Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 360 - AVS Forum | Home Theater Discussions And Reviews
 1728Likes
Old 07-28-2014, 01:32 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6568 Post(s)
Liked: 3636
I am not familiar with how the room simulator works. However, the formulas in the room mode calculator are simple mathematics, and are accurate.
AustinJerry is offline
Old 07-28-2014, 01:36 PM
markus767's Avatar
Quoted: 3638 Post(s)
Liked: 1297
Originally Posted by jim19611961 View Post
That is easier said than done. Unfortunately, they dont explain how to graph the results in a comparative and helpful way. Instead, they want you to pay $75 for their analysis
Did you listen to the test signal over headphones? How does it compare to how it sounds when played back on your speakers?
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old 07-28-2014, 03:33 PM
3ll3d00d's Avatar
Quoted: 1566 Post(s)
Liked: 544
the room mode calculator just tells you where the modes are, the rew room sim solves for modes and the listening position (and delays etc dialled into each source).
As far as I can see, placing the MLP and the sub at the same distances from each wall (at 1/3 the length) produces that dip at 45Hz. I'm not entirely sure why.
It doesn't look a great room for 1 sub tbh, how big is the listening area? do you have multiple rows of seats? for a single seating position, sitting at 1/5 the distance from the rear wall and a sub in the corner looks about as good as you can expect.
3ll3d00d is online now
Old 07-28-2014, 03:57 PM
Liked: 3636
OK, let's see if he tries that, and what the measurements show. It will be interesting to see how accurate the room simulator is. It should work reasonably well in a rectangular sealed listening room. I have an open floor plan, and such simulators are of no use whatsoever, unfortunately.
Old 07-29-2014, 12:03 AM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
Originally Posted by HDgaming42 View Post
I was shocked running REW with my new sub (empty room) to find a nasty nasty null. I've moved both my MLP and sub around to a number of positions and could use some guidance. My room's dimensions aren't THAT far off a recommended ratio--or so I thought.
Well... room dimensions ratio... My understanding...
A room (enclosed space) is going to have nodes - frequencies that produce standing waves due to reflections. A Cube is usually quoted as the worst, same nodes in all directions, so they reinforce each other. I suppose a sphere would be the ultimate bad room.
The recommended room dimension ratios don't eliminate nodes, but, the nodes for end to end, side to side, floor to ceiling, and the angular reflections, occur at a range of frequencies, not falling on top of each other, not reinforcing each other.
I suppose if the room is bumpy enough it looks smoother, as opposed to one with a few totally black holes in the response.
Close your eyes and see if what you HEAR is as bad as what you think you see when you MEASURE, and go from there.
Musical intruments are not one frequency, they have harmonics and overtones. The ear/brain is adept at filling in the gaps.
I have a big hole at 55hz, and never guessed until I measured it. Didn't notice anything wrong. Now chasing it. That's the hobby.
If you want no nodes, you need an anechoic chamber.
I see the science boys have created the blackest material yet, almost no reflectivity/emission for light. Maybe somebody is working on the same for sound.
https://en.wikipedia.org/wiki/Room_modes
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
Old 07-29-2014, 01:35 AM
markus767's Avatar
Liked: 1297
Already exists, it's called DBA:
Double Bass Array (DBA) - The modern bass concept!
Markus
Old 07-29-2014, 09:14 AM
HDgaming42's Avatar
Quoted: 165 Post(s)
Sadly this is one of the things that drew me to measuring my room. One of my favourite songs features successive piano chords descending the scale (Spoon--Beast and Dragon Adored). Playing it in that room made me want to weep. Some chords simply disappear. Others play too loudly. To hear them butchered like that in direct succession was like a knife to the heart after a $1000 subwoofer purchase!
If I have to fill 90% of this room with Rockwool, or teach myself how to build Helmholtz resonators / Metal Panel Absorbers I'll do it. This was to be my room of solace, and sadly listening to my Grados sounds better...
Originally Posted by markus767 View Post
This is truely fascinating stuff. I can't believe there isn't more talk about this than there is! Here's some amazing results using a SBA: http://www.gearslutz.com/board/bass-...ts-inside.html
HDgaming42 is offline
Old 07-29-2014, 09:33 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
There is not more talk about partly cause few have seen the thread or know of the concept. But secondly, perhaps more importantly, results just as great can be achieved through other, more conventional means. Extensive bass trapping.
Name:	rew r today.jpg
(1/24th oct smoothing)
This is mine. But at least half a dozen other posters here have gotten similar results, also through conventional means.
Mostly, folks with uneven bass don't provide enough bass trapping in their room. As ive seen posted several times, I have never seen a room with too much bass trapping.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
Old 07-29-2014, 09:37 AM
markus767's Avatar
Liked: 1297
I beg to differ. DBA approaches free-field conditions. Passive absorption becomes unpractical when trying to achieve same results.
