Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 378 - AVS Forum
 58Likes
post #11311 of 11330 Old Yesterday, 12:06 AM
Roger Dressler's Avatar
Quoted: 373 Post(s)
Liked: 225
Originally Posted by markus767 View Post
Jerry, just a minor suggestion for improvement. When you talk about level calibration signals you should add RMS, e.g. -30dB FS RMS. The signal itself "wiggles" around that value.
Markus, is that necessary? The generator in step 8 shows "RMS Level dB FS," so when you dial up "-30" that covers it. Besides, there's no option for anything else.
Roger Dressler is online now
post #11312 of 11330 Old Yesterday, 12:14 AM
markus767's Avatar
Quoted: 641 Post(s)
Liked: 240
I think it doesn't hurt to be as specific as possible.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is online now
post #11313 of 11330 Old Yesterday, 07:17 AM
jim19611961's Avatar
Quoted: 92 Post(s)
Liked: 80
Hi Jim,
I switched off loopback and even tried to create severe mismatch of sample rates and bit depths but the resulting impulse responses never looked as dissimilar as what you and Jerry have shown. I'm running REW on a Mac.
Thanks for trying to recreate the problem.
Since Jerry and I both have the problem, there might be a lot of others as well, but they don't know it cause how many people did what I did to discover the inconsistency in the first place?
Perhaps after the holidays are over, John will chime back in either here or at HTS. In the meanwhile, I am going to use the 256k sweeps because they look the most like my Omnimic sweeps.
My Room
http://www.gearslutz.com/board/studio-building-acoustics/817205-my-listening-room.html
My Music
http://rateyourmusic.com/~jim1961
My Equipment
Rega - Apollo
Rega - DAC
Goldpoint Passive
(2) Classe CA-100 bridged power amps (350w)
Jenzen Next ( http://www.troelsgravesen.dk/Jenzen-NEXT.htm )
jim19611961 is online now
post #11314 of 11330 Old Yesterday, 01:30 PM
Bluescale's Avatar
Quoted: 87 Post(s)
Liked: 43
I've got a few other things to run through tonight, but if/when I get a chance, I'll give it a try. I'm not sure if Markus is using a USB mic, but if he's not, that might be difference. I have a CSL UMIK-1.
Bluescale is online now
post #11315 of 11330 Old Yesterday, 01:37 PM
markus767's Avatar
Quoted: 641 Post(s)
Liked: 240
I have a couple of mics here but none of those USB mics.
Markus
post #11316 of 11330 Old Yesterday, 01:41 PM
Quoted: 92 Post(s)
Liked: 80
I think that is the mic Jerry uses. A Dayton UMM-6 for me.
But that is what we need. More evidence.
My Room
My Music
My Equipment
Rega - Apollo
Rega - DAC
Goldpoint Passive
post #11317 of 11330 Old Yesterday, 07:11 PM
steveting99's Avatar
Quoted: 161 Post(s)
Liked: 75
Guys,
Wanted to ask about the audio output signal when using HDMI connected to the AVR.
Does REW send out PCM signal to the AVR?
Maranatz NR1504, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
steveting99 is offline
post #11318 of 11330 Old Yesterday, 07:12 PM
Bluescale's Avatar
Quoted: 87 Post(s)
Liked: 43
Originally Posted by steveting99 View Post
Guys,
On the front of my processor it says PCM.
post #11319 of 11330 Old Yesterday, 07:31 PM
AustinJerry's Avatar
Quoted: 475 Post(s)
Liked: 696
Guys,
Just curious, why do you ask? Does the type of signal make a difference?
AustinJerry is online now
post #11320 of 11330 Old Yesterday, 08:05 PM
Quoted: 161 Post(s)
Liked: 75
Thanks Bluescale!
I'm thinking of getting one of these: http://www.minidsp.com/ht-series/nanoavr-dl to test for Dirac in-a-box.
Would like to compare Dirac to Audyssey.
My thinking is to check the frequency and timing to see what Dirac has done. So want to use REW to take the before and after Dirac REQ. The NanoAVR-DL can only accept PCM signals so wanted to check that REW outputs PCM.
Bluescale has just confirmed this.
Already got the UMIK-1 mic for REW so don't need to purchase another one from MiniDSP. Got some unanswered questions to be resolved with MiniDSP. Will most likely place an order for the NanoAVR-DL once the questions are answered satisfactorily...
