Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 369 - AVS Forum | Home Theater Discussions And Reviews
 1740Likes
post #11041 of 21630 Old 08-21-2014, 11:50 AM
Zee-man's Avatar
Quoted: 24 Post(s)
Originally Posted by Alan P View Post
I agree, less peaks for Audyssey to pull down = less distortion + more headroom.
UNLESS, location B doesn't give you enough headroom, then you may be forced to use location A.
Also, the scale is wrong on your graphs. Should be 45-105 on the vertical and 15-200 on the horizontal.
Oh, and really no need to measure so loudly. You could pull down the MV 5 or 10db and still be fine.
I'm a noob at this, but I was concerned about the rather large null at 45Hz in the B location (red graph in the first chart in prev post)? If I understand correctly, placement is the best (maybe only) way to get rid of a null and I figured the fewer the nulls the better since the peaks can be fixed through Audyssey.
My bad on the 300 horiz graph.
Here is the "refined" location A graph that shows the subs w/o aud (red) and with aud (blue). it appears that audyssey only pulled down one peak. Is this acceptable, does that alleviate your concerns about my location A?
Oops - just noticed one of the graphs in my prev post was not quite correct. This is the "refined" location A graph with both subs and mains running with aud. The graph in my prev post showed only the left sub with the mains.
I'm having some issues with volumes when measuring. When I hit the CHECK LEVELS button, sometimes it will say the level is too low but when I run the test, I almost run out of headroom. ??? I need to re-read the REW guide to find out what's wrong - likely a setting on my part.
Zee-man is offline
post #11042 of 21630 Old 08-21-2014, 11:57 AM
Zee-man's Avatar
Quoted: 24 Post(s)
Your MDAT file doesn't have any of the Audyssey ON measurements.
I linked two mdat files on my post, you must have only got the first one.
FYI - the first mdat shows subs only w/o aud so I could compare the 3 locations. After that test, I assumed location A was better so I level matched again, ran aud, and measured to create the 2nd mdat named 8-19 location A final. It is the latest and greatest.
Zee-man is offline
post #11043 of 21630 Old 08-21-2014, 11:59 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6621 Post(s)
Liked: 3654
Sorry, Alan, my intention is not to pick on you, but your description of the sub distance tweak is oversimplified. It actually consists of two distinct steps. The first step involves measuring the two subs by themselves, and varying their distances to achieve the flattest response, for the sub channel only. Then measure both subs combined with the center speaker. Adjust the distances of both subs by the same amount in order to achieve the flattest response between the combined subs and the center at the crossover point. The sub distance tweak is not guaranteed to produce significant results (if makes very little difference in my setup, for example), but should always be tried to ensure the best results.
And why do you say that the graph scales are incorrect. We have agreed that the vertical scale should show 5dB increments, which it does, and that the horizontal scale should be 15-300Hz, which it is. I believe this is documented in the Guide.
HST, I agree with both you and Jim that the red graph looks to be the best measurement. Next step woul be to see the effect Audyssey has on placement B so we can make a final comparison.
AustinJerry is online now
post #11044 of 21630 Old 08-21-2014, 12:08 PM
Liked: 3654
There is nowhere in the Guide that says to hit the Check Levels button. Is that the button on the measurements screen? Ignore it, and just make sure your levels aren't high enough to produce clipping.
Zee-man likes this.
post #11045 of 21630 Old 08-21-2014, 12:08 PM
Zee-man's Avatar
Quoted: 24 Post(s)
Here is the mdat for the latest and greatest test which only shows location A, with and w/o aud. This is my much preferred location so I hope the results are decent. This is the 2nd mdat from my prev post.
https://dl.dropboxusercontent.com/u/...A%20Final.mdat
Zee-man is offline
post #11046 of 21630 Old 08-21-2014, 12:10 PM
Alan P's Avatar
Quoted: 4699 Post(s)
Liked: 3329
Feel free to pick on me, Jerry. I don't mind at all.
In my defense, I wasn't aware the OP had an AVR that could calibrate dual subs separately. I also never heard that you should perform the tweak with subs+center....I always read it should be sub+FL/R.
If this indeed is the case, I've been doing it wrong for a really long time. However, it has always produced dramatic results around the crossover point in my system.
RE: graph scale. I obviously need to read the revised guide. Sorry about that. I'm just going by this post from kbarnes, and have been using those settings myself for posting graphs since day one.
Again, sorry if I caused any confusion.
Alan P is online now
post #11047 of 21630 Old 08-21-2014, 12:12 PM
Alan P's Avatar
Liked: 3329
Which mic are you using? Are you calibrating the SPL before taking measurements?
post #11048 of 21630 Old 08-21-2014, 12:15 PM
Alan P's Avatar
Liked: 3329
After just a cursory look at the MDAT....if there's a way you could put both subs in the "R" position, I think you would get a much flatter response.
Is DynEQ off when you are measuring?
Also, don't forget to try the distance tweak (as Jerry described how to do above ).
post #11049 of 21630 Old 08-21-2014, 12:16 PM
Liked: 3654
No harm done, Alan. The time-honored Sub Distance Tweak can be viewed here. I believe KBarnes authored the actual document, but the procedure is really Craig John's and Mark Seaton's.
