Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 388 - AVS Forum | Home Theater Discussions And Reviews
 1718Likes
post #11611 of 21549 Old 09-12-2014, 02:24 PM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3324
Originally Posted by tommaazz View Post
HI. I was just playing the other day with rew and my laptop built in mic (i know i know ) ...i first calibrated again with audyssey xt32 and then i have done a rew measurement 10-200 hz and i saw a pretty big dip at about 30 hz...i have a sb12 nsd and a sb 13 ultra...so i played with sb13 ultra PEQ1 and set it at 31 hz Q 2,9 and level at -8 and then replayed the measurement....the dip was almost gone but...does that even make any sense? setting level at31 hz at -8 and getting a flatter response? It certanly is more impactful (have replayed some scenes) than with just audyssey setting but is that even possible? i am just curious (measurement was taken with FL FR and SW1 and SW2)
Does your AVR have SubEQ (will calibrate dual subs independently)? If so, and Audyssey got the distance for each sub right (rarely happens), they would be in phase. You sound like a good candidate for the sub distance tweak.
tommaazz likes this.
Alan P is online now
post #11612 of 21549 Old 09-12-2014, 02:26 PM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 186
Originally Posted by HDgaming42 View Post
I am convinced I can localize the sub when set to a 200Hz crossover, but perhaps it's in my head.
IIRC, 200Hz is well above what ppl consider to be the cutoff for localizable subs. I read somewhere that the true non-localizable frequencies start somewhere between 50-80Hz, depending.
I felt that I could localize mine which were set to 110Hz. I moved them up front and have them as flanking subs to my mains (which are bookshelves). I'm loving them that way.
For multiple placement of subs, I use Gedde's method which is described here. Basically, place the first sub where you get the flattest response. Then place the second sub and adjust its level et al to fill in the nulls. My summary is probably wrong but you get the idea, I hope.
The really nice thing about the multiple subs placed according to Geddes is that you get a very flat response, bass decay is handled nicely and the subs end up with a geat deal of headroom. I was watching Cabin in the Woods and the explosions and landslides were incredible! The explosions in The Family actually scared me.
My focus is 2ch music but since I have these subs I feel compelled to get good boom out of them
artur9 is offline
post #11613 of 21549 Old 09-12-2014, 04:13 PM
HDgaming42's Avatar
Quoted: 163 Post(s)
Cool. Checking out your links now. Sadly the flattest response is with the sub placed well behind the MLP.
I have one good sub (17-200 +/- 3dB) and one cheapo sub (maybe 30-200 +/- 3db?). I'd like the good sub to be in the region where it's flattest (behind MLP), but that means easier localization (bass coming from behind you is really weird!). Perhaps the two papers will address this...
@Alan P : I'll try your suggestion to revisit moving the mains (and MLP now that its height is messing things up where I had it).
HDgaming42 is offline
post #11614 of 21549 Old 09-12-2014, 06:04 PM
SeekingNirvana's Avatar
Quoted: 233 Post(s)
Liked: 124
I didn't see in the guide what all the HDMI outs do under the preference screen. It says HDMI 1 is left, and HDMI 2 is right, but what are the rest? I know they are for other speakers, but without me having to go through all of them can someone list what they are?
Also.....how would I play more then one at a time? Like if I wanted to have both fronts and my subs on the same sweep?
If my AVR has true dual sub outs, will the sweep go through both at the same time?
My dual sealed LMS 5400 Ultra build
http://www.avsforum.com/forum/155-di...0-build-4.html
SeekingNirvana is offline
post #11615 of 21549 Old 09-12-2014, 06:20 PM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
Channel 1: Front Left
Channel 2: Front Right
Channel 3: Center
Channel 4: Subwoofer
Channel 5: Surround Left
Channel 6: Surround Right
Channel 7: Surround Back Left
Channel 8: Surround Back Right
You can select two channels by setting the second channel as the timing reference. I don't think you can do more than 2 channels at once. Depending on how you have your speakers crossed over, if you play a full frequency signal, it'll engage the subs along with the other speakers for the low frequencies. I found that I almost never use Channel 4 to test the sub. Instead, I play the sweep on one of the other channels, and just turn off the amp going to my main speakers.
