Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 379 - AVS Forum | Home Theater Discussions And Reviews
 1850Likes
post #11341 of 21973 Old 09-02-2014, 10:52 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Originally Posted by jim19611961 View Post
I just called Parts Express to find out. The mic that comes with the Omnimic kit is neither the UMM-6 or the EMM-6. This is the mic I use. They say its exclusive for that kit.
Yeah, I knew you were using the OM kit mic (more similar to a UMM-6 than the EMM-6 because it's USB) so I was more responding to the fact that the EMM-6 is not a USB mic. HST, until now I wasn't sure if the OM mic was really any different to the UMM-6 since I've owned both and there's no discernible difference in appearance.
jkasanic is offline
post #11342 of 21973 Old 09-02-2014, 10:55 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Was their any discernible difference in the measurement data they provided?
Additionally, PE said there was "extra stuff" in the OM version. They added it may not work right with anything other than OM. Made my day
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #11343 of 21973 Old 09-02-2014, 11:06 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Several months ago (heck, maybe even over a year now?!), there was a discussion in this thread around the use of the UMM-6 with OM as well as the OM mic with REW. To my knowledge, the latter has been reported but not the former. The physical appearance of the mic is identical as well as the case and accessories. I sent my OM kit back when I realized how much more robust/versatile REW was so I never had the chance to swap mics and compare the data. I also believe at that time that OM didn't support the cal file from CSL (or perhaps I have it mixed up and REW didn't support the cal file from OM) so that was a limiting factor but I believe that is no longer the case.
I haven't been following this latest issue in detail but from the posts I've read, all signs point to the use of a USB mic (UMM-6, UMIK-1 or the OM version) and no loopback as the major variables. How that relates to how REW retrieves and displays the data is beyond me.
jkasanic is offline
post #11344 of 21973 Old 09-02-2014, 11:11 AM
Bluescale's Avatar
Quoted: 497 Post(s)
Liked: 189
I don't think loopback is an issue, because Markus tried it with and without loopback, and the data was the same.
Bluescale is offline
post #11345 of 21973 Old 09-02-2014, 11:12 AM
Quoted: 449 Post(s)
Liked: 153
Good point. But not with a USB mic. Or was it?
My Room
My Music
Jenzen Next
post #11346 of 21973 Old 09-02-2014, 11:16 AM
Bluescale's Avatar
Quoted: 497 Post(s)
Liked: 189
No, he didn't have a USB mic. Is it even possible to do the loopback connection with a USB mic?
post #11347 of 21973 Old 09-02-2014, 11:18 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Yeah, I forgot Markus reported no issue with and without the timing reference loopback so good point indeed. Could be another anomaly with the USB mics (like the spikes issue and higher noise floor).
jkasanic is offline
post #11348 of 21973 Old 09-02-2014, 11:19 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
AFAIUI, no it's not possible.
jkasanic is offline
post #11349 of 21973 Old 09-02-2014, 11:25 AM
Quoted: 449 Post(s)
Liked: 153
Have either of you performed the test? Result?
My Room
My Music
Jenzen Next
post #11350 of 21973 Old 09-02-2014, 11:26 AM
3ll3d00d's Avatar
Quoted: 1581 Post(s)
Liked: 568
that's correct
the measurements look like they contain noise before the impulse to me. If you look at the IR on overlay with dBFS scale, zoom in on -2ms to +2ms and see how the level before the impulse increases with each sweep until it blows through the full scale, at that point it loops over itself before the main impulse.
I think the next step is to try and rule out different parts of the signal path; for example going to a short direct USB connection, switching USB cable, switching USB ports and so on.
I don't see how loopback has anything to do with it as that just gives it the system time so it can calculate the flight time correctly. The reported measurement itself doesn't change when you mess around with loopback (e.g. set it so it receives no signal or so you clip the loopback signal).
3ll3d00d is online now
post #11351 of 21973 Old 09-02-2014, 11:30 AM
Quoted: 449 Post(s)
Liked: 153
I agree. It does look that way on the 512k and 1M sweeps. But not on the 256k sweep.
I tried all three of those things to no avail.
Remember. I tried this whole affair on my laptop and got the same results.
I have also tried it using my PC speaker system with the same results.
When I used my RS SPL meter as the mic, the problem went away.
The only common factor is REW and the mic. They don't like each other it seems. The puzzling thing is Jerry is having the problem also, and he is using a different mic than me.
My Room
My Music
Jenzen Next
post #11352 of 21973 Old 09-02-2014, 11:47 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6834 Post(s)
Liked: 3805
Until you pointed it out, I didn't realize I had a problem, Jim. Just think, two years of REW work down the drain. I guess I'll start over now.
AustinJerry is offline
post #11353 of 21973 Old 09-02-2014, 11:51 AM
Quoted: 449 Post(s)
Liked: 153
I wouldn't go that far. The 256k sweeps agree very closely with the data obtained by Omnimic. Since OM is a kit, and each part is meant to work with the others, I can only assume OM with the OM mic is pretty accurate. That said, you use 256k most of the time anyway. So while there is a mystery here, if your data is off, I don't think its by much.
