Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 382 - AVS Forum | Home Theater Discussions And Reviews
 2288Likes
post #11431 of 23611 Old 09-04-2014, 01:37 PM
Alan P's Avatar
Quoted: 5148 Post(s)
Liked: 3840
Originally Posted by HDgaming42 View Post
*remove the miniDSP
*reset Audyssey and temporarily disable it
*set the Sub to physical full gain (manufacturer recommended)
*set all AVR trims so MV 0 = 75dB using AVR tones, including sub
*run sweeps with only 1 HDMI channel using the same 90Hz crossover for L, sub, and L+Sub by physically powering other speakers off where applicable
*run Audyssey for 3 points (minimum)
*repeat sweeps
*pray
First step, good. Then skip all the other steps you outlined and go directly to "run Audyssey". The other steps are completely unnecessary.
Setting your sub to max gain is going to get you nothing but -12db (or whatever the max is on your AVR) in the sub trim.
Setting any of the speaker trims pre-Audyssey is a waste of time as Audyssey is going to reset them anyway.
Running sweeps pre-Audyssey is a waste of time because none of your distances or crossovers are set correctly. There is reason to do sweeps with Audyssey disabled, but that is after you have ran it and all settings are correct.
Are you certain you don't have DynEQ and DynVol? You have XT.......
Alan P is offline
post #11432 of 23611 Old 09-04-2014, 01:42 PM
3ll3d00d's Avatar
Quoted: 1666 Post(s)
Liked: 646
I disagree with this. IMV HD (if I may call you HD ) would benefit from doing this without external interference at all and then layering in the tooling (audyssey, minidsp). Yes it will take longer but it will make sure he is crystal clear on what is going on.
Bluescale likes this.
3ll3d00d is online now
post #11433 of 23611 Old 09-04-2014, 01:52 PM
Alan P's Avatar
Liked: 3840
Well, I guess. But the part about setting the sub gain to max has got to go for sure.
What is "IMV"??
Alan P is offline
post #11434 of 23611 Old 09-04-2014, 01:54 PM
HDgaming42's Avatar
Quoted: 169 Post(s)
Pretty certain. No mention of them in the manual, and I've never run across them in years of ownership.
Because things like this bug me, I found where I got the miniDSP gain into my head, and yes, it was my misunderstanding/mangling of what was being discussed in this thread. I too have an SVS sub with a Sledge Amplifier STA-500D (PB-2000), so should I not set it to "0" or "max" as discussed?
You're saying Audyssey will just smack it down -12 anyway?
HDgaming42 is offline
post #11435 of 23611 Old 09-04-2014, 01:54 PM
3ll3d00d's Avatar
Liked: 646
What is "IMV"??
In My View
post #11436 of 23611 Old 09-04-2014, 02:09 PM
Alan P's Avatar
Liked: 3840
You are correct, no DYnEQ or DynVol on your AVR.
Yes, you should try maxing the gain on the sub(s) when using the MiniDSP, but not without it - doesn't work that way. With the sub gain maxed and using the MiniDSP you can adjust gains down to a reasonable range with the MiniDSP software so Audyssey will set the sub(s) at the optimum trim level. Without the MiniDSP you have to adjust the gain on the sub(s) to achieve optimum trim level.
Since I'm looking at your manual; you have Double Bass, Intellivolume and THX Subwoofer turned off, right?
Alan P is offline
post #11437 of 23611 Old 09-04-2014, 02:18 PM
3ll3d00d's Avatar
Liked: 646
more generally, you want to avoid going up and down (and then up again) with the gain structure (though ultimately if you don't have a noise problem, I don't think it makes any difference)
post #11438 of 23611 Old 09-04-2014, 02:18 PM
HDgaming42's Avatar
Quoted: 169 Post(s)
YYes, you should try maxing the gain on the sub(s) when using the MiniDSP, but not without it - doesn't work that way.
And that's when I set it that way--when I integrated the miniDSP.
I don't believe you can enable Double Bass if you have a cross-over active, but:
No to double bass
No to intellivolume (IIRC only sets an initial volume level--that's all--nothing dynamic)
Yes to THX subwoofer, as my sub outputs flat below 30Hz (but not in my room!!! LOL)
post #11439 of 23611 Old 09-04-2014, 02:23 PM
3ll3d00d's Avatar
Liked: 646
Originally Posted by hdgaming42 View Post
no to double bass
no to intellivolume (iirc only sets an initial volume level--that's all--nothing dynamic)
yes to thx subwoofer, as my sub outputs flat below 30hz (but not in my room!!! Lol)
I think for it would be wise to
Alan P likes this.
post #11440 of 23611 Old 09-04-2014, 02:32 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7743 Post(s)
Liked: 4333
Regarding what to set the speaker and sub levels to before running Audyssey, keep in mind that for the first pass, the settings don't matter that much. Set them as you described, run the 3-pos Audyssey calibration, save the results, and then look at the trim values in the AVR. If any of the trims are "maxed out", i.e. are set to their maximum values (-12 on a Denon, not sure but maybe -15 on the Onkyo), then go to that speaker (or sub), adjust the gain setting down a bit, and repeat the 3-step calibration again. Ideally, all trims should end up more in the middle of the range, i.e. +/- 5.
