Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 410 - AVS Forum
 240Likes
post #12271 of 12280 Old Today, 06:09 AM
LastButNotLeast's Avatar
Quoted: 262 Post(s)
Liked: 279
Originally Posted by markus767 View Post
Try to get a used Onkyo TX-NR818. It came with XT32.
A second sub will probably improve things the most.
You're in luck, they have one left:
http://www.accessories4less.com/make...eceiver/1.html
Greenwood Ave likes this.
Downloadable FREE demo discs:
http://www.avsforum.com/t/1475769/de...ently-authored
Did you really need to quote that entire post in your reply?
LastButNotLeast is offline
post #12272 of 12280 Old Today, 08:53 AM
artur9's Avatar
Quoted: 79 Post(s)
Liked: 44
The man's name is Floyd Toole.
Apologies. So Toole, Olive and Geddes are the spiritual leaders of this thread?
Other than that treating the back wall is a very good idea especially when one is sitting close to it.
One other thing. I found that my panel's ETC measured a little better when slightly separated. So, instead of 12' of contiguous panels the panels have a 10" gap between them. More gap or less gap was worse.
artur9 is online now
post #12273 of 12280 Old Today, 09:37 AM
Greenwood Ave's Avatar
Quoted: 18 Post(s)
Originally Posted by AustinJerry View Post
Unfortunately, due to the shape of your room, and the sloping ceiling, I am not sure that this helps very much. It does show that you have a first-order standing wave at 47Hz associated with the length of the room. Moving the couch forward may alleviate this somewhat. You seem to be sitting pretty far away from the screen. How large is that screen? And the distance to the left and right speakers could be closer to the equilateral triangle if you move the couch forward.
Here are a couple pictures of my our family room that I posted before on the other thread. Till a month ago this used to be what we called the "mud room." My wife's happy to have the TV/speakers out of the living room, and I'm sure happy to be able to crank my music after the kids go to be since I'm now on the opposite side of the house.
The pictures were taken before I put up 2' x 3' 4" absorption panels on either side of the couch as well as the clouds. I also put heavier polyester blackout curtains up. Come to think of it, I should measure the ETC with the curtains open and closed to see if this really made any difference. My ears tell me a little.
I will try moving the couch up, but it would be a awkward to do this more than a foot. I know it is not considered great to have the couch so close to the wall. I may actually consider putting a panel behind the curtains in font of the window. I will measure this. Assuming the ETC is what to look at here? My main thought though is still to build two 2' x 4' 4" absorption panels on either side of the back wall. I will try angling them out a bit to create the air pocket back there. Or I also am considering framing them with a 6" width wood so a air pocket will be created that way. Not sure if that's enough space to do much good.
The way I'm thinking now, I will most likely look at another PB-1000 sub in the next few months. Seems most people here think this will make the most difference, which makes sense to me. My only hesitation is that the corner to the right seems to be such a crappy place to put a sub that I do wonder if this could be counterproductive. Still, my thinking is that this would make more of a difference to SQ than moving to XT32. (Of course I'm sure some people might look at that picture and think I'm out of my mind to consider a second sub with a TV that old, but hey, I'm more of a music guy than movie. A new TV will come too.)
This week I will definitely try out the blocking technique when I spare moment. Thanks for that, Jerry. And thank you to everyone who has helped me here.
Name:	Screen Shot 2014-11-05 at 9.37.43 PM.png
ID:	382993   Click image for larger version
Name:	Screen Shot 2014-11-05 at 9.37.14 PM.png
Greenwood Ave is online now
post #12274 of 12280 Old Today, 09:42 AM
Quoted: 262 Post(s)
Liked: 279
One of the many nice things about SVS is that you can try it and return it if it doesn't work out.
Instead of replacing your AVR, you might want to add a parametric equalizer to the subwoofer output. I used to use this one:
https://www.google.com/webhp?hl=en&t...=en&q=dsp1124p
Should still be available used at Guitar Center and other places.
post #12275 of 12280 Old Today, 09:51 AM
Quoted: 18 Post(s)
Would that work well used in addition to Audyssey XT? That link isn't working for me for some reason.
post #12276 of 12280 Old Today, 10:26 AM
Quoted: 262 Post(s)
Liked: 279
Yes. You need the other EQ for the other speakers; this just goes to the subs.
Here's one:
http://www.musicgoroundlincoln.com/p...r-feedback-pro
post #12277 of 12280 Old Today, 11:05 AM
artur9's Avatar
Quoted: 79 Post(s)
Liked: 44
Dunno if this posting by Dr. Olive has been mentioned here:
A Method For Training Listeners and Selecting Program For Listening Tests
Listener Performance Is Strongly Influenced by Program SelectionThe single largest effect on the listener’s performance was the program selection. Slide 13 plots the mean listener performance scores for each of the twenty programs averaged across all eight equalizations. The percentage of correct responses ranged from a high of 88% (pink noise) to a low of 54% (jazz piano trio). Listeners performed the task best when using broadband, spectrally dense continuous signals like pink noise or pop/rock selections like Tracy Chapman, Little Feat, and Jennifer Warnes. Listeners performed worse on programs featuring solo instruments, small combos and speech that produced more discontinuous and narrow band signals. More about this later.
post #12278 of 12280 Old Today, 01:36 PM
AustinJerry's Avatar
Quoted: 957 Post(s)
Liked: 879
I think you need to pause and think about all the suggestions you have received, and especially not make any big purchases or put up any new treatments without a specific game plan.
For example, when you placed the treatments on the side walls, did you determine their exact placement using a mirror?
Next, only place a treatment on the back wall if it provides a measurable difference in the reflections. With that window directly behind you, you may not have any reflections to correct.
Third, with respect to moving the couch forward, we are not asking you to commit to anything permanent. We are asking you to simply take several measurement with the mic placed in front of the MLP, more towards the front of the room, without moving the couch. If those measurements show a significant reduction in the 50Hz issue, then you can decide if the improvement warrants moving the couch.
Fourth, you have heard from several people now that an additional sub (placed properly) is likely to produce the most improvement. Consider this purchase before upgrading your AVR to XT32. Both are significant expenses, and you want the most bang for the buck (if improved bass is your objective).
And finally, if you decide on getting an inexpensive DSB unit, I strongly recommend the MiniDSP, which is less than $150, simply because there is a large community here on AVS that can help you configure it properly.
AustinJerry is online now
post #12279 of 12280 Old Today, 01:51 PM
jkasanic's Avatar
Quoted: 91 Post(s)
Liked: 73
Probably, but to address the 50Hz peak, you would need to re-position the sub, add another sub, or add treatments. So we are really saying the same thing, no?
My point was that I don't believe he's using any sort of EQ so applying a cut there would reduce the initial impulse and thus reduce the ringing.
EDIT: Now I feel like Keith...should've turned on the now infamous "read ahead mode".
jkasanic is offline
post #12280 of 12280 Old Today, 01:59 PM
jkasanic's Avatar
Quoted: 91 Post(s)
Liked: 73
+1
jkasanic is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