If the OP doesn't have dual sub channels, then of course the subs should be equidistant, and the procedure needs to be modified accordingly.
Edit: With regards to using the center vs L+R, the reason is that the center is much more important for movie content, so getting the splice correct with the center provides the most benefit. If you then check the splice with the L+R, it is usually optimized as well. If not, stick with optimizing the center+subs.
post #11050 of 21630 Old 08-21-2014, 12:48 PM
Alan P's Avatar
Liked: 3329
Thanks Jerry!
What do you do if the splice with the L/R is NOT good after your optimize the splice with the center? Should you adjust the distance of the L/R speakers?? I'm guessing no.
post #11051 of 21630 Old 08-21-2014, 01:26 PM
Liked: 3654
Never adjust the distances of the main speakers. Any difference is likely to be small, based on my experience. If the difference were significant, then I would let my ears be the judge. Don't know what other options there might be.
post #11052 of 21630 Old 08-21-2014, 07:10 PM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 189
I got another sub at auction and my new UMIK-1 to replace a failed UMM6. I'd also moved 2 of my subs to the front wall in preparation for trying flanking subs with a higher crossover setting.
After taking the below measurements I noticed the little foam cover for the mic. Do I have to use that?
After some fiddling I got the following results. Despite the labels the L+R were on the whole time.
The question I have is this. I did a 15-300Hz sweep that looked good but then when I did a 15-20K Hz sweep it looked terrible. I repeated the bass-only sweep and that looked the same as the red sweep again.
No smoothing, no DSP other than the one parametric setting on the Dayton SA1000 knock-off (which wasn't very effective, BTW).
Green is before any adjustments, red is with everything dialed in, then blue is full frequency sweep. Any idea why the blue looks different from the red?
Name:	umik-1 measures.jpg
artur9 is offline
post #11053 of 21630 Old 08-21-2014, 07:25 PM
Liked: 3654
The part of the measurement below the crossover point should look about the same whether you are measuring to 300Hz, or whether it is a full sweep. May I assume that you are running the mains as "small" with a crossover? What is the crossover value?
The level for the full sweep measurement looks low. Any idea why it would be so much lower?
And the little foam thing can be used or not--it doesn't make a difference. It is acoustically transparent.
Edit: BTW, what do you mean, "dialed in".
post #11054 of 21630 Old 08-21-2014, 07:30 PM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 189
The crossover is set to 120Hz.
That whole blue measurement is strange because I touched nothing other than to change the sweep to 20KHz. Then I changed it back to 300Hz and the measurement was identical to the red line again.
By "dialed in" I meant I was happy with the measurements for now.
artur9 is offline
post #11055 of 21630 Old 08-21-2014, 10:08 PM
Liked: 3654
There shouldn't be any difference. Here is a measurement from my system:
The measurements are essentially identical up to approx. 60Hz, when the influence of the center channel alters the response.
post #11056 of 21630 Old 08-22-2014, 08:56 AM
HDgaming42's Avatar
Quoted: 165 Post(s)
Back for more...
Hi guys,
I finally moved my sub to the back of the room following all the advice I got way back here, and I completed and placed my bass traps. Here are my results.
My Room Sim was unusual as it suggested the most ideal MLP to be in the dead center of the room. This was it's prediction:
My result (didn't save it) didn't look anything like that (even a 1" movement in Room Sim seems to destroy this particular prediction. I found the ideal sub placement and MLP to be with the MLP 105" into the room, center width.
Room Sim's version of this placement:
This is a bit jumbled, but stick with me if you will. Here is a comparison of no treatment (red) to two full height corner bass traps up front (green) with two tweaks*. More on that later.
Waterfalls:
purple instead of red for some reason--but corresponds to the All SPL above it.
After spending nearly a month's worth of "free time" (which wasn't a lot TBH) I guess I was hoping for a flatter response.
Here's what I found interesting and could use some advice on (actually, I'm soliciting all advice on anything you see here!!).
I have a set of double, solid core doors with air-tight gaskets to enter the room. It seems like that is messing with my response!
By opening the interior door I drop a peak by a number of dB, and raise a null. The door cavity is airtight (double wall construction all around). I've read that drilling holes between the doors to provide airflow into the wall cavities can help...but now I can't dig up that advice. I was worried this would short-circuit my soundproofing. Thoughts? Advice? Also of note, my rack's plexiglass door was creating havok, and I removed it to get to the point you see as "best result", no plexi-door and one door open.
Here's where I'm at utilizing best placement, no plexi-glass door and one door open. Also, two 7ft tall bass traps (corner chunk Roxul Safe N Sound) in the front two corners.
Where do I go from here?
Room Sim doesn't seem to be able to come up with a 2nd sub fix for this room. The back wall is problematic as it has those double doors, and a cubby for the equipment rack. There is really only four feet of treatable area on the back wall.
I'm open to all suggestions--really interested in your thoughts on drilling holes (how big, how many?) between the casing of the two double doors. Would love to be able to keep my (expensive!) plexi door for my rack too...
Feeling...defeated.
