Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 359 - AVS Forum | Home Theater Discussions And Reviews
 2033Likes
post #10741 of 22697 Old 07-14-2014, 02:14 PM
skipford's Avatar
Quoted: 25 Post(s)
This is the thread to start with REW, and it has 10,741 posts.
I have read many at the beginning and end. What I need is a primer on basic how-to analyse your current audio performance.
I am considering doing this and testing with REW prior to adding ANY acoustical treatments in the room.
Can anybody point me to a thread or post that gives some beginning instruction as to how to tackle this in a DIY perspective; not just "hire some professional to do it" answer?
I really truly appreciate everyone's contribution in this thread.
Kyle
skipford is offline
post #10742 of 22697 Old 07-14-2014, 02:26 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7103 Post(s)
Liked: 3948
Kyle, I can't tell from your post whether you are a already familiar with REW, and are looking for guidance on how to interpret your measurements, or whether you are seeking advice on how to use REW. If it is the latter, then have you looked at the REW beginner's guide? There is a link in my sig. If you are looking for advice on existing measurements, post them here, and you will get plenty of feedback.
AustinJerry is online now
post #10743 of 22697 Old 07-14-2014, 07:24 PM
artur9's Avatar
Quoted: 611 Post(s)
Liked: 215
The acoustical master thread and the DIY movie poster acoustic panel threads helped me the most.
artur9 is offline
post #10744 of 22697 Old 07-25-2014, 11:14 AM
HDgaming42's Avatar
Quoted: 166 Post(s)
Help with nasty null?
I was shocked running REW with my new sub (empty room) to find a nasty nasty null. I've moved both my MLP and sub around to a number of positions and could use some guidance. My room's dimensions aren't THAT far off a recommended ratio--or so I thought.
Is this my room--or my sub? Would love an expert opinion--especially what is happening when I add Roxul in the corners. I would like to keep my MLP as centered (width) as possible for imaging.
Anyhow:
Room is 120" by 196.5" by 88". The room is sealed--double walled--double solid core doors. The "room layout.jpg" below doesn't show the window on the top wall, the door on the bottom wall left, or the closet for the equipment rack on the bottom right. I'm working on it.
Running REW I found the best height for my MLP was around 39" from the floor. Got steadily worse until 50" was abysmal. Moving the MLP forward and backward "move MLP depth.png" I found 64" from the back wall (top green) to be the smoothest. Then weeks later I continued my testing at 74" (38% rule perhaps?) though I'm now not sure why as 64" was superior...
"Move Sub along wall" had me running the sub toward me along the right wall until it was comically close to the MLP--perhaps not doable. It ended up looking the flattest at 64" off the front wall "sub along side wall right".
Fearing this didn't seem a very viable placement I found the flattest response along the front wall placing the sub at about 31.5" off the left wall, and 48-52" into the room "best along front wall".
Finally I temporarily placed 3 bags of Roxul safe n sound in the corners. Front left and right and back left "adding roxul".
Adding the Roxul did some pretty funky stuff from 60Hz upward that I don't understand. I've also included a waterfall comparison "adding roxul waterfall".
Gear:
UMIK-1 with horizontal orientation and calibration file
Onkyo 805 with audyssey disengaged and crossover at 120Hz (highest it will go)
SVS PB-2000 at 75dB, phase at 0, input on LFE
So.....what insight does any of this provide--if any? How close could I get this response to flat without a second sub and just using placement and a miniDSP do you think? Would dual subs in such a small room (damn you ceiling!!!) even be beneficial?
I wish I hadn't blown my budget on a single sub! Doh!
Edit: Apologies in advance--it appears I had my graphs end at 120Hz--not 200Hz as instructed...
Name:	room layout.jpg
ID:	180018   Click image for larger version
Name:	move sub along wall.png
ID:	180026   Click image for larger version
Name:	move mlp depth.png
ID:	180034   Click image for larger version
Name:	best along front wall.png
ID:	180042   Click image for larger version
Name:	adding roxul.png
Name:	adding roxul waterfall.png
ID:	180058   Click image for larger version
Name:	sub on right wall.png
HDgaming42 is offline
post #10745 of 22697 Old 07-25-2014, 06:45 PM
Quoted: 115 Post(s)
Liked: 49
Had Dan AKA SmithandWEsson over my house to run REW on my system. But we got these strange readings with my KEF Q900 fronts taking a nose dive around 2k.
jsil is offline
post #10746 of 22697 Old 07-25-2014, 07:54 PM
Liked: 3948
Who/what is Smithandwesson?
post #10747 of 22697 Old 07-25-2014, 08:11 PM
RayDunzl's Avatar
Quoted: 1229 Post(s)
Liked: 1429
RoomSim
Using your measurements as near as I could guess, to simulate your room, with 1/12 octave smoothing:
I guess "Room".