IgorZep likes this.
Markus
Old 07-29-2014, 09:54 AM
Quoted: 449 Post(s)
Liked: 153
i beg to differ. Dba approaches free-field conditions. Passive absorption becomes unpractical when trying to achieve same results.
Name:	dba vs mine.JPG
The Cyan is mine, the Red is the waterfall from the dba page. I used similar scale and smoothing. I wouldnt say the dba blows me out of the water.
My Room
My Music
Jenzen Next
Old 07-29-2014, 09:59 AM
markus767's Avatar
Liked: 1297
Now compare your room to a DBA setup. That's why I've said "unpractical" Especially when one has concrete walls all around. Very common in Europe. Not such much in the US.
Markus
Old 07-29-2014, 10:08 AM
Quoted: 449 Post(s)
Liked: 153
Are you insinuating my room is unpractical?
True, I wouldn't get the result I am getting in a concrete room.
Even in a concrete room, the room within a room concept would work pretty well I think.
My Room
My Music
Jenzen Next
Old 07-29-2014, 10:54 AM
Liked: 3636
I still think the most impact will be from a second sub. Then additional bass traps. JMO.
Old 07-29-2014, 11:08 AM
Quoted: 449 Post(s)
Liked: 153
Agreed.
But lets consider something else. If your mains are full range speakers, and you don't cross them over, and let their bass extend, you now have two more subwoofers in a sense (that is, two more sources producing in the low bass region).
For those with only one sub, it might be worth trying.
This is basically how my system operates. (2) main speakers run full range (no XO), plus (3) subs. So essentially, I have (5) sources in the bass region.
Name:	My Room 12-07-13 sub locations.jpg
My Room
My Music
Jenzen Next
Old 07-29-2014, 11:40 AM
HDgaming42's Avatar
Quoted: 165 Post(s)
Agreed.
My main front speakers are actually monitors - Mackie HR624mkII. They're what I use 8hrs a day at work, so I'm used to them. They're powered and pretty flat (which is what I wanted). Although your full-range idea would probably work, I don't think that's in my future.
My sub is an SVS PB-2000. The thing is a monster in a room my size (10' x 16'). Finding a home for two of them that doesn't interfere with a) L, C, R b) corner bass trapping or c) rear wall treatment d) my television might be a challenge.
Would I be safe to assume the flattest response would be to place both subs in the middle of the width of the room, front and back? I think that's what I gathered from the HK paper. Four subs is a non-starter.
I have about 3hrs a week to devote to that room, so I am now 1/4 the way toward building bass traps for the front two corners. Doing Roxul safe n sound superchunks with about a 32" face (freestanding units that can stack). Once I get those in I can roll the sub back in and do another sweep before and after to see what that does.
Next up--I'm guessing--will be to treat the back wall. My back corners have a door on one side, and a cubby for an equipment rack on the other, so no easy way to trap those corners unfortunately.
Thanks for the help / advice thus far!
Old 07-29-2014, 11:46 AM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3326
Have you tried the sub in the rear 1/4 of the room (as REWs room sim showed that to produce the flattest response)??
Alan P is online now
Old 07-29-2014, 12:25 PM
HDgaming42's Avatar
Quoted: 165 Post(s)
Not extensively. I'd read that putting your sub behind you isn't really advisable with mains that cross at 80Hz. I know there are conflicted opinions on that. I'm also not sure how accurately REWs room sim fits my room (with a window and cubby for the rack).
I've attached it's prediction of listening position A, and the actual reading. Would you say that prediction is close (I'm not being snarky--I'm genuinely curious).
I've also attached a placement in the back 1/4 that I interpret as much easier to deal with. Is this what you're referring to? A peak at 70dB and 75dB to iron out instead of many nulls?
I should add my ceiling is 88".
Name:	back quarter.PNG
ID:	186050   Click image for larger version
Name:	room simulator position A.PNG
ID:	186066   Click image for larger version
Name:	actual measurement position a.png
Old 07-29-2014, 12:36 PM
3ll3d00d's Avatar
Liked: 544
I would say that it is recognisably the same response, the sim has exaggerated the size/q of the first peak to null but otherwise it looks good.
In my experience, of room sim vs reality in a cuboid room that has some shallow alcoves, the sim accuracy degrades as the mic approves the non linear areas (ie the alcoves). The usefulness therefore varies with the listening position.
Old 07-29-2014, 12:40 PM
Alan P's Avatar
Liked: 3326
80hz is actually where your crossover should be to eliminate localization....you'll be fine with the sub behind you.
I would say that REWs prediction is pretty spot-on to your in-room measurement. That's why I think it would be spot-on for the predicted response with the sub behind you.
Yes, Audyssey will be able to iron out those peaks much easier than it can try to fill in the huge null(s)....give it a go, you got nothing to lose but time!