Depends. Are they set up as stereo subs, or are they set up for a mono signal? The LFE channel should play out of both of them, but if you have them set up as stereo subs, redirected bass will play out of the left sub for the left channels, and the right sub for the right channels.
Alan P likes this.
Bluescale is offline
post #11616 of 21549 Old 09-12-2014, 09:22 PM
Zzzzz...'s Avatar
Quoted: 152 Post(s)
Liked: 48
Originally Posted by AustinJerry View Post
If you do an internet search on bass resonance, bass ringing, etc., you will find a wealth of information that describes what it is, what causes it, and how it can be addressed. There are white papers on acoustics at the web sites of companies that deal in acoustics treatments (RealTraps, GIK Acoustics) that provide good information. Do some research--you will learn a lot.
As for whether you can actually hear the issues in the 40-50Hz range, only you can tell. My point was that the lower you go in the frequency range, the less frequent you will hear actual content there.
Using a mattress as a bass trap is certainly creative. I guess WAF is not an issue for you. Whether this improves the sound can only be determined by trying it. I suppose ringing would be somewhat lower in a padded cell.
Thanks - I'll do some more reading.
Regarding the 40-50 Hz question, I worded that badly. I really wanting to ask if those two dips should be noticeable?
Regarding the mattress, I was just trying to think of something that I already had at home that I could experiment with.
Originally Posted by markus767 View Post
If the foam is open cell then it would be effective when placed in a corner. Most mattresses are closed cell foam though.
If you can blow through it easily with your mouth directly at the mattress then it's open cell foam.
If I can't think of anything better, I'll try it out.
Originally Posted by LastButNotLeast View Post
I guess I shouldn't try that with my waterbed, then.
I suppose it depends on how adventurous you want to get. Perhaps you are on the verge of discovering a whole new class of bass treatments
Originally Posted by Alan P View Post
Notice that where Audyssey is boosting the dips is where the ringing gets substantially worse? You need to try (with placement, phase, distance) to get a flatter response pre-Audyssey. IME, the more EQ applied, the worse the ringing.
If you want to see something really disturbing check out your distortion graph, particularly those areas where Audyssey is over-boosting.
Being a beginner at this I'll probably first stick to trying to get a flatter response with less ringing
Zzzzz... is online now
post #11617 of 21549 Old 09-12-2014, 10:14 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6522 Post(s)
Liked: 3614
Alan, it is true that applying Audyssey correction can affect both the distortion levels and the bass ringing. But it is not always significant, nor is it always a detrimental effect. Here are some measurements from my system. First, the distortion measurements:
Note the dip at 77Hz that Audyssey corrects results in a modest increase in distortion, from .6% to 1.1%. And Audyssey lowers the peak at 55Hz with negligible effect on distortion.
Next, the bass ringing (Decay) measurements:
If anything, Audyssey improved the bass ringing.
Not every installation is the same, so everyone should look at these measurements as part of the REW analysis. We should not, however, get in the habit of saying that Audyssey (or room correction in general) always makes distortion and bass ringing worse.
ahblaza likes this.
AustinJerry is online now
post #11618 of 21549 Old 09-13-2014, 12:09 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
Thanks for response...yes i have subeq ht..i saw this distance tweak and it seemed complicated when reading a guide. What it seems odd is that i put -8 level at 31hz and it shakes more? I dont know should i just leave at audyssey setting because i only have laptop mic and stop playing with rew because i dont know how accurate is this metod with built in mic which is not omnidirectional
tommaazz is offline
post #11619 of 21549 Old 09-13-2014, 12:17 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
Makes sense if your sub is out of phase with your mains and you were measuring with your mains. Just the one sub, right?
That being said, any measurements you make with the internal mic can't be trusted in the least.
Ooops....just notice you have 2 subs. They are out of phase with each other!