Once you have it so Audyssey is setting all the trims to reasonable values, the next step is to measure the output of the AVR speaker level-setting tones, which should measure close to 75dB at the MLP. If they don't, you might as well stop, because something isn't right.
Looking forward to your next round of testing.
Alan P likes this.
AustinJerry is offline
post #11441 of 23611 Old 09-04-2014, 02:33 PM
HDgaming42's Avatar
Quoted: 169 Post(s)
Attachment 246386
From my reading--and clearly--my reading is not absolute--the designation of "THX sub" in an AVR this old really only did two things--set a preferred crossover of 80Hz with a slightly modified slope, and enabled the optional use of BGC (which I have not enabled)
Not correct? Or you'd rather remove it at this stage just to be sure?
post #11442 of 23611 Old 09-04-2014, 02:36 PM
Liked: 4333
No to double bass
ALL processing, including THX sub should be turned off prior to running the calibration. After the calibration, you can turn any of thes back on according to your tastes. You should also leave them off during the REW measurements.
Alan P and 3ll3d00d like this.
post #11443 of 23611 Old 09-04-2014, 03:28 PM
HDgaming42's Avatar
Quoted: 169 Post(s)
Why yes--yes you may refer to me as "HD". Thank you for asking.
I echo your mindset. Ideally I would get all my room treatments in place before going any further than I have, but the reality is that this room needs to be semi-functional soon.
I'll report back with what I manage to accomplish tonight. Once again gang--thanks for the help!
post #11444 of 23611 Old 09-04-2014, 06:30 PM
Zzzzz...'s Avatar
Quoted: 184 Post(s)
Liked: 56
Hi everyone,
I'm using REW for the first time and I'm having a few problems. First, here is my setup:
iMac, umik-1, Denon X4000, REW (V5.01 Beta 22)
The mac is connected to the AVR's AUX1 input via the mac's headphone output (using a 3.5mm to RCA adaptor)
Here are the issues I'm having:
1. Only extremely rarely does REW recognise that the mic is attached (and hence available for use). It seems like there is some sort of cable/connection problem as just moving the mic causes the connection to be lost. I'm using the USB cable that came with the mic.
2. To test the connection between my mac and AVR I tried playing some music. It sounded really bad - very noisy. Playing the same song via a USB stick (ie bypassing the mac completely) the same song sounds amazing - crystal clear. What is likely causing this? Is it the cable from my mac to AVR? The cable is 4-5m long.
Cheers
Zzzzz... is offline
post #11445 of 23611 Old 09-04-2014, 06:42 PM
Liked: 4333
Originally Posted by Zzzzz... View Post
Hi everyone,
Cheers
Note 2 on page 3 of the REW Guide (link in my sig) has some advice regarding running REW on a Mac. Perhaps this will be useful. Most of us are Windows users.
post #11446 of 23611 Old 09-04-2014, 07:20 PM
Zzzzz...'s Avatar
Quoted: 184 Post(s)
Liked: 56
Hi,
Thanks - I've already read through that (great guide BTW)
I don't suspect the issues I'm having are mac vs Windows specific...
Zzzzz... is offline
post #11447 of 23611 Old 09-04-2014, 07:29 PM
Liked: 4333
The two issues you mention sound like a cabling or connection problem. Try a different cable. Don't know what else to recommend.
post #11448 of 23611 Old 09-04-2014, 07:57 PM
Zzzzz...'s Avatar
Quoted: 184 Post(s)
Liked: 56
Regarding the mic not registering with REW, it currently is registering. In order to get it to work I had to apply additional force to the cable end that inserts into the mic.
Zzzzz... is offline
post #11449 of 23611 Old 09-04-2014, 08:06 PM
Alan P's Avatar
Liked: 3840
Try a different USB cable for sure.
