Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 421 - AVS Forum | Home Theater Discussions And Reviews
 1722Likes
post #12601 of 21563 Old 12-09-2014, 08:50 AM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3326
Originally Posted by tvuong View Post
You could save up for a pair of T18's. Denon X4000 can be had new for $650-$700 plus you can sell your 2113. Seriously, You spent a great fortune on a pair of top notch subs and cheap out on what driving them? It will also makes your Horns sing even better. There is enough evidence to confirm xt32/subeq HT is a real deal so there is no excuse NOT to complete your craving for not much more
Ummmm.....SHUT UP!!
Alan P is offline
post #12602 of 21563 Old 12-09-2014, 09:30 AM
T0S
T0S's Avatar
Quoted: 21 Post(s)
Originally Posted by 3ll3d00d View Post
What sub do you have?
I have a Velodyne HGS18. Thanks.
T0S is offline
post #12603 of 21563 Old 12-09-2014, 10:35 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
Thought id share a acoustics calculator site. Among the offerings, it provides an interesting Axial mode visual.
http://www.acoustic.ua/recommendations/800
Audionut11 likes this.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #12604 of 21563 Old 12-09-2014, 12:54 PM
T0S
T0S's Avatar
Quoted: 21 Post(s)
what I would do is determine exactly whether Audyssey sees that spike as something to correct or not. I think this is quite unlikely but still worth verifying. If your room is a cuboid then just use the rew room sim. In a rectangular room that spike equates to a room dimension of ~7-8m. Do you have such a room?
If not then I'd take 7 measurements, 1 at the MLP and 1 each about 0.75-1m away in each dimension (up/down, left/right, forward/back). I would then compare the <50Hz responses and compare them to your audyssey mic positions to see if you have the corner case of an extreme spike in 1 position but a dip in other positions & hence audyssey is choosing not to correct.
as per my previous post though... I would be looking to use a secondary EQ to tame that peak when using audyssey. Throw a BFD at it (or a minidsp in new money) and sort it out properly.
Yes excellent idea about measuring the individual positions - missed reading this post earlier. I did notice during the set up that the right hand side positions required Audyssey to pull up the chirp volumes. I'll make sure to compare those to the rest. Thanks.
T0S is offline
post #12605 of 21563 Old 12-09-2014, 01:38 PM
aaranddeeman's Avatar
Quoted: 1614 Post(s)
Liked: 558
Received umik-1 yesterday. Do you use that black foam cover when taking measurements or w/o it?
aaranddeeman is offline
post #12606 of 21563 Old 12-09-2014, 01:58 PM
Alan P's Avatar
Liked: 3326
Or...do I as suggested and just run a single mic position Audyssey cal and see if the response improves.
T0S likes this.
Alan P is offline
post #12607 of 21563 Old 12-09-2014, 02:00 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6544 Post(s)
Liked: 3626
If you are talking about the dust cover, I leave it on. However, it is acoustically transparent, so it doesn't really matter. When setting the mic to ear-level height, measure with the dust cap off, since it adds a bit to the height.
AustinJerry is offline
post #12608 of 21563 Old 12-09-2014, 02:01 PM
Liked: 3626
I spent a bit of time providing some recommendations earlier today. No comment from you?
post #12609 of 21563 Old 12-09-2014, 02:08 PM
ssjp55's Avatar
Quoted: 74 Post(s)
Liked: 24
That is the wind screen and either way should be fine. Does that really make enough difference to add to the height?
ssjp55 is offline
post #12610 of 21563 Old 12-09-2014, 02:29 PM
Liked: 3626
Depends. If you are obsessive like me, then 1/4 inch is a big deal. In reality, probably not.
post #12611 of 21563 Old 12-09-2014, 03:25 PM
Alan P's Avatar
Liked: 3326
Geez, Jerry....you got your head is a vise while your listening to your system or what?