Well.that makes sense as the svs said that sb12 and sb13ultra have different phase response and if they are far appart (mine are around 3.5m) the cacellation of the frequencies is less evident...so what should you do in my case? Should i just sell sb12 and have an ultra only? My room is around 1600 cubic feet and ultra is more than enough...but i can feel the difference with both subs playing.
tommaazz is offline
post #11620 of 21549 Old 09-13-2014, 05:14 AM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 186
The Acoustic Treatment master thread might have some suggestions.
IIRC, garbage bags filled with material might be sufficient to experiment with. Just be careful not to place them where the shiny bags can affect the higher frequencies.
artur9 is offline
post #11621 of 21549 Old 09-13-2014, 03:00 PM
nathan_h's Avatar
Quoted: 1014 Post(s)
Liked: 609
This is awesome, but what version of Soundflower are you using?
1.5.2 does not appear to play nice with Mavericks. I'm trying the 1.6.6 beta but so far it doesnt recognize an hdmi dongle on the displayport of my 2011 mac air.
Sorry if this has been addressed before, but I couldn't find it after a few days of searching. I've worked out a way to individually select each of the 8 channels individually on a Mac, when outputting over HDMI. This is similar to the workaround in the sticky as it uses Soundflower (download here). I used the latest version, which actually has support for 64 channel input and output.
This is pretty straightforward once you have Soundflower installed and running. You need to go to System Preferences ->Sound -> Output, and set this to Soundflower (64 ch).
Go to the MIDI controller via Applications -> Utilities ->Audio MIDI Setup, and select Soundflower (64 ch) as the output. In the image I’ve set the volume for channels 7 through 64 to zero, but it’s not necessary.
Next, open REW, and go to preferences. Set your output device as Default Device.
Now go to Applications -> Soundflower ->Soundflowerbed. This should load the application. It looks like an asterisk in your menu bar. When you click on that, you get a drop down. Mouse down and select HDMI under the Soundflower 64(ch) section. Now, click the asterisk again, and mouse down to the SoundFlower (64ch) and you get another set of options under routing. This is where the magic happens. Mouse over and set channels 2 through 64 to None. This deactivates each of those outputs. We only need one active at a time.
To begin with, I just ran a test tone from the REW generator to experiment. Go back to the Soundflowerbed icon and hover over Soundflower(64ch), mouse over to Channel 1, and you can select which output channel you want to route the sound to. For example, HDMI (1) corresponds to my L channel, HDMI (2) corresponds to my Center, and so on. I tried it with all 6 speakers in my living room setup.
The key here is to have only 1 channel activated at a time. The OS wants to send the sound to all 6 channels (or 8) at once, but Soundflower will let you turn all of them off (or on) individually.
Hope this is useful! This worked for me on a MacBook Pro running OS X 10.7.5. I'll be interested to know if it works for others.
input Configuration Update
I've noticed an intermittent issue where my UMM-6 is not recognized by REW. My Mac will immediately recognize it, and typically swaps the input in the system preferences to the UMM-6, but for some reason, REW does not see it despite all the other settings being correct. For now, the work-around has been to select the "Built-in Input" in REW. I'm not familiar with the other mics/sound cards, but this is how it's setup on my Mac.
Go to System Preferences -> Sound and make sure you click on the Input tab
Make sure your mic is selected (e.g. highlighted). You can also go to the MIDI controller via Applications -> Utilities ->Audio MIDI Setup and double check that your particular input device is active. Look for the microphone beside it.
Now open REW and go to the preferences. Select the Soundcard tab and under "Input Device and Input" you can select "Built-in input"
What's interesting about this is sometimes REW will recognize my mic when "Default Device" is selected in REW, and sometimes it won't. I haven't figured out why this is yet, but you have to make sure REW is not defaulting to your laptop/computer's built-in mic.
nathan_h is offline
post #11622 of 21549 Old 09-13-2014, 04:57 PM
3ll3d00d's Avatar
Quoted: 1566 Post(s)
Liked: 544
AIUI soundflower etc is no longer required with REW 5.01 beta 21 and higher. Details in the thread on HTS.