RoomSim at Sourceforge
There may be better simulators, don't know. Maybe you already have one.
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #10748 of 22697 Old 07-26-2014, 01:00 AM
Quoted: 115 Post(s)
Liked: 49
Hi AustinJerry,
His a forum member and he was showing me how REW works. We ran REW in my room and we got those readings. Need help understanding what is going on.
jsil is offline
post #10749 of 22697 Old 07-26-2014, 05:04 AM
markus767's Avatar
Quoted: 3884 Post(s)
Liked: 1388
Place the sub VERY close to your head behind the listening position, about 1' from your ears. This puts you in the direct field of the sub where SPL is very high compared to what is sent into the room. You'll hear a lot more direct sound and way less detrimental room effects.
The only drawback of this setup is that it's highly listening position dependent.
Yes, if you place them correctly.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #10750 of 22697 Old 07-26-2014, 08:41 AM
HDgaming42's Avatar
Quoted: 166 Post(s)
Originally Posted by RayDunzl View Post
RoomSim
I guess "Room".
Oddly enough, I think I've run every damned calculator under the sun...but a room simulator. Completely ignorant of their existence. Room mode calculators didn't (at least to me) predict this mess as clearly as what RoomSim seems to have done. Thanks for this.
Initially I read that as "one inch". The room is already skirting the outer boundaries of WAF; I think that would be the final straw!
post #10751 of 22697 Old 07-26-2014, 08:54 AM
markus767's Avatar
Liked: 1388
A sub at about shoulder height is probably more WAF friendly then a sub out in the room where it can be seen all the time.
Markus
post #10752 of 22697 Old 07-26-2014, 08:59 AM
markus767's Avatar
Liked: 1388
Your measurements are a good example why I keep telling people to use room simulators ONLY for educational purposes and NOT for planning a real setup.
If you plug dimensions and locations of your room into REW's room simulator then you'll see a very different picture than the actual situation as shown by your measurements. Only in-room measurements tell the truth.
Markus
post #10753 of 22697 Old 07-26-2014, 12:53 PM
HDgaming42's Avatar
Quoted: 166 Post(s)
Can you comment as to why adding Roxul seems to raise up one null slightly, while creating (moving forward?) a new, much deeper null?
post #10754 of 22697 Old 07-26-2014, 02:33 PM
markus767's Avatar
Liked: 1388
There are many modes and changing their contribution will change the room's transfer function at the listening position.
Markus
post #10755 of 22697 Old 07-26-2014, 02:39 PM
RayDunzl's Avatar
Liked: 1429
I notice now that the current 'beta' version of REW includes a shoebox room simulation.
It's probably already been mentioned a hundred times in this thread, but I'm late to the party, and it is a topic at the moment.
RayDunzl is offline
post #10756 of 22697 Old 07-27-2014, 10:04 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
I know you guys are eager for another way to test your system
ASC MATT Test™
http://www.acousticsciences.com/products/matt-test
Actually, this test is pretty easy to run and to interpret, so don't get scared away just yet.
It so happens I have the Stereophile Test Cd 2, so I ripped track 19 to a WAV file using EAC and uploaded it to my dropbox account. Here is the file:
https://dl.dropboxusercontent.com/u/...tereophile.wav
I then opened Omnimic (I am sure you can do the same thing in REW) and watched the FFT (RTA in REW?), paused the screen at various points (around 100hz, 350hz, and 700hz) and snapshoted the image so I could see it clearly. Here is what mine looked like.
Have fun
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #10757 of 22697 Old 07-27-2014, 10:53 AM
markus767's Avatar
Liked: 1388
Thanks Jim but why look at it with an RTA? This file needs to be listened to.
Markus
post #10758 of 22697 Old 07-27-2014, 11:03 AM
Quoted: 449 Post(s)
Liked: 153
Because I wanted to see what kind of swings I was getting as per the following quote from the article:
What does the test tell me?
The MATT test provides two pieces of information: how loud the sound is and how articulate the sound is. The maximum readout on the sound level meter during a tone burst is an indication, in decibels, of how loud your system is at that frequency. The difference in readout between the highest and lowest swing of the needle during a tone burst tells us how articulate the sound is at that frequency. Generally speaking, you can follow the following table to determine how articulate your sound is at various frequencies.
