Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 411 - AVS Forum
 240Likes
post #12301 of 12303 Old Yesterday, 08:11 PM
AustinJerry's Avatar
Quoted: 972 Post(s)
Liked: 882
Originally Posted by aaranddeeman View Post
All righty..
Yes my AVR has Audyssey MultEQ XT
I will get to the next measurements tonight at some point.
Thank you for being patient with me.
Take your time. You should run the calibration before any more measurements. I assumed you have familiarized yourself with Audyssey best practices by reading the materials in the Audyssey thread. Following guidelines can make a difference between good and poor results.
AustinJerry is online now
post #12302 of 12303 Old Yesterday, 09:04 PM
aaranddeeman's Avatar
Quoted: 125 Post(s)
Liked: 26
Oh. I already took the measurements. But anyways I can repeat both after calibration as well.
But check them out in the mean time.
ID:	387481   Click image for larger version
ID:	387489   Click image for larger version
aaranddeeman is offline
post #12303 of 12303 Old Today, 06:20 AM
jkasanic's Avatar
Quoted: 91 Post(s)
Liked: 73
Some pretty steep roll off above 6kHz?? What is the spec of your mains?
Just a tip on using REW, it's almost always better to take a full range measurement and restrict your graph limits when focusing on the bass region. This way when someone asks to see the full range, the measurement is already done. It wasn't clear from your post if that's what you did so disregard if that's the case.
jkasanic is offline
Dayton , Dayton Audio , Room Equilizer Wizard Rew