Alan P is offline
post #12612 of 21563 Old 12-09-2014, 04:27 PM
tvuong's Avatar
Quoted: 1546 Post(s)
Liked: 877
I have been thinking about adding a third FV15hp for a while now. With my almost flat FR, do you guys think it will improve if my normal listening level is -15 or -10 max? The third one will be near field in the left rear corner (only place I can put in my room). Since both of my front subs are equal distance to MLP, they can be fed off from my avr sub1 output, and sub2 output for the third one. What y'all think?
tvuong is offline
post #12613 of 21563 Old 12-09-2014, 04:43 PM
Liked: 558
Yes. That's the dust cover I was talking about.
Thanks for the response.
Also is the narrow_band_90_degree calibration file is correct one to be used?
post #12614 of 21563 Old 12-09-2014, 04:51 PM
Liked: 3626
You can never have too many subs. I have four 15-inch sealed units. Exactly as you suggest, the front two are on one sub output and equidistant from the MLP, the other two are collocated in the rear on the other sub channel. Works quite well.
Check this: AustinJerry's Set-Up
post #12615 of 21563 Old 12-09-2014, 04:52 PM
Liked: 3626
Yes.
post #12616 of 21563 Old 12-09-2014, 04:54 PM
Alan P's Avatar
Liked: 3326
Truer words have never been spoken.
Alan P is offline
post #12617 of 21563 Old 12-09-2014, 05:12 PM
tvuong's Avatar
Liked: 877
I asked the question in the wrong place. I should have known better Very nice set up there, Jerry. Seriously, what is the benefit(s) though by adding a third knowing that I have a flat FR with two and don't listen that loud?
tvuong is offline
post #12618 of 21563 Old 12-09-2014, 05:51 PM
Liked: 3626
Well, if you are satisfied with your current bass response, there is no reason to add more subs. You need to be the judge.
post #12619 of 21563 Old 12-09-2014, 06:08 PM
tvuong's Avatar
Liked: 877
That's the hard part
tvuong is offline
post #12620 of 21563 Old 12-09-2014, 06:34 PM
Liked: 3626
I went back and downloaded your measurement file, and I don't see an opportunity for significant improvement by adding any additional subs.
post #12621 of 21563 Old 12-09-2014, 06:56 PM
tvuong's Avatar
Liked: 877
^^ thanks for taking your time, Jerry. Much appreciated.
tvuong is offline
post #12622 of 21563 Old 12-10-2014, 02:50 AM
T0S
T0S's Avatar
Quoted: 21 Post(s)
Sorry I haven't responded yet - absolutely taking in your comments back to the REW SIM and then looking to see if there is another sub posiion I should try before I report back the results. It'll have to be this weekend.
Based on you comments, I'll try to reduce the 50Hz peaks at least to see if Audyssey will then do a better job in the low bass range.
T0S is offline
post #12623 of 21563 Old 12-10-2014, 02:57 AM
T0S
T0S's Avatar
Quoted: 21 Post(s)
Based on you comments, I'll try to reduce the 50Hz peaks at least to see if Audyssey will then do a better job in the low bass range as per the attachment
Name:	Room sim to reduce 50Hz peak.png
T0S is offline
post #12624 of 21563 Old 12-10-2014, 03:13 AM
T0S
T0S's Avatar
Quoted: 21 Post(s)
Oh yes - that's the easiest and will do that first. Thanks for this.
T0S is offline
post #12625 of 21563 Old 12-10-2014, 03:28 AM
3ll3d00d's Avatar
Quoted: 1566 Post(s)
Liked: 544
there are 3 reasons I can think of for adding moar subs
1) FR improvements
2) headroom (i.e. reduce distortion at your chosen listening level)
3) increased tactile feel
clearly 1 doesn't apply (and you may even make it worse)
2 doesn't obviously apply either given that you can hit ~114dB without compression which suggests distortion is unlikely to be an issue at that level, I think the highest output I've seen demanded by an actual film is ~120dB at reference for the EoT sweeps so you have headroom over and above even that scene
3 is impossible to judge from REW, it is certainly true that people seem to a nearfield sub so if you're in a concrete bunker then this could be a nice upgrade
to confirm 2 then you could post distortion graphs for that +5MV sweep
3ll3d00d is online now
post #12626 of 21563 Old 12-10-2014, 06:59 AM
Liked: 3626
50Hz looks better, but 25 Hz is still an issue. Are there reasons you can't consider moving the MLP forward? The 25 Hz peak must be noticeable. Maybe you aren't interested in very low bass?