Reading through the preliminary manual now.
post #11321 of 11330 Old Yesterday, 08:10 PM
dsteak's Avatar
Yet another Noob here. I have dual Rythmik 15" subs, 16x13x7.5 theater with sound treatments. Installed REW and took a quick measurement. Here is what showed. Any thoughts on what it's showing? I'm trying to read up and learn what these things mean, just thought I'd reach out for some quick assessments.
dsteak is offline
post #11322 of 11330 Old Yesterday, 08:13 PM
Bluescale's Avatar
Quoted: 87 Post(s)
Liked: 43
The nanaAVR HD also only accepts PCM (this is true for all miniDSP products, isn't it?) and it's definitely designed for use with REW:
http://www.minidsp.com/applications/...n-with-nanoavr
If you go through with this, I'll be really interested in your experience. That has the potential to be a great solution for a lot of people who want Dirac, but don't want to buy a new AVR.
post #11323 of 11330 Old Yesterday, 08:17 PM
Bluescale's Avatar
Quoted: 87 Post(s)
Liked: 43
Take a look at Jerry's guide here:
It has some information on posting graphs that make for us to see what's going on. Can you repost that with no smoothing and set to show all the way to 300hz? Again, take a look at the guide on specific information how to do that if you don't know.
post #11324 of 11330 Old Yesterday, 08:52 PM
Quoted: 475 Post(s)
Liked: 696
I see a frequency response curve that is reasonably well-shaped down to 10Hz, with a gently upwards-sloping "house curve". I see a dip at 60Hz that might be associated with the crossover frequency, or might be caused by a room mode. I see some unexplained little color bars at the bottom--don't know what they represent.
If you have the time, re-measure the frequency range 15-300Hz (or 10-300Hz if you are showing off). Include the legend at the bottom of the graph scree when you post. Tell us what you are measuring, i.e. is this subs only, or subs+mains? If the mains are included, what is the crossover point? Are you using room correction like Audyssey? Is the graph smoothed, or unsmoothed? If smoothed, post the new measurement unsmoothed.
So, not bad, but we don't have all the information yet. Answer ALL the questions, please.
post #11325 of 11330 Old Yesterday, 10:00 PM
RayDunzl's Avatar
Quoted: 243 Post(s)
Liked: 225
... I see some unexplained little color bars at the bottom--don't know what they represent...
Calculated room nodes if you input the dimensions in the right slots.
- modal analysis setup on the EQ window
- show modal frequencies option on the main window on some displays
I'll be back later...
equitech 1.5RQ > digits > miniDSP > behringer > benchmark > krell pre and monoblocks > reQuest
RayDunzl is online now
post #11326 of 11330 Old Today, 04:03 AM
3ll3d00d's Avatar
Quoted: 120 Post(s)
Liked: 32
Dayton EMM-6 mic via a usb preamp/audio device (RME Fireface 800), no loopback, IRs do not vary with length
I did notice that the input levels reported by the longer sweeps were lower than the shorter sweep. I wonder if this is related to your problem given the higher noise floor of the USB mic (and the fact that your sweeps look like they contain noise before the initial impulse)
3ll3d00d is online now
post #11327 of 11330 Old Today, 10:03 AM
Quoted: 92 Post(s)
Liked: 80
Attachment 240041
Red = 1M
Blue = 256K
Its easy to see now whats happening. This unnormalized view clearly shows the 1st IR peaks to be 5-6db different. So when normalized, one graph get pushed up more than the other. Second problem is they dont track each other very well. And thirdly, that pre ringing on the red graph (1M).
Unfortunately, knowing whats happening hasnt helped in figuring out why.
My Room
My Music
My Equipment
Rega - Apollo
Rega - DAC
Goldpoint Passive
post #11328 of 11330 Old Today, 10:32 AM
dsteak's Avatar
Thanks so much for the replies. I measured twice (Audyssey ON/OFF) and updated the output. This is with the Subs only, no Mains.
dsteak is offline
post #11329 of 11330 Old Today, 11:36 AM
Bluescale's Avatar
Quoted: 87 Post(s)
Liked: 43
If you go back into REW, pull up that measurement, and hit to "Freq. Axis" button up in the top left, things will look more like what we expect. Right now it's showing a linear response, which doesn't do a good job of mimicking what we actually hear. Once you hit the button, it'll switch to logarithmic. You'll notice that some of the gridlines are much closer together, and the measurement increments aren't uniform blocks of 50.
Once you've done that, post the image for us.
post #11330 of 11330 Old Today, 11:53 AM
Quoted: 475 Post(s)
Liked: 696
Agreed that the graph should be displayed in log mode, nice catch. Also, I would go ahead and include the mains in the measurement. Looking at raw sub response is OK to dial in the subs, but ultimately we want to see the overall bass response, which includes the contribution of the mains. That should smooth out the response above the crossover considerably.
Reply Audio theory, Setup and Chat
Dayton , Dayton Audio , Room Equilizer Wizard Rew
User Tag List
