Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 390 - AVS Forum
 111Likes
post #11671 of 11689 Old 09-17-2014, 06:10 PM
artur9's Avatar
Quoted: 45 Post(s)
Liked: 40
Originally Posted by jim19611961 View Post
I would say there is pudgy, fat and obese. Slightly pudgy, if in the lowest registers, I could see as nice. Obese up to 200hz, that wouldn't be so good, no
Mine was going for Sta Puf covered with fuzz, I think.
artur9 is offline
post #11672 of 11689 Old Yesterday, 07:16 PM
WarmongerX's Avatar
To those that have used REW, is it worth the time, effort and investment to get the $95 mic and spend time learning the software? Or is using the receivers built in calibration tools (MCACC, Audyssey, etc) + SPL meter + some manual fine tuning a better route. I've been reading about it for the past day and it seems easy and complicated at the same time and I'm wondering if it's worth the effort and hours spent configuring everything.
Will you hear the difference between either way?
Samsung 65" ES8000 - Pioneer Elite VSX23-TXH - 7.1 Definitive speakers - PM 1000 L/R - PC 1000 - ProSub 800 - PM 800's Surround & Surround Back
WarmongerX is online now
post #11673 of 11689 Old Yesterday, 07:24 PM
LastButNotLeast's Avatar
Quoted: 174 Post(s)
Liked: 245
Basically, this is what REW allows you to do, only accurately.
You can get as serious with REW as you like. If you "just" want to get a flat frequency response curve, okay, aim for that. If you get interested and want to pursue decay rates and the like, you can, but you don't "have" to.
It's just another aspect of the hobby. I have a meter and I calibrate my video. I have a mic and I calibrate my audio. Most of the time, it's fun. It's always interesting. And the result is that I'm getting the best performance possible out of the equipment that I have, modest though it may be.
For the $100, you may as well try it and see if it strikes your fancy. I'm sure you can sell the mic if you decide that it's really not for you.
Bluescale likes this.
Downloadable FREE demo discs:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Did you really need to quote that entire post in your reply?
LastButNotLeast is offline
post #11674 of 11689 Old Yesterday, 07:26 PM
nathan_h's Avatar
Quoted: 82 Post(s)
Liked: 88
For those wondering, Soundflower is still required on a Mac if one wants to send output to particular channels in a surround setup. Finally got it all working and it's SO MUCH easier than removing patch cords etc!
____________________
Build Thread:
nathan_h is online now
post #11675 of 11689 Old Yesterday, 07:53 PM
WarmongerX's Avatar
Thanks, I'll give it a shot. Noticed that Cross Spectrum is out of the UMIK-1's right now though.
post #11676 of 11689 Old Yesterday, 08:13 PM
Quoted: 174 Post(s)
Liked: 245
Here's the other one that's popular:
http://www.parts-express.com/dayton-...phone--390-808
They even give you 45 days to play with it.
Hint: google for a coupon code.
Michael
post #11677 of 11689 Old Today, 03:38 AM
AustinJerry's Avatar
Quoted: 607 Post(s)
Liked: 740
Using REW and using AVR calibration tools are entirely different things. Every listening room has audio characteristics that affect audio quality. The placement of your speakers, and the amount of room treatments can correct for audio issues. REW is a tool to assess the audio quality and assist you in determining whether adjustments in speaker placement and treatments are resulting in improvements.
Any thing you do to get your listening room in the best audio shape before you run automated room correction, the better the correction results will be. But REW room-tuning does not REPLACE room correction. If you have automated room correction, you should still use it, because it is the "icing on the cake" that corrects other audio issues that cannot be fixed with speaker placement and treatments.
So, long answer, but the proper approach is to use both, because they compliment each other.
Edit: I should add that using both REW and automated calibration together always results in a better solution. Unless you have an exceptionally good listening room, automated calibration by itself rarely corrects all the audio issues.
Bluescale, IgorZep and spotts29 like this.
AustinJerry is online now
post #11678 of 11689 Old Today, 03:41 AM
Quoted: 607 Post(s)
Liked: 740
Michael
It has been discussed many times in this thread--there are advantages to ordering the mic from Cross Spectrum Labs because you receive customized calibration files with your purchase. The price difference is not significant. Either the UMM-6 or the UMIK-1 microphones are functionally equivalent.
post #11679 of 11689 Old Today, 06:21 AM
Quoted: 174 Post(s)
Liked: 245
Right. And he can't get the UMIK and the UMM can be returned within 45 days.
Also, the calibration files from Dayton have been shown to be perfectly adequate for the beginning hobbyist.
So he can get his hands on one now, give it a try, and see if he wants to keep it or get a calibrated UMIK eventually.