3ll3d00d is online now
post #11623 of 21549 Old 09-13-2014, 05:09 PM
nathan_h's Avatar
Liked: 609
Good to know. Ill try it without then. Thanks!
I was following AustinJerry's doc as precisely as possible and the latest edition, from last month, says it is required.
nathan_h is offline
post #11624 of 21549 Old 09-13-2014, 05:47 PM
Liked: 3614
The Guide does not support using REW on a Mac. It only has a courtesy link to J_P_A's tips. As mentioned previously, if you want guidelines on how to use a Mac, check out the threads on HTS.
post #11625 of 21549 Old 09-13-2014, 06:26 PM
ahblaza's Avatar
Quoted: 1497 Post(s)
Liked: 1596
Hello, I am very new to this REW myself and I tried to use the laptop's mic and it was not reliable at all, the UMIK is a very inexpensive tool to help with measurements. HDMI also is very convenient. I haven't taken a measurement yet as I procrastinate a lot and I'm taking my time as well and using Jerry's guide and so far all is working as planned, I just need to implement the tools I have and get moving along.
Cheers Jeff
ahblaza is offline
post #11626 of 21549 Old 09-13-2014, 06:36 PM
nathan_h's Avatar
Liked: 609
Fair enough.
According to the folks there, Soundflower is still required.
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is offline
post #11627 of 21549 Old 09-13-2014, 07:41 PM
Zzzzz...'s Avatar
Quoted: 152 Post(s)
Liked: 48
Thanks - that does sound like a good suggestion. I was also thinking about using lots of pillows and a beanbag. Also thanks for the link - didn't realize the thread existed.
post #11628 of 21549 Old 09-14-2014, 02:01 AM
3ll3d00d's Avatar
Liked: 544
Fair enough.
JohnM clearly states work arounds are no longer required but also says this is down to a new JRE so there is a working JavaSound setup on the Mac. This may mean 2 channel output only if it has the same capability as the PC version. It sounds like you're the pioneer here
post #11629 of 21549 Old 09-14-2014, 08:34 AM
HDgaming42's Avatar
Quoted: 163 Post(s)
I think I've resigned myself to buying multiple subs. Reading Geddes papers it seems you only need one sub that goes low into the first mode region -- that I have, an SVS PB2000.
The more subs the better, assuming placement that maximizes their independence from one another. It seem in the front of my room I have a problem with nodes around 80Hz and 120Hz.
Can I get away with buying cheapo "garbage" subs if I'm getting 3 of them and placing them around the room? Using REWs room sim this would seem to pan out with my good sub at the rear, center of the room, and the other subs a) front corner b) alongside mains c) middle wall.
I can get a Polk Audio PSW108 for $100--perhaps $75 with a price match. I'm reading complaints about port noise starting at 45Hz. Could I use the miniDSP to create a crossover for these subs to roll off before it reaches this point, thereby taking their greatest weakness out of the equation?
Would this be a good way to fill those 80 and 120Hz nulls while leaving the "heavy lifting" to the SVS? Buying three of these at $75 each really seems attractive to me as I had not budgeted for a second sub at all...
My time is limited nowadays, and I'm not sure when I'll ever get back to making more traps, which I know would help as well...
I'm guessing that the sub up front has the same dip around 80hz. Have you measured it alone?
The one sub in back is not enough to cancel the null created by your mains. You may want to try both subs in back, maybe stacked...?
Unless your mains are nailed to the floor, you should be able to get rid of the null produced by them. I understands aesthetics and all, but better response is better response.
I'm re-arranging my room based on a room sim and your suggestions. Just have to wait until I can blast the house with pink noise...
post #11630 of 21549 Old 09-14-2014, 09:04 AM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 186
I'm no expert so please bear in mind that these are just off the cuff opinions. You know what they say about opinions being like ... ?
I'm hoping Markus will offer some input as he seems to know this sort of thing very well.
Exactly, assuming you have the space for them. I always get a kick out of the simulation that Harman did with 5000 subs. I wonder where the MLP was in that?
You can certainly get away with smaller subs but I'm not so sure about "garbage". At a guess, I would think that the cheaper subs would have significant distortions in key regions.
