Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 402 - AVS Forum
 187Likes
post #12031 of 12052 Old 10-22-2014, 06:44 AM
bloodta's Avatar
Quoted: 14 Post(s)
Originally Posted by Frank D View Post
Graphs look really good with both subs and Audyessy engaged, but the really question is how does it sound to you? Have you have a chance to do any extensive testing (ie watching movies etc)?
I'm the kind of guy who doesn't want to feel as though I'm missing something. I think it sounds great, I just want it to be dialed in.
bloodta is online now
post #12032 of 12052 Old 10-22-2014, 06:51 AM
AustinJerry's Avatar
Quoted: 801 Post(s)
Liked: 810
Personally, I would be concerned with the 15-20dB rise as the curve approaches 20Hz. If this is an intentional house curve, then that is fine. Otherwise, I would be working to flatten it out. Perhaps you can post a waterfall graph to see how the rising low frequency response affects bass ringing. Also, an ETC graph would allow us to see how well you have controlled room reflections.
AustinJerry is online now
post #12033 of 12052 Old 10-22-2014, 12:34 PM
ahblaza's Avatar
Quoted: 252 Post(s)
Liked: 256
Guys, excuse my ignorance but I'm really new to REW, I opened the program today and upon opening it said a newer version is available, version V5.01 Beta 23, it mentions inprovements in certain areas and certain bug fixes especially the 6dB down with calibration mic, since Jerry said that if an SPL meter is used with the calibration of the mic this 6dB down would not have an effect. So should I update to this current version, is this the version all are using? Also can you give me a link (I'm not there yet) with the adapter needed to take the pre-out measurements after connecting a RCA cable to the pre-out I want to measure, I know I'm way ahead of myself but want to have everything I need. TIA
Cheers Jeff
j_nordi
ahblaza is online now
post #12034 of 12052 Old 10-22-2014, 02:02 PM
Quoted: 801 Post(s)
Liked: 810
Yes, generally you should always upgrade to the latest version of REW. I don't know which cable/adapter you are talking about, but Pre-out measurements are an advanced topic, and only used in very special situations. You should focus on walking before you try to run.
Bluescale and ahblaza like this.
post #12035 of 12052 Old 10-22-2014, 04:16 PM
bloodta's Avatar
Quoted: 14 Post(s)
How should I set the graph limits for the ETC graph?
post #12036 of 12052 Old 10-22-2014, 04:18 PM
Quoted: 801 Post(s)
Liked: 810
The guidelines for each type of REW graph are in the guide.
post #12037 of 12052 Old 10-22-2014, 04:54 PM
bloodta's Avatar
Quoted: 14 Post(s)
Not sure about this ETC graph, is it correct?
post #12038 of 12052 Old 10-22-2014, 05:35 PM
Quoted: 801 Post(s)
Liked: 810
Did you follow the guide, p. 76? What you are presenting isn't even close to the example shown in the guide, and cannot be interpreted as shown.
post #12039 of 12052 Old 10-22-2014, 05:55 PM
bloodta's Avatar
Quoted: 14 Post(s)
To be honest, I'm not seeing anything about an ETC graph on page 76. I was looking at post #2 on page 1.
post #12040 of 12052 Old 10-22-2014, 06:18 PM
Quoted: 801 Post(s)
Liked: 810
I am not understanding. Have you actually looked at the guide? It is linked in my sig.
post #12041 of 12052 Old 10-22-2014, 06:27 PM
bloodta's Avatar
Quoted: 14 Post(s)
Im very sorry, its been a long day, I just downloaded it and see exactly what you're saying. Great guide by the way, that'll come in very handy. Thanks
post #12042 of 12052 Old 10-22-2014, 06:54 PM
Quoted: 801 Post(s)
Liked: 810
OK, we are on track now. Please don't be reluctant to ask questions.
post #12043 of 12052 Old 10-23-2014, 01:22 PM
bloodta's Avatar
Quoted: 14 Post(s)
I appreciate it. Here's my graph.
post #12044 of 12052 Old 10-23-2014, 01:36 PM
Quoted: 801 Post(s)
Liked: 810
Now draw a horizontal line at the -20dB mark, and extend it out to 20ms. Any measurement that extends above this line is something that would benefit from reflection control treatments. In your example graph, there is quite a bit of work to be done.
Thanks for re-doing the graph. When we are all using similar presentation techniques, interpretation is much easier.
post #12045 of 12052 Old 10-23-2014, 01:58 PM
bloodta's Avatar
Quoted: 14 Post(s)
That was a left front speaker graph. The speaker is 2 ft from the left wall. The left wall is a knee-wall. It goes up 6 feet then it angles 2 feet to the ceiling, the angled part is untreated, the straight part is treated. I believe this untreated angled part is the culprit. I did the string trick and it didn't touch any hard surfaces.
post #12046 of 12052 Old 10-23-2014, 02:50 PM
Quoted: 801 Post(s)
Liked: 810
There are a lot of different approaches to finding and resolving reflections. One method that I find particularly effective is I have a couple of spare 2'x4' wall treatments. I simply place a treatment temporarily in a spot I suspect might be causing a reflection, and re-measure with REW. If you are committed to finding reflections (and bass resonances using the waterfall graph), improving things can be a lengthy process. But with each improvement, the reward is a better sounding listening room.
Here is a typical measurement in my room (and mine is nowhere as good as someone's like Jim19611961!):
post #12047 of 12052 Old 10-23-2014, 03:12 PM
bloodta's Avatar
Quoted: 14 Post(s)
After playing with my treatments, heres a graph
post #12048 of 12052 Old 10-23-2014, 04:38 PM
ahblaza's Avatar
Quoted: 252 Post(s)
Liked: 256
To my untrained eye that second graph is much improved over the first, correct?
j_nordi
post #12049 of 12052 Old 10-23-2014, 05:13 PM
Quoted: 801 Post(s)
Liked: 810
I agree, it looks quite a bit better. What did you do so quickly?
post #12050 of 12052 Old 10-23-2014, 05:21 PM
bloodta's Avatar
Quoted: 14 Post(s)
Ha, I cheated. I made a tunnel out of my 2x4ft, 2" oc703 around the speaker, and took some measurements. Sort of a proof of concept, to see if my panels are doing their job. I noticed some had a thin black backing on them, would those be considered faced?
post #12051 of 12052 Old Yesterday, 06:52 PM
steveting99's Avatar
Quoted: 280 Post(s)
Liked: 112
Guys,
I've done an experiment in moving some furniture around and in trying to see if there can be an improvement in the ETC graph.
1st ETC measurement. Using the center channel (set as small) with sub and Audyssey switched ON, the following is the ETC graph with the existing furniture as is in the room.
The 1st troublesome reflection point for the center channel is very close the speaker - about a foot away. I thought it could be the coffee table so moved it and re-measured.
2nd ETC measurement. Same as the 1st, but with the coffee table removed.
Think I'm going in the right direction here. There was a change in the response of the ETC in the first two milliseconds. The ETC graph for the center channel is now much better and the next troublesome reflection is just over 2' away. Might try the string technique to identify where this reflection point is.
Maranatz NR1504, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
steveting99 is online now
post #12052 of 12052 Old Yesterday, 07:22 PM
Quoted: 801 Post(s)
Liked: 810
Originally Posted by steveting99 View Post
Guys,
You have the right idea, Steve. There are two pretty severe reflections remaining in your second graph. Don't forget the ceiling as a possible reflection point--it was one of my worst.
Reply Audio theory, Setup and Chat
Dayton , Dayton Audio , Room Equilizer Wizard Rew
User Tag List
