Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 376 - AVS Forum | Home Theater Discussions And Reviews
 1721Likes
post #11251 of 21559 Old 08-27-2014, 05:27 PM
HDgaming42's Avatar
Quoted: 164 Post(s)
Originally Posted by 3ll3d00d View Post
A possible answer, based on your earlier frequency response, is the variation in levels across the range. You have 10dB from 45 to 30Hz for example. Perhaps you should eq first and then revisit to avoid chasing ghosts.
An astute observation. Thank you for taking the time to go back and peruse the mountain of data I've collected to offer this explanation.
Judging by how a non-averaged RTA was entirely unworkable, I suspect, like you're suggesting, the disparities I have in the bottom end are what is responsible for the variation I see between calibration methods.
I will stick with the AVR settings for now and continue down the (long twisting) path toward home theater nirvana.
As for the Mackie monitors, if I never intend on running them at reference levels (the room is a shoe box, and that would likely deafen or kill the occupants) could I get away with simply leaving them at "normal"? From the numbers you (re)provided, this seems reasonable to me...
HDgaming42 is offline
post #11252 of 21559 Old 08-27-2014, 05:54 PM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
I have a question about room treatments. As I mentioned previously, I didn't get around to canceling my order for the mineral wool boards. I have a case of 6 Roxul Rockboard 80, and another case of 6 Roxul Rockboard 60 on their way now. The 80 is 8 lb/ft3 (equivalent to OC 705), and the 60 is 6 lb/ft3 (equivalent to OC 730). I was planning to create two 6" thick bass traps using the Rockboard 80. Do you guys have a recommendation of what I should do with the 60? Should I build 2 less dense bass traps, or should I build some broadband absorbers? If I go for broadband absorbers, should I go for six 2" thick or three 4" thick panels.
Also, the back wall near where the sub is set up rattles quite a bit when things dig really deep (think the skadoosh scene in Kung-Fu Panda). Will placing an absorber back there help with the rattling?
Bluescale is offline
post #11253 of 21559 Old 08-27-2014, 08:11 PM
HDgaming42's Avatar
Quoted: 164 Post(s)
FWIW there's some good info on what the levels really should be in this thread - http://yabb.jriver.com/interact/inde...topic=77124.20 - and why narrow band pink noise is a bit of a fudge to allow for deficiencies in the measurement chain. In particular note the comments from bobkatz (aka http://www.digido.com)
Slowly making my way through this thread. What an excellent resource! I can see why Markus advocates the RTA method:
Im with Bob on the sub/LFE setup. I never ever trust pinknoise and RMS meters for the sub and LFE (even narrow band LFE noise) which is why I use sweeps, and individual tones from 20hz to 200hz with FFT analysis to check for funky cross over problems and room modes before i even think about level matching. Almost all common household rooms will have problem room mode frequencies in the 30-100hz range (standing waves and nulls) which makes RMS pink noise useless because your going to have upto 10db room mode peaks and 10db holes between 20-300hz or so. The meter wont be able to distinguish a room mode peak or a null or a crossover problem. Only careful measurement with proper instruments can properly set LFE/sub crossover and levels if you want the most accurate result.
I believe this addresses my situation exactly. Thanks 3ll3d00d!
post #11254 of 21559 Old 08-27-2014, 08:57 PM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
As for the Mackie monitors, if I never intend on running them at reference levels (the room is a shoe box, and that would likely deafen or kill the occupants).
Reference level is reference level. Headphones, shoebox, stadium, doesn't matter. The only difference is the power requirements required to produce that level.
Audionut11 is offline
post #11255 of 21559 Old 08-28-2014, 12:05 AM
markus767's Avatar
Quoted: 3632 Post(s)
Liked: 1294
Unfortunately the perceived loudness of "reference level" is different in different sized rooms. The premise that the steady state response would directly translate to perceived loudness is flawed.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #11256 of 21559 Old 08-28-2014, 12:13 AM
markus767's Avatar
Liked: 1294
Originally Posted by HDgaming42 View Post
Does this look (attached) correct? I was able to match up 60Hz, but 30Hz is out of wack...
You just have found out that the room distorts the magnitude response of a speaker by a great deal. Run Audyssey and you'll notice that the response will be much smoother afterwards.
Markus
post #11257 of 21559 Old 08-28-2014, 12:19 AM
markus767's Avatar
Liked: 1294
If the RTA method is bulletproof then great, I guess we're done. I just don't understand why both test tone CDs (two sets of pink noise) and REW both want my sub lower than the AVR and the RTA method...
They average the response of different frequency ranges. Your response is VERY uneven at low frequencies.
