Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 418 - AVS Forum | Home Theater Discussions And Reviews
 1722Likes
Old 12-05-2014, 09:00 AM
tvuong's Avatar
Quoted: 1546 Post(s)
Liked: 878
Austin Jerry,
are they not supposed to? The dip from FR graph and the resonance from the decay graph at 100hz that is? Sorry I am still new to this stuff.
tvuong is offline
Old 12-05-2014, 09:19 AM
tvuong's Avatar
Liked: 878
Originally Posted by Alan P View Post
Can you post this graph with Audyssey off?
I did not take that measurement for the latest Audessey run. I did in the past with subs in different place and found XT32 with subeqHT did an excellent job flatten the FR. Have you thought about upgrading your avr to a xt32 subeqHT one and not using minidsp for your upcoming T18's? It is very affordable now.
tvuong is offline
Old 12-05-2014, 09:24 AM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3326
Yeah, with the $$$ I spent on the T-18s there ain't gonna be any more upgrades for me for a very long time. With that said...I have thought about XT32...sure.
The reason I wanted to see the Audyssey Off graph is because I wanted to see if Audyssey is boosting a big null at 100hz (as I think it was at 50hz before). I think you did good with the new sub placement, but you may have just swapped one null for another.
Alan P is online now
Old 12-05-2014, 09:26 AM
tvuong's Avatar
Liked: 878
Originally Posted by markus767 View Post
Would need to see the scope graph. Could you also upload the .mdat of your last measurement somewhere?
Is there a way to go back to view that scope to change the horizontal limit? That .mdat file has 30 measurements in it. Is that what you want me to upload?
tvuong is offline
Old 12-05-2014, 09:32 AM
Alan P's Avatar
Liked: 3326
On the decay graph, you ideally want the 160ms slice (the blue slice) to be down 20db from the red slice. You can see that just below 100hz, you're only about 10db down. Since it wasn't like this before you moved the subs (although it was similar, but at 58hz), this leads me to believe that Audyssey is boosting the heck out of a null at 100hz.
Overall, your decay improved by moving the subs....if it wasn't for that nastiness around 100hz, you'd be golden.
Before moving subs:
Old 12-05-2014, 09:36 AM
tvuong's Avatar
Liked: 878
I take the 100hz null over 50 any day, would you? does it matter though for the 100hz null if I crossover my front 3 @ 80hz?
tvuong is offline
Old 12-05-2014, 09:42 AM
markus767's Avatar
Quoted: 3636 Post(s)
Liked: 1295
No. Help > Graph Panel > Scope:
"This graph shows the generated sweep test signal and the raw captured system response as acquired via the soundcard, which may be useful for troubleshooting. This is not a live display, it updates with new content after a sweep has completed. Only the signals for the last measurement are shown. The Y axis is the percentage of digital full scale. The generated sweep is shown normalised so that its peak value is 100%. If the captured trace reaches +100 or -100% it is clipping and the sweep level or AV processor volume should be reduced."
Why not but I'm only interested in the sub response with and without MultEQ, so 2 of those 30 would be enough.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old 12-05-2014, 09:48 AM
tvuong's Avatar
Liked: 878
Dang, I am not ready to run another sweep for the scope. If I do, what would the horizontal scale needs to be? How do I upload the .mdat file that contains only 2 out of 30 measurements?
tvuong is offline
Old 12-05-2014, 09:53 AM
markus767's Avatar
Liked: 1295
So that the whole recording is visible.
Delete all measurements except those two and save to a new .mdat file.
Markus
Old 12-05-2014, 09:54 AM
3ll3d00d's Avatar
Quoted: 1566 Post(s)
Liked: 544
you can either click delete 28 times and then save a new mdat
or
save the 2 you want into separate mdat's, delete everything from the workspace, open each one in turn & then save a new mdat with the 2 measurements
3ll3d00d is online now
Old 12-05-2014, 10:24 AM
tvuong's Avatar
Liked: 878
Duh? I didn't even think about that.
tvuong is offline
Old 12-05-2014, 11:11 AM
LastButNotLeast's Avatar
Quoted: 1487 Post(s)
Liked: 1085
Originally Posted by JAMES MCHUGHES View Post
Anyone have time to point me in the right direction ?
Welcome aboard.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Old 12-05-2014, 02:12 PM
tvuong's Avatar
Liked: 878
@Alan P ,
I did measure. Here it is subs only graphs.
@markus767 , Is this the graph you wanted to see?