Old 07-29-2014, 12:43 PM
Alan P's Avatar
Liked: 3326
Seems in your room sim capture that your MLP is in the center of the room, I thought it was 5'4" from the back wall...?
Old 07-29-2014, 12:58 PM
HDgaming42's Avatar
Quoted: 165 Post(s)
It was. The graph didn't look great (what did you come up with?) so I moved the MLP forward until it looked fairly flat (attached with original MLP).
Maybe I don't have the hang of the REW room sim, but applying both the 2 and 4 sub HK models to this simulator doesn't seem to really get me any closer to flat than 1 sub with placement in the back 1/4. What am I missing? (i've tried inverting the opposing subs)
Name:	MLP 5foot4.PNG
Old 07-29-2014, 01:12 PM
Quoted: 449 Post(s)
Liked: 153
Name:	piano keys original DB keys.jpg
In respect to our FR and house curve, I thought id post a variation of something id done before.
Red +4
Orange (Dark) +2
Orange (Light) +0
Yellow -2
Green (light) -4
So about 2db per color change.
Always looking for new ways to look at things.
My Room
My Music
Jenzen Next
Old 07-29-2014, 03:39 PM
HDgaming42's Avatar
Quoted: 165 Post(s)
Is this as true for music as for movies?
I see advice like the following posted around the net...
Once again, the subwoofer should be located near one of the main speakers with it's driver approximately the same distance from your ears as the bass and midrange drivers in the main speakers, so integration is seamless. The attack of bass notes (pluck of bass guitar string and slap of kick drum hammer are in the mid-range frequencies and do not come from the subwoofer. The transient response will be best if all the drivers involved with a bass note are located the same distance from your ears.
Many people will not notice a difference of up to three milliseconds
(approximately three feet).
Old 07-29-2014, 03:42 PM
Alan P's Avatar
Liked: 3326
I just crammed the sub into one or the other back corner and left your MLP at 5'4"...seemed to get the best response in the corner without moving the MLP. If you're willing to move the MLP, that changes things a bit.
When I ran the room sim the response was flatter than the one you show above but not as flat as the one with the MLP in the center of the room. I found that to get a decent response, the sub needed to be at least 2.5' behind the MLP, but it looks like the flattest response is with the MLP dead center in the room....which is usually not good.
You're just gonna have to experiment a bit (with the real thing) I think.
Adding more subs won't necessarily get you flatter, but it will make the response flat over a wider area (less seat-to-seat variance).
Old 07-29-2014, 03:44 PM
Alan P's Avatar
Liked: 3326
That only applies if you have no way to delay your sub signal....you do. It's the sub distance setting in your AVR.
Old 07-29-2014, 04:00 PM
HDgaming42's Avatar
Quoted: 165 Post(s)
It's all up for grabs right now--nothing's in stone. When I get the bass traps done I'll do some more testing, including the sub behind the MLP, and with the MLP being *shudder* center of the room. I'm curious if the prediction will ring true.
I'm selfish in that if I can get a great MLP while sacrificing accuracy for other seats (for people who frankly couldn't care) and save money in the process-sign me up.
Ahh. Wasn't aware of that. Thanks.
Old 07-29-2014, 04:13 PM
Alan P's Avatar
Liked: 3326
Agreed...my wife couldn't care less.
Old 07-29-2014, 04:17 PM
Alan P's Avatar
Liked: 3326
Since you were unaware, there's something else you need to be aware of; after you run Audyssey (you have Audyssey, right?), don't be alarmed if the sub distance in your AVR is (significantly or slightly) different than the actual, physical distance. This is perfectly normal, expected even.
Old 07-29-2014, 05:38 PM
Quoted: 449 Post(s)
Liked: 153
I agree with this quote if ALL the following are true:
1) Your main speakers are satellites (i.e. depend on the subs for extension)
2) Where the mains happen to be provides a relatively smooth bass response for the subs.
3) The satellite to sub integration is good.
It also depends on not only the XO frequency, but the slope of the XO filter.
example 1) a 80hz XO with a 2nd order XO(12db/octave). You may still have significant sub energy above 100hz and into those frequencies where directionality is a concern.
example 2) a 40hz XO with a 4th order XO(24db/octave). In this case, there will be no significant energy from the subs at frequencies where directionality is concerned.
If your somewhere in-between, you might try to find a track with some drum rolls that pan across the soundstage and see if the imagery suffers dependent on sub location.
My Room
My Music
Jenzen Next
Old 07-29-2014, 05:57 PM
Liked: 3636
Not necessarily true, Alan. By carefully placing multiple subs, there can be a measurable flattening of the frequency response, both at the MLP, and over the wider area.
I have provided an example: AustinJerry's Set-Up
Alan P likes this.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