PS I tested pulling the traps away from the wall (they're free-standing) in 1" increments. I could see no benefit going beyond 1". I went all the way to 8", which was the maximum feasible in my room. My traps are faced with 6mil poly.
Name:	best result spl.png
ID:	223825   Click image for larger version
Name:	compare double doors.png
ID:	223833   Click image for larger version
Name:	room calc of what worked.PNG
ID:	223841   Click image for larger version
Name:	no treatment waterfall.png
ID:	223849   Click image for larger version
Name:	best result waterfall.png
Name:	treatment comparison.png
HDgaming42 is offline
post #11057 of 21630 Old 08-22-2014, 09:18 AM
frankie2075's Avatar
Quoted: 453 Post(s)
Liked: 108
Whats a good mic to buy to use with REW? Link to it if possible thanks.
frankie2075 is offline
post #11058 of 21630 Old 08-22-2014, 09:43 AM
HDgaming42's Avatar
Quoted: 165 Post(s)
For USB mics it usually ends up coming down to two suggestions, either the UMIK-1, or the UMM-6.
There are many threads about these mics. Here's one.
post #11059 of 21630 Old 08-22-2014, 10:51 AM
Quoted: 453 Post(s)
Liked: 108
post #11060 of 21630 Old 08-22-2014, 10:56 AM
HDgaming42's Avatar
Quoted: 165 Post(s)
I bought the UMIK-1, but if I did it again I would have purchased from a vendor that provides a calibration file for orienting the mic directly at the ceiling. The cost is not much higher (if at all) and I would now like to have that capability...
post #11061 of 21630 Old 08-22-2014, 11:30 AM
Quoted: 453 Post(s)
Liked: 108
Seems like you can download the calibration file if you type in your serial number on minidsp website. I already have a stand for the mic if i get it. I came with my auddessey pro calibration kit.
post #11062 of 21630 Old 08-22-2014, 12:07 PM
AV_mike's Avatar
Quoted: 91 Post(s)
Liked: 86
The downloadable calibration file (from Dayton, or MiniDSP) is for a single orientation (pointed at the sound source, 0 degrees)
Cross Spectrum Labs will provide multiple orientation cal files with their products, including the Narrow Band, 90 degree file that is required for optimum use with REW.
Regards, Mike.
AV_mike is offline
post #11063 of 21630 Old 08-22-2014, 12:31 PM
RayDunzl's Avatar
Quoted: 1228 Post(s)
Liked: 1429
Regards, Mike.
Looking at sample cross spectrum files, the difference in the response curves for 0,45,90 degrees occurs at the high frequencies.
Sample UMIK
Sample UMM6
Low frequencies (sub woofer range and higher) look the same.
However, they say:
"Our own microphone measurements indicate that the factory calibration data included with the mics may not be representative of the UMM-6's individual performance."
They don't add that type of qualification to the UMIK-1 page.
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI with AcourateDRC > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is offline
post #11064 of 21630 Old 08-22-2014, 12:53 PM
HDgaming42's Avatar
Quoted: 165 Post(s)
Sample UMIK
Sample UMM6
However, they say:
You just made my day! I had assumed I would not be able to trust a 90 degree orientation, but now it appears that I can (for non-HF use).
post #11065 of 21630 Old 08-22-2014, 12:58 PM
Liked: 3654
You should read the guide link in my sig--it has all the info on the mics.
post #11066 of 21630 Old 08-22-2014, 01:13 PM
RayDunzl's Avatar
Liked: 1429
Yes, I recently bought the UMIK-1 from miniDSP without doing enough price compare with Cross Spectrum, and felt deprived, then got used to it.
There's a Conversion tool somebody whipped up... I suppose it does a reasonable guesstimate.
RayDunzl is offline
post #11067 of 21630 Old 08-22-2014, 02:48 PM
cfraser's Avatar
Quoted: 128 Post(s)
Liked: 73
^ Also Jerry did a comparison of the microphones at the 90 degree and 0 degree positions using the "stock" calibration file, and didn't find a whole lot of diff, mainly just at the higher freqs as he said. We mostly do our work at the lower freqs, at least "lower" in comparison to where the microphone calibration diverges significantly with orientation.
cfraser is offline
post #11068 of 21630 Old 08-22-2014, 04:47 PM
Bluescale's Avatar
Quoted: 468 Post(s)
Liked: 170
How the heck did I miss this guide?! It would have saved me so much heartache when I was beating my head against the wall earlier this year, trying to figure out how to use REW.
Great work, by the way. This is a thing of beauty.
Alan P likes this.
Bluescale is offline
post #11069 of 21630 Old 08-22-2014, 05:03 PM
Liked: 3654
Thanks! It represents the collective wisdom of a number of the regulars in this thread, and should be a good starting point for any new REW user. Glad you found it useful.
post #11070 of 21630 Old 08-22-2014, 07:11 PM
Alan P's Avatar
Liked: 3329
Hi guys,
Waterfalls:
Feeling...defeated.
Bumping this for HD...hoping someone smarter than me has some good advice!
Dayton , Dayton Audio , Room Equilizer Wizard Rew