Here is the graphs after subs distance tweak for comparision. It does help bring up the subs 80hz dip. The rest, XT32/SubeqHT does wonders
Blue: Center and subs Audessey ON
Green: Left Right and subs Audessey ON
Name:	2subs upfront aud on and off.png
ID:	404346   Click image for larger version
Name:	distance tweak with 2 subs upfront no smoothing.png
tvuong is offline
Old 12-05-2014, 02:20 PM
3ll3d00d's Avatar
Liked: 544
@Alan P ,
the distortion plots from your compression sweeps would be informative (with respect to what I think Alan is quizzing you on)
having said that, I'd be kicking back and cranking out some choons/films if I were you
Old 12-05-2014, 02:25 PM
tvuong's Avatar
Liked: 878
^^ I wish I can right now.
tvuong is offline
Old 12-05-2014, 02:28 PM
Alan P's Avatar
Liked: 3326
I agree!
But if you want to try and perfect the response more, and you have more placement options....you could try to get rid of that null at 100hz pre-Audyssey. With Audyssey over-boosting to try and fill it in, it's undoubtedly creating distortion....how audible that distortion would be is up for debate.
Old 12-05-2014, 02:41 PM
3ll3d00d's Avatar
Liked: 544
I agree!
I would say highly unlikely, the boost would be centred somewhere in the vicinity of g# I think (http://auditoryneuroscience.com/topi...-western-music) and must be v high Q (as the effect spans maybe 10Hz at most).
It is an exceptionally flat response though, be interesting to see if Markus digs anything up out of the scope view (which I thought was just clip detection so always thought that REW alerts in that case)
Old 12-05-2014, 02:53 PM
Alan P's Avatar
Liked: 3326
Hey guys,
What does this impulse response tell you about these subs?
What about this one?
ID:	404482   Click image for larger version
Old 12-05-2014, 02:58 PM
3ll3d00d's Avatar
Liked: 544
Hey guys,
I would say nothing. The time window is way too wide, the IR is centred on 0 but you have cut off the negative portion, one looks like it is mains + sub and the other is something else (maybe a sub alone?).
Take a step back, what are you trying to do? where do those results come from? what frequency range was swept? is it EQ'ed or not? where was the mic? etc
Old 12-05-2014, 03:02 PM
Alan P's Avatar
Liked: 3326
I sold 2 of my XS15s to a buddy and went over last weekend and took some measurements. Here's a comparison of his old sub vs. the PSAs:
The 2 impulse responses are old sub vs. new, just wanted to know what they mean. What settings should I use so they display correctly?
Name:	ray old new fr.jpg
Old 12-05-2014, 03:05 PM
Alan P's Avatar
Liked: 3326
With the old sub, it was sub + mains. With the new subs it was subs + CC. Audyssey off in both cases. Mic at MLP. Sweep was 0-300hz.
Old 12-05-2014, 03:06 PM
markus767's Avatar
Liked: 1295
Well you would need to measure the same devices if you want to compare them. If you want to compare sub performance then measure just the subs.
Markus
Old 12-05-2014, 03:08 PM
Alan P's Avatar
Liked: 3326
Yeah, we knew the PSAs would be a significant upgrade so just took the one measurement with the old sub.
Here's the MDAT if anyone's interested:
https://www.dropbox.com/s/rl2docvvq9x41nt/REW.mdat?dl=0
Old 12-05-2014, 03:15 PM
markus767's Avatar
Liked: 1295
What's the diference between MLP1, 2 and 3? Is it with MultEQ or not? Any differences in location between old and new sub?
Markus
tvuong's Avatar
Liked: 878
No more other placement options as this is my third placement for them and it is the best of them all. Regarding the 100Hz null, It doesn't matter as my front three speakers are taking from there from their 80Hz crossover as shown in the LR & Subs and Center & Subs graphs
Much Thanks.
tvuong is offline
Old 12-05-2014, 03:18 PM
markus767's Avatar
Liked: 1295
The label in the .mdat says "Old LR+Sub AudOn"?
Markus
Old 12-05-2014, 03:24 PM
Alan P's Avatar
Liked: 3326
Yeah, sorry....Aud was on for that first measurement with the old sub.
Old sub was in front right corner. PSAs are in both front left and right corners.
All other measurements are Aud off.
EDIT: We did determine after measuring that his version of Audyssey (6-7 year old Onkyo) did absolutely nothing to his bass response...and, as a matter of fact, made the rest of his FR look horrible.
The last unlabeled measurement was subs + CC after distance tweak.
Old 12-05-2014, 03:25 PM
markus767's Avatar
Liked: 1295
So what is the difference between "MLP1, 2 and 3"?
Markus
Old 12-05-2014, 03:27 PM
Alan P's Avatar
Liked: 3326
Three different seats in the front row of his theater. MLP1 is the far left seat.
Old 12-05-2014, 03:29 PM
markus767's Avatar
Liked: 1295
So you were basically comparing apples and oranges. One sub vs. two, different brands, different EQ, maybe even different mic location.
Markus
Dayton , Dayton Audio , Room Equilizer Wizard Rew