If the RTA method shows large deviations between the bands like in your room then you need to optimize speaker setup and room acoustics.
Markus
post #11258 of 21559 Old 08-28-2014, 12:29 AM
markus767's Avatar
Liked: 1294
Make them as thick and broadband as possible. Reducing low frequency energy from the room will improve the perceived sound quality more than killing first reflections like many recommend. It's harder to do than higher frequency absorption and it's even harder to measure but it reduces deterimental effect caused by upward masking. You'll hear more detail in higer frequencies.
Probably not. You'll have to find what is rattling and dampen it.
Bluescale likes this.
Markus
post #11259 of 21559 Old 08-28-2014, 01:09 AM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
For the Rockboard 60, Are two 6" panels better than three 4" panels, even through they cover less surface area in the room?
post #11260 of 21559 Old 08-28-2014, 01:12 AM
markus767's Avatar
Liked: 1294
What's the flow resistivity of Rockboard 60?
Markus
post #11261 of 21559 Old 08-28-2014, 03:25 AM
3ll3d00d's Avatar
Quoted: 1566 Post(s)
Liked: 544
generally speaking audyssey will get you pretty close, doing this yourself is more about fine tuning (like setting levels yourself using an RTA) and/or problem resolution (e.g. in case you have noise floor issues).
3ll3d00d is online now
post #11262 of 21559 Old 08-28-2014, 08:25 AM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
I couldn't find that data. I found absorption co-efficiencies at various frequencies:
Acoustical Performance:
ASTM C 423
CO-EFFICIENTS AT FREQUENCIES
Thickness 125 Hz 250 Hz 500 Hz 1000 Hz 2000 Hz 4000 Hz NRC
1.0” 0.08 0.33 0.78 1.03 1.02 1.04 0.80
1.5” 0.17 0.62 1.00 1.05 1.01 1.01 0.90
2.0” 0.32 0.81 1.06 1.02 0.99 1.04 0.95
3.0” 0.78 0.89 1.04 0.98 1.01 1.02 1.00
The package I'm getting contains six 2" boards.
post #11263 of 21559 Old 08-28-2014, 09:13 AM
markus767's Avatar
Liked: 1294
Without flow resistivity values not much can be said. Try straddling the wall corners with it for a first test.
Markus
post #11264 of 21559 Old 08-28-2014, 09:38 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 372 Post(s)
Liked: 243
The most useful source for GFR I know of is this thread @ Gearslutz. It's spotty, at best, but FWIW Rockboard 40 shows as 5.2 x 10^4 (post #22). If RW3 60 and RW4 80 = Rockboard (this site shows as Rockwool Slab), GFR for each is shown in post #49.
Wish there were a more concise and known-accurate source for GFR, but I know of none - for Rockwool at least.
RUR is offline
post #11265 of 21559 Old 08-28-2014, 10:22 AM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
Thanks, RUR. I stumbled across that same thread earlier this morning trying to find an answer to Markus' question. I'm not comfortable using the Rockboard information because, as Andre points out, manufacturer to manufacturer, and even region to region differences can be significant.
I've sent an email off to Roxul asking for the airflow resistance and resistivity. Let's see if they get back to me with anything useful, and in a timely manner. If not, I'll do what Markus suggested - stick it in the corner, and measure.
post #11266 of 21559 Old 08-28-2014, 11:58 AM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 187
A room has more corners than you think. There are the wall-wall corners, wall-floor corners and wall-ceiling corners.
You may want to experiment with wall-wall vs wall-floor corners. The best corners for traps are the ones where wall+floor+ceiling come together. Hence the tri-corner trap that one can buy.
artur9 is offline
post #11267 of 21559 Old 08-28-2014, 12:38 PM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
Alas...
Good day,
Thanks for the inquiry into ROXUL.
We have not done airflow resistivity testing on ROCKBOARD 60 or ROCKBOARD 80. We have tested the product’s acoustical performance to ASTM C423. This is a test for noise reduction coefficient. The information can be found on the attached technical data sheets.
My apologies that we cannot provide any airflow resistance data for you. That being said, ROCKBOARD 60 and 80 are often used successfully in acoustical panel applications.
Please let me know if you have any other questions.
http://www.roxul.com/files/RX-NA_EN/...OCKBOARD60.pdf
http://www.roxul.com/files/RX-NA_EN/...OCKBOARD80.pdf
post #11268 of 21559 Old 08-28-2014, 12:43 PM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
Don't I know it!
