clean and offers very tight bass and has the slam for movies even in my 5400cf space. I mean when watching Tron Legacy for example I could feel the couch vibration.
Ken makes them for clean sound not really for higher spls and the 3D pulsar is for multiple subs.
Rolling off at 30hz based on the review and based on what I see with my graphs is disappointing at least on paper.
Here is another review graph for the 12012 and also the complete sub review.
As you can see the sub extends really low on the graph. I think in my case is the room size, mode and maybe better placement that I am still working on. Sounds really nice now like I said but now that I have REW I need to see it roll off much later especially if it is capable from the review.
http://www.hometheatershack.com/foru...er-review.html
asere is online now
post #10470 of 23335 Old 06-17-2014, 12:41 PM
3ll3d00d's Avatar
Liked: 621
All that review shows is room gain, it is a bit of a daft comment from the author to say it extends to 4.5Hz. You may well need 4 of them to get the extension you appear to be after.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