My Room
My Music
Jenzen Next
post #11354 of 21973 Old 09-02-2014, 11:59 AM
3ll3d00d's Avatar
Liked: 568
they all look the same to me, they just burst through the peak level at different times
This is from -2.5ms to +0.1ms
I've drawn lines to show what I mean (I changed the 512 trace to blue to distinguish it from the other green one)
tbh even the 128 one looks dodgy, I don't see anything like that in any of my traces. They're usually like this
post #11355 of 21973 Old 09-02-2014, 12:02 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
I have not tried it. If there's no progress on this issue before my next measurements then I'll be sure to try it the next time I have my room setup.
jkasanic is offline
post #11356 of 21973 Old 09-02-2014, 12:04 PM
3ll3d00d's Avatar
Liked: 568
I don't think all (or anything really) is lost. As far as I can see, the etc's look basically the same which is, afaik, what you use it for. If you were doing impulse or phase related work (e.g. XO design) then I think you'd have noticed the problem before now. FWIW the phase view is another one that shows variation btw (though I think some variation is expected when you don't have loopback)
post #11357 of 21973 Old 09-02-2014, 12:06 PM
markus767's Avatar
Quoted: 3757 Post(s)
Liked: 1346
So, I have a question about this. My sub is a Rythmik D15SE, which is downward firing. Downward firing works well in my room because I have concrete floors If I flip it upside down on the couch, so the sub is firing toward the ceiling, it'll be pretty close to ear height.
Does the direction of the driver make a difference? For that reason alone, I haven't bothered to do the sub crawl. I always move it to possible locations, and measure, which is a pain with such a big sub.
Orientation doesn't matter as long as the driver is at ear height.
Easy to check if you're doing it right: Put the mic at some location in the room and measure. Then swap location of mic and sub and re-measure. The result should look more or less the same.
Bluescale likes this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #11358 of 21973 Old 09-02-2014, 12:12 PM
LastButNotLeast's Avatar
Quoted: 1533 Post(s)
Liked: 1143
At least now there's a great guide you can follow.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #11359 of 21973 Old 09-02-2014, 12:15 PM
Quoted: 449 Post(s)
Liked: 153
Name:	OM ETC 09 02 14 R.JPG
Name:	rew etc 09 02 14 r.jpg
Jerry, here is REW vs OM. Same mic location. One right after the other. As you can see, the ETC's look very very similar. And ETC is one of those areas where the file size problem shows the most.
My Room
My Music
Jenzen Next
post #11360 of 21973 Old 09-02-2014, 12:25 PM
Quoted: 449 Post(s)
Liked: 153
Attachment 242466
Attachment 242474
What I should have said is that the 128k and 256k look "more" normal than the 512k and 1M
My Room
My Music
Jenzen Next
post #11361 of 21973 Old 09-02-2014, 12:34 PM
3ll3d00d's Avatar
Liked: 568
Does omnimic let you change the sweep length? What does the ir look like in omnimic? Same as REW or different.
You, and Jerry, could also try HolmImpulse if you want another data point. This would help isolate either the app or the mic/signal chain.
post #11362 of 21973 Old 09-02-2014, 12:42 PM
Quoted: 449 Post(s)
Liked: 153
Name:	OM IR 09 02 14.jpg
Here is the OM IR.
Yep. The pre hump is there.
OM works completely differently than REW. You cannot change sweep lengths. You get a CD disc with sweeps contained on them for apllication to different measurements.. The sweep length for FR (shorter) is different than the one used for ETC (longer) though.
My Room
My Music
Jenzen Next
post #11363 of 21973 Old 09-02-2014, 12:52 PM
Liked: 3805
I was trying to be humorous, guys. I'm not going to lose any sleep over this anomaly.
post #11364 of 21973 Old 09-02-2014, 12:56 PM
Quoted: 449 Post(s)
Liked: 153
If we see you posting at 3:00am, then we will know things are worse than your admitting
My Room
My Music
Jenzen Next
post #11365 of 21973 Old 09-02-2014, 01:16 PM
Liked: 1143
Make sure Windows isn't adding any of its own processing:
post #11366 of 21973 Old 09-02-2014, 01:23 PM
Quoted: 449 Post(s)
Liked: 153
Checked that also (had already been disabled).
My Room
My Music
Jenzen Next
post #11367 of 21973 Old 09-02-2014, 03:22 PM
Kal Rubinson's Avatar
Quoted: 693 Post(s)
Liked: 472
I've used it with REW and with DiracLive.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #11368 of 21973 Old 09-02-2014, 03:29 PM
Quoted: 449 Post(s)
Liked: 153
I have been using it with REW as well. But if you have been following this recent discussion, and you run the tests prescribed, you may find that there are issues. Especially someone such as your self, who uses a USB mic with REW, could be helpful in determining the cause, whether your suffer from the issue or not.
My Room
My Music
Jenzen Next
post #11369 of 21973 Old 09-02-2014, 03:47 PM
Quoted: 693 Post(s)
Liked: 472
I have not been "following" this thread with any regularity. Can you explain or link me to it?
Kal Rubinson
post #11370 of 21973 Old 09-02-2014, 03:50 PM
Quoted: 449 Post(s)
Liked: 153
Its being discussed in two places. Here is a link to the more compact version:
http://www.hometheatershack.com/foru...sparities.html
My Room
My Music
Jenzen Next
Dayton , Dayton Audio , Room Equilizer Wizard Rew