I don't know what your price is but I have a Mordaunt Short that I got from accessories 4 less and an Outlaw Audio M8 that are both pretty clean at the frequencies I'm using them. Reaction Audio has some bigger subs at attractive prices.
I'd be concerned that you'd end up with subs that you'd have to toss rather than resell.
I wouldn't think you're want to roll off that high. Some piano notes go down to 25Hz, more or less. My M8 goes down to about 35Hz easily and that works well enough.
I think you do want subs that can handle the whole 25-120Hz range if you can. While you do tune them to different crossovers and levels I would think that a sub that can't reach <50Hz isn't going to help much.
You have 1 sub now? When I was in your position I waited and got good subs one at a time.
I started with the Outlaw Audio M8. That one by itself interacted so badly with the room that I didn't need REW to hear the problems. There were zero placement options that would work for the 2 money seats simultaneously.
Then I got a good deal on a pair of TBIs about a year/18months later.
In your position, I would spend the approx $250 on an Outlaw Audio or something similar.
artur9 is offline
post #11631 of 21549 Old 09-14-2014, 09:15 AM
nathan_h's Avatar
Liked: 609
Yeah it's interesting. No more workarounds required.... but everyone still uses the workaround.
Right now, I'm finding that the method for choosing a single channel via software is perhaps one of the main things to pay attention to.
Mike has as much confirmed that. Without the workaround, you can get a stereo signal. Period. The workaround can generate a complete signal on each channel. And the way one can get a single channel is......use the control settings for the system itself to mute all but one channel. Wish I was smart enough to automate that. It is going to take a very long time to iterate through EQ changes to each channel this way.
In any event, now that I've read the threads and posted the questions, and done the experiments, and we'll see what happens next. I'd really like to fix my response. I've got a lot of bass trapping (roughly ten OC bass traps) but still a wild waterfall in the bass region.
It is a bit tedious to have two separate forums, both owned by the same company (verticalscope), to work through, but I guess that's just historically how they have grown up.
Name:	all channels no eq one third smoothing.png
nathan_h is offline
post #11632 of 21549 Old 09-15-2014, 10:02 AM
Alan P's Avatar
Liked: 3324
This is because your subs are out of phase, by reducing the level on the one sub you are reducing the amount of cancellation to the other sub.
You need to get your subs in phase with each other before making any decisions. While playing pink noise, adjust the distance of the closer sub one foot at a time (try both directions) until you get the highest SPL at the MLP. This is much easier and accurate using REWs RTA function.
post #11633 of 21549 Old 09-15-2014, 10:13 AM
Alan P's Avatar
Liked: 3324
Thanks for clearing that up Jerry.
Regarding your examples - to be fair, your distortion example didn't need a whole lot of EQ and your distortion did almost double.
Your decay, while still acceptable overall did get considerably worse below 25hz post-Audyssey.
post #11634 of 21549 Old 09-15-2014, 10:54 AM
Liked: 3614
What you say is true, Alan. However, the point of my post was to show that applying Audyssey correction is not nearly as bad as your words imply. I did not see anything really disturbing, nor did I see evidence that Audyssey was over-boosting.
"If you want to see something really disturbing check out your distortion graph, particularly those areas where Audyssey is over-boosting."
post #11635 of 21549 Old 09-15-2014, 01:23 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Austin Jerry,
Maybe you can answer this for me. I posted this on another forum and everyone is stumped. When finishing my theater (again) a couple years ago I was using REW to tune my mains and subs. I kept dealing with a nasty dip around 30hz that I couldn't ever EQ out, so I assumed it was just a null and left it alone.
Fast forward to a couple weeks ago. I had family coming into town and was finally getting around to tuning an additional couple subs that I added to the back of the room. I pull out my UMM6 (pop in the calibration file), and start tuning.