I, personally, am not especially good at waiting.
Michael
post #11680 of 11689 Old Today, 06:44 AM
jkasanic's Avatar
Quoted: 41 Post(s)
Liked: 62
He could also send the mic from Dayton (or anywhere else) to Herb at CSL for calibration if availability is an issue.
jkasanic is offline
post #11681 of 11689 Old Today, 07:27 AM
HDgaming42's Avatar
Quoted: 116 Post(s)
I find it fascinating. I was drawn to REW because I didn't like the sound of my room and my new subwoofer purchase. REW let me see exactly what was happening in my room and helped me fix (or greatly address) the issues.
Everyone's hearing is unique. My wife doesn't hear a difference and couldn't care less. I am much happier. Just be aware that depending on your personality, you can very easily get hooked on using REW and fiddling with your stereo more than using it. If I'd never gone down this rabbit hole I probably wouldn't be contemplating purchasing 3 more subwoofers!
WarmongerX likes this.
HDgaming42 is offline
post #11682 of 11689 Old Today, 07:28 AM
Quoted: 174 Post(s)
Liked: 245
That would no longer be cost-effective (see, I'm not only impatient, but cheap, too. ).
post #11683 of 11689 Old Today, 07:55 AM
Alan P's Avatar
Quoted: 442 Post(s)
Liked: 235
Originally Posted by warmongerx View Post
to those that have used rew, is it worth the time, effort and investment to get the $95 mic and spend time learning the software? or is using the receivers built in calibration tools (mcacc, audyssey, etc) + spl meter + some manual fine tuning a better route. I've been reading about it for the past day and it seems easy and complicated at the same time and i'm wondering if it's worth the effort and hours spent configuring everything.
yes!!
AVR:
FL/R:
CC:
SUR:
x 4
SUB:
x 4
DISP:
Alan P is online now
post #11684 of 11689 Old Today, 08:38 AM
nathan_h's Avatar
Quoted: 82 Post(s)
Liked: 88
Michael
Dayton's calibration is fine these days, yes, for a single mic position.
Cross Spectrum measures at multiple angles, which is a time saver if you want to measure many different speakers without moving the mic each time.
Heck I was surprised how close the mic was to linear WITHOUT the Cross Spectrum file. Certainly close enough that any obvious problems were still obvious!
Build Thread:
post #11685 of 11689 Old Today, 08:45 AM
lemonslush's Avatar
Quoted: 172 Post(s)
Liked: 45
Is the goal here to match the flat black line it give you?
I have been playing with it for several hours now and this is much better looking than it was before
Its just one sub. i tried doing multiples at once and it was a total mess.
ID:	269281   Click image for larger version
lemonslush is online now
post #11686 of 11689 Old Today, 11:42 AM
WarmongerX's Avatar
LOL!
Thanks for the all the replies everyone. I will get one and spend the time learning and playing with it. Like most of you , I love to tinker around and am very picky about sound and video of my home theater, so this is probably naturally right up my alley. I will be replacing my entire front soundstage, including sub, in the next six months, so this appears it will be a valuable tool in getting the best sound out my new purchases.
post #11687 of 11689 Old Today, 12:05 PM
Quoted: 607 Post(s)
Liked: 740
What the heck does this mean, Nathan?
post #11688 of 11689 Old Today, 12:28 PM
nathan_h's Avatar
Quoted: 82 Post(s)
Liked: 88
Cryptic, yes! Let me explain what I meant (hopefully better) based on my understanding:
Cross spectrum does measurements at zero degrees and 90 degrees (and others). Most companies just do the zero degree measurement.
The difference: When measured at zero degrees, you have to point the mic at each speaker you are measuring. When measured at 90 degrees, you can point the mic at the ceiling, and measure any speaker that is at 90 degrees to the mic (typically all speakers in the room) without moving the mic.
Build Thread:
post #11689 of 11689 Old Today, 12:43 PM
Quoted: 607 Post(s)
Liked: 740
You are correct that the proper measurement technique is to use the 90-degree calibration file, point the mic at the ceiling, and measure the speakers from the MLP. However, just because you don't have a 90-degree calibration file doesn't mean you should point the mic at the speaker for a measurement. Just use the zero-degree calibration file, but continue pointing the mic at the ceiling. There is a link in the Guide that shows the very minor difference at the extreme high end that is a result of using the zero-degree calibration file--it is not very significant.
The only time you would point the mic directly at a speaker is when you are taking a near-field measurement to assess a speaker's frequency response independent of room effects, or to measure a speaker's dispersion characteristics.
Alan P likes this.
Reply Audio theory, Setup and Chat
Dayton , Dayton Audio , Room Equilizer Wizard Rew
User Tag List