  • 15dB swing - excellent
  • 10dB swing - good
  • 5 dB swing - fair
  • 3 dB swing - poor
  • 1 db swing - bad
My Room
My Music
Jenzen Next
post #10759 of 22697 Old 07-27-2014, 12:53 PM
markus767's Avatar
Liked: 1388
Don't think your FFT is showing what the text describes.
Farina describes a measuring method that is based on bursts in
http://pcfarina.eng.unipr.it/Public/...153-AES110.PDF
http://pcfarina.eng.unipr.it/Public/...177-AES114.PDF
Markus
post #10760 of 22697 Old 07-27-2014, 02:26 PM
Quoted: 449 Post(s)
Liked: 153
http://www.gearslutz.com/board/10292582-post117.html
http://www.gearslutz.com/board/10270472-post115.html
Lets see what Art says.
My Room
My Music
Jenzen Next
post #10761 of 22697 Old 07-27-2014, 03:04 PM
3ll3d00d's Avatar
Quoted: 1630 Post(s)
Liked: 597
What settings did you use in your RTA? It seems like you would need to be quite careful with the windows to make sure you have the temporal resolution you need (possibly even needing a frequency dependent windowing capable RTA, if such a thing exists) to see what is going on. A spectrumlab trace would be quite interesting.
I like the irony in using an fft based system to measure this BTW
3ll3d00d is offline
post #10762 of 22697 Old 07-27-2014, 04:06 PM
Quoted: 449 Post(s)
Liked: 153
In OM, your settings options are more limited. Basically, I choose the fastest (impulse) response with no smoothing or weighting.
My Room
My Music
Jenzen Next
post #10763 of 22697 Old 07-28-2014, 04:36 AM
markus767's Avatar
Liked: 1388
You simply need to record the linked MATT signal at the listening position and compare it to the original waveform. See http://www.acousticsciences.com/matt
Markus
post #10764 of 22697 Old 07-28-2014, 08:05 AM
Alan P's Avatar
Quoted: 4896 Post(s)
Liked: 3532
Anyhow:
Gear:
Hey HD - sorry, I really thought you might get more input in this thread.
Anyways, have you played around with the room sim in REW? That null at 45hz is nasty with those dimensions....have you considered knocking down a wall??
With your MLP at 5'4" from the back wall, I found with the room sim that if you place the sub along one of the side walls 3' from the back wall gives the best response. Give it a shot!
Alan P is offline
post #10765 of 22697 Old 07-28-2014, 09:04 AM
Quoted: 449 Post(s)
Liked: 153
Name:	Matt signal.JPG
Original Matt track
Name:	Matt at LP.JPG
Recorded Matt track at LP
I did this the only way I could think of using the software I have. I used Windows sound recorder to record the played Matt track at the listening position. Then opened each using Izotope RX (the only program I have that analyzes wave form). Not sure this is telling me anything useful or not.
My Room
My Music
Jenzen Next
post #10766 of 22697 Old 07-28-2014, 09:17 AM
Quoted: 449 Post(s)
Liked: 153
I think most of the staff for this thread is on vacation
The only thing I can offer is to continue to experiment and measure. Your right that multiple subs would help as would substantial room bass trapping. Trying to get a single sub to produce a flat response without either of the aforementioned approaches and relying on placement and a DSP only will only get you so far.
My Room
My Music
Jenzen Next
post #10767 of 22697 Old 07-28-2014, 09:52 AM
Quoted: 449 Post(s)
Liked: 153
That is easier said than done. Unfortunately, they dont explain how to graph the results in a comparative and helpful way. Instead, they want you to pay $75 for their analysis
My Room
My Music
Jenzen Next
post #10768 of 22697 Old 07-28-2014, 09:55 AM
Alan P's Avatar
Liked: 3532
Playing with the REW room sim a bit more - looks like either of the rear corners kill the null too.
Alan P is offline
post #10769 of 22697 Old 07-28-2014, 11:35 AM
Liked: 3948
It is not obvious from the room mode calculator that the 45Hz dip is associated with any of the room dimensions.
Moving the sub along the front wall seemed to have zero effect on the null. The single side wall measurement seems to show a slight improvement. Too bad you didn't opt for two reasonably-priced subs instead of one expensive one. If you are interested in my analysis of the benefits of multiple subs, you can read about it here:
AustinJerry's Set-Up
post #10770 of 22697 Old 07-28-2014, 11:46 AM
Alan P's Avatar
Liked: 3532
That's strange Jerry because the REW room sim clearly shows the 45hz dip...unless the sub is located in the back 1/4 of the room.
Alan P is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