Here's where it gets interesting. For the first session I decide to tune only the subs, so I select HDMI4 for the subs only. This run there is no dip at 30. I'm happy and figure the rear subs addressed the dip there. So after I have a pretty solid baseline, I decide to run a sweep with the left main. As soon as I do, low and behold, the nasty dip at 30hz appears. I'm thinking it's an interaction issue between my main and sub, so I decide to do the same sweep (HDMI1), but with the main amp turned off. Even with the main not running, I get the same dip at 30hz. Now obviously I can tune around this knowing there is really no dip there, but what would be causing this anomaly. The questions it raises are; is that the only inaccurate reading I'm getting or are the rest of my measurements off as well?
For the record, this has happened with 2 different EQ setups and 2 different receivers (Onkyo 3009 and dual SMS's to Yamaha A5000 and Mini DSP 4x10), so it's obviously not something related to either of those. Only thing that hasn't changed is my laptop and the REW program.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #11636 of 21549 Old 09-15-2014, 02:22 PM
Selden Ball's Avatar
Quoted: 3065 Post(s)
Liked: 1496
bass addict,
I'd like to think that it's a low frequency interaction between your main speakers and the room, but that seems to be ruled out by your description of your procedure. Nonetheless, there are some details that you didn't explicitly mention.
Most importantly, are your front main speakers biamped? (i.e. might turning off the "main" amp have affected only the high frequency output?)
When you ran the sweep with the front left speaker, did you have bass management enabled (which would have involved the subwoofers) or was only the left front speaker active?
What's the crossover frequency between your main speakers and the subwoofers?
How low can your main speakers go when not supplemented by the subwoofers?
When you ran the sweeps that saw the 30Hz dip, are you absolutely certain that both subwoofers were active or could it be that only one of them was generating any output? (and its null is what you're seeing/hearing).
Alan P likes this.
Selden
Selden Ball is online now
post #11637 of 21549 Old 09-15-2014, 02:47 PM
Liked: 3614
Unfortunately, I can't test out what you observed. My laptop only supports stereo HDMI, so I cannot output to the LFE channel using HDMI4.
I think Seldon has asked some appropriate questions. Assuming your mains are set to Small, then when you run the test signal to HDMI1, you should be getting re-directed bass to all subs as well as the left front speaker. By turning off the left front speaker, the bass signal to all subs should be identical to the signal going to all subs over the LFE channel using HDMI4.
So, something must be different when you are using HDMI1. Looking forward to your answers to Seldon's questions.
post #11638 of 21549 Old 09-15-2014, 03:06 PM
Quoted: 360 Post(s)
Liked: 437
Originally Posted by Selden Ball View Post
bass addict,
Mains are not biamped. When I kill my Outlaw amp it shuts everything down entirely.
Bass management was enabled as all speakers are set to small.
80hz.
I believe the F3 is right at 80hz. They are AE 15" drivers in around a 3cf sealed enclosure if memory serves me correctly.
I'm 99% sure all three subs were active. I know they are on HDMI 4 but maybe HDMI 1 only runs the front 2 (two front are on sub out 1 with rear sub on sub out 2). I don't think so though as the overall SPL didn't drop any with the dip (which would indicate all subs are active).
The other weird thing which is totally unrelated; every so often when running a sub sweep, the output goes wonky and gets distorted and fades in and out. I have to unhook my mic, plug it back in, and recalibrate the reading before it works right again.
post #11639 of 21549 Old 09-15-2014, 04:20 PM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
Output on HDMI4 should be 10dB higher than output on HDMI1. The LFE output is 10dB hotter.
I've found something similar happens to me from time to time, although nut just when I'm running sweeps on the subs. I've found that if I go to preferences and change the output channel, and then click on measure, it does some sort of a reset. I don't even have to run a sweep, but going into the measurement dialog is necessary. I can then change it back to my original HDMI channel, and no issues. Hopefully that saves you a bit of time from unplugging and recalibrating needlessly.
post #11640 of 21549 Old 09-15-2014, 04:26 PM
Quoted: 360 Post(s)
Liked: 437
That's weird as I've never shown a 10db change when switching between output 1/2/3 and 4. I'll have to go back and double check that.
I assumed they would have accounted for that in the programming to keep all sweeps at the same SPL to make comparisons easier between the sub/mains and both.
Thanks, I'll try that.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