And my room has more corners than most, because of the odd nooks and crannies and angles (I can think of 13 places where three boundaries meet). My theory is that one of the reasons I have less reflection issues than I would expect is because the room is so non-symmetrical, it's operating as a bit of a diffusor.
post #11269 of 21559 Old 08-28-2014, 12:58 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6542 Post(s)
Liked: 3625
A way to pick the most effective place for bass trap placement is to play a bass frequency test tone and walk around the room with an SPL. Those corners showing the highest readings are the best spots for the traps.
AustinJerry is offline
post #11270 of 21559 Old 08-28-2014, 03:43 PM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
Is there a preferably tone to play, or is it a good idea to play a sweep (say 10-200 hz), and see which corner has the most overall energy?
post #11271 of 21559 Old 08-28-2014, 05:14 PM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Thanks, Jim. I got too tied up to create one myself. Better from you anyway.
John replied at HTS.
Might take a look since you are having the same symptoms as I am. You might want to participate as well to help John see the problem.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #11272 of 21559 Old 08-28-2014, 06:15 PM
Liked: 3625
I'll try and run some tests tomorrow. Testing for understanding, you want me to take several consecutive measurements, being careful to not alter anything, and simply varying sweep length from 128 to 1M?
post #11273 of 21559 Old 08-28-2014, 06:31 PM
Quoted: 449 Post(s)
Liked: 153
Yep. And save the data.
Edit: Then go to the HTS thread and look at your IR in the fashion John presented them. See if you IR's match up like John's, or are all over the place like mine.
My Room
My Music
Jenzen Next
post #11274 of 21559 Old 08-29-2014, 09:37 AM
markus767's Avatar
Liked: 1294
Jim,
Just did a quick test and my IRs look exactly the same regardless of test signal length. I've tested this with an external USB interface and with the built in speakers/mic of my laptop.
Markus
post #11275 of 21559 Old 08-29-2014, 10:10 AM
Quoted: 449 Post(s)
Liked: 153
Jim,
Thanks. Additional input is always welcome for problem solving. But I am really at a loss to what is wrong.
I wonder if it could be my USB path?
Computer -> 15ft usb cable -> Usb Hub
From the Usb Hub one output goes to my DAC on my stereo system via another 15ft Usb cable, a second output on the Usb Hub goes to my Usb mic via another 10ft Usb cable.
It is done this way because my measuring computer is a desktop in the next room about 20feet away.
Does that sound problematic?
My Room
My Music
Jenzen Next
post #11276 of 21559 Old 08-29-2014, 10:22 AM
Saril's Avatar
Quoted: 46 Post(s)
Is UMIK-1 & REW capable of showing noise floor lower than 50dB C/Slow
Originally Posted by Alan P View Post
Takes me about 15 minutes at most. That being said, I've had good results from just a 3 point calibration (1 - MLP / 2 - 3" left of MLP / 3 - 3" right of MLP)...takes about 5 minutes.
With all the time you've wasted trying to set your levels manually with REW you probably could have run full 8-point Audyssey a dozen times!
And, yes, I trust the levels set by Audyssey....and have verified them many, many times with an analog SPL meter and REWs SPL meter. I've ran Audyssey so many times in the last year, I've lost count.
The only thing I do is bump up the sub trim from where Audyssey sets them....my preference is hotter than most though at +8db.
Alan (or anyone) - have you ever measured a noise floor lower than 50 dB C/Slow using the UMIK-1 and REW? I am reading around 40 - 43 dB C/Slow with my UMIK-1 and SPL reads about 10 dB higher. Thanks for any insight with this.
Saril is offline
post #11277 of 21559 Old 08-29-2014, 10:26 AM
markus767's Avatar
Liked: 1294
I wonder if it is my USB path?
John is probably right - he usually is I would look at the signal path in detail. Remove as many variables as possible. Can you do computer USB out > DAC > computer analog in?
Markus
post #11278 of 21559 Old 08-29-2014, 10:31 AM
Quoted: 449 Post(s)
Liked: 153
I agree John knows what he is doing. I am not questioning his expertise.
It would be difficult to do the path suggested. What would it accomplish if I could?
My Room
My Music
Jenzen Next
post #11279 of 21559 Old 08-29-2014, 10:45 AM
Quoted: 449 Post(s)
Liked: 153
I tried making two separate paths:
Computer Usb1 -> DAC
Computer Usb2 -> Hub -> Mic
Same results
My Room
My Music
Jenzen Next
post #11280 of 21559 Old 08-29-2014, 11:13 AM
Quoted: 449 Post(s)
Liked: 153
Did the same test on my laptop. Same result. Kinda rules out the computer doesn't it?
My Room
My Music
Jenzen Next
Dayton , Dayton Audio , Room Equilizer Wizard Rew