post #12627 of 21563 Old 12-10-2014, 07:37 AM
tvuong's Avatar
Liked: 877
1) FR improvements
Thanks so much for the detail explanation. It does make lot of sense. I see if I can try that compression sweeps again that includes +5 sweep as I have not with my latest subs placement. Looking back at my +5MV sweep, I was average about 110db with a few rises up to 115dbs. I understand where to look for compression but what I am not certain is that when looking at the highest sweep, do you look at its peak output or its average one?
I was surprised that I have more tactile feeling now than when I had one sub near field. Probably because I upped another +3db in my low shelf filter. Since you also use jriver, I have bandwidth set at 1 for my 35hz +6db gain low shelf. Have you played with low shelf in jriver? I am not so sure q=1 is correct/good (the reason I want to use REW to measure jriver output some day). Thanks again.
tvuong is offline
post #12628 of 21563 Old 12-10-2014, 08:03 AM
3ll3d00d's Avatar
Liked: 544
compression will show up as a reduction in output. Take the audioholics review of the SB13 for example
http://www.audioholics.com/subwoofer...iew_fullscreen
the response severely compresses between 20-40Hz from the red line (110dB) indicating that the sub must employ some boost centred on ~25-30Hz and that then combines with some limiter to prevent it being overloaded. The response then becomes the typical sealed sub response (with a much higher rolloff) rather than the boosted to flat response shape at lower output levels.
IIRC yours didn't show any evidence of this showing that you had headroom for ~110-115dB. Checking the distortion at those levels will give another indication of stress.
this thread explains how the LS works in jriver - http://yabb.jriver.com/interact/index.php?topic=88589.0 - and gives you a link to the minidsp spreadsheet which lets you play around with how it works. This was one of my old measurements showing a +10dB LS at 30Hz with Q=0.5 or Q=1
The LS you have will basically rise 6dB from ~50 to ~20Hz.
post #12629 of 21563 Old 12-10-2014, 09:28 AM
tvuong's Avatar
Liked: 877
It sure did not with my last subs location. I will run another sweep with my current subs location and post with distortion graph
Attachment 413073
Thanks for the link. Definitely will read it. Is the LS graph you posted the output from jriver? I really need to measure my jriver output to see at what frequency I reach 6db gain on my 35Hz LS.
So you were looking at the peak in that +5MV graph, right? cuz the average is ~110db. I still dont understand the 120db at reference for Edge of Tomorrow part where you mentioned I have headroom over and above that scene. How does hitting 114db without compression translate to having over and above headroom for the 120db EoT scene? Thanks so much.
Name:	compression sweep up to 5db mv.png
tvuong is offline
post #12630 of 21563 Old 12-10-2014, 09:39 AM
3ll3d00d's Avatar
Liked: 544
yes that is from jriver, yours will be a v similar shape to the gold line in my graph except scaled down to +6dB rather than +10dB
your graphs say your system is off by a few dB, if I were you I'd run a full range sweep at -30 (MV at -30 and REW sweep at full strength) on a main channel, smooth it and check that your measurement is centred on 75dB (or use the RTA method with 1/1 octave smoothing)
in a bass managed system, your subwoofer has to be able to deal with the LFE channel + the redirected bass from the mains. In a 7.1 system, if every single channel was given a 0dBFS signal at the same time then your sub would need to be able to deal with ~125dB if you were playing at reference. I don't think there is any disc that has such content though so designing a system to cater for that much output is overkill. The opening sweep from EoT is one of the hottest tracks out there atm as it combines IIRC the C and LFE at 0dBFS, this produces something like 120dB on paper. My point was that your compression result suggests you can produce at least ~110dB cleanly and you want to listen at maybe -10. The hottest track out there asks for 120dB which is 110dB at -10 and therefore you have no headroom issue atm.
Dayton , Dayton Audio , Room Equilizer Wizard Rew