Alan P is offline
post #11450 of 23611 Old 09-04-2014, 08:08 PM
Liked: 4333
I have a UMIK-1 as well. I found that you really need to make sure the USB plugs firmly into the base of the mic. Sounds like your experience was similar.
post #11451 of 23611 Old 09-04-2014, 11:15 PM
Zzzzz...'s Avatar
Quoted: 184 Post(s)
Liked: 56
Is this a common problem? I suppose I'll email CSL and see what they say...
Please find attached my first graphs. Currently I'm just trying to optimize sub placement. The graph shows 2 frequency responses with the sub in its original position (close to a side wall, roughly mid-wall) and with the sub placed in a corner. I originally didn't place the sub in the corner as I expected it would give me worse results but it looks like it gives me a smoother response. What do people think of these responses? Any feedback most welcome (I'm completely new to room optimization).
Note: the offset of the SPLs shown in the graph may or may not be correct. The test signal used was not that loud however.
Edit: the graphs are with Audyssey OFF (ie there is no EQ being used)
Name:	orig vs corner.jpg
Zzzzz... is offline
post #11452 of 23611 Old 09-05-2014, 12:18 AM
Bluescale's Avatar
Quoted: 736 Post(s)
Liked: 301
The blue FR sweep certainly looks better. It'd be important to see a waterfall also, to get an idea of decay, which is at least as important as the frequency response with a subwoofer. I the SPL shown here is correct, you may be running into noise floor issues. I know I tend to have some noise show up between 50 and 55 dB at some frequencies, and I also have a CSL UMIK-1. Can you measure again at a higher volume?
Bluescale is offline
post #11453 of 23611 Old 09-05-2014, 02:20 AM
Zzzzz...'s Avatar
Quoted: 184 Post(s)
Liked: 56
Thanks for the reply.
Attached is a graph at higher SPL - this time just of the sub in the corner (ie in the position that gives a better looking graph).
Note that REW told me I only had 1.5 dB of headroom when doing this measurement. When I tried to increase the volume further, REW gave me a clipping warning. Is this normal?
Name:	corner  higher SPL.jpg
Zzzzz... is offline
post #11454 of 23611 Old 09-05-2014, 05:30 AM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 241
If you can I would recommend the use of a digital connection rather than the analog. Does the iMac support a mini-toslink connector or has Toslink output?
The mini-toslink is what I use off my old Mac laptop and it works very well.
The UMIK really does require a lot of force to get the USB cable to snap in. I had similar problems until I realized that.
Cheers
Try toslink or mini-toslink and see if that improves things.
artur9 is offline
post #11455 of 23611 Old 09-05-2014, 05:33 AM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 241
Your measurements aren't conforming to the guidelines for this thread. Did you review AustinJerry's guide?
There's a link to it in his signature and, IIRC, on the first page.
artur9 is offline
post #11456 of 23611 Old 09-05-2014, 05:47 AM
artur9's Avatar
Quoted: 673 Post(s)
Liked: 241
2) use HolmImpulse
Does that work with multiple subs? More specifically, multiple subs fed with one signal?
artur9 is offline
post #11457 of 23611 Old 09-05-2014, 05:49 AM
3ll3d00d's Avatar
Liked: 646
I am not sure what you mean.
post #11458 of 23611 Old 09-05-2014, 06:18 AM
HDgaming42's Avatar
Quoted: 169 Post(s)
What are your room dimensions if I might ask? The fact you got that flat a response "by just throwing it in a corner" fills me with jealous rage.
Rage? Yes, I believe that is the word.
A month of crawling around my room, building bass traps, re-testing and adding multiple levels of EQ have not got me that flat a response in my room from hell.
post #11459 of 23611 Old 09-05-2014, 06:22 AM
Liked: 4333
Look at it a different way. Because the USB connector fits snugly, there is less risk of it becoming disconnected in the middle of moving the mic stand around during measurements. So no, I don't think it is a problem once you realize that you need to press hard to make sure it is seated properly.
post #11460 of 23611 Old 09-05-2014, 06:32 AM
Liked: 4333
Yes, adjust the input level so that no clipping occurs. Your level is fine. No need to measure below 15Hz--it is rare to have useful output lower than that.
The response from 20-50Hz is not bad, but the huge dip at 60Hz deserves some further investigation. As HD suggests, if you provide your room dimensions, it will be easier to tell if the dip is associated with a room mode. Dips are usually addressed by placement, so that's why dimensions are useful.
In order to have a better picture of the bass response, you should measure the sub along with the main speakers, preferably the center channel. Since the dip is likely to be in the vicinity of the crossover to the main speakers, it is possible that the combined response will show a smoothing of the dip. In other words, it may be a lot better than what your sub-only graph is showing. Also, what is the crossover frequency? And while you are at it, toss in a waterfall graph following the instructions in the guide.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
