Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 429 - AVS Forum
 271Likes
post #12841 of 12857 Old Yesterday, 01:10 PM
tvuong's Avatar
Quoted: 278 Post(s)
Liked: 128
If I missed it in the guide, I apologize but I can't seem to find the part to interprete distortion graph. I am trying to understand my graph below. Thanks.
tvuong is offline
post #12842 of 12857 Old Yesterday, 01:22 PM
3ll3d00d's Avatar
Quoted: 324 Post(s)
Liked: 92
do you understand what harmonic distortion is? have you read the REW help on the subject?
the graph is basically just telling you how loud the various components of harmonic distortion are & how they vary by frequency, i.e. it's exactly the same information as a frequency response chart but showing the harmonic distortion instead
3ll3d00d is online now
post #12843 of 12857 Old Yesterday, 02:10 PM
artur9's Avatar
Quoted: 87 Post(s)
Liked: 46
I wonder if it's possible to add such examples to the guide?
Has anyone here had ringing this bad? Most of the graphs I've seen here have only a few frequencies extending out past 450ms. This one has seems to have it going every 35Hz or so.
Originally Posted by markus767 View Post
No, THIS is modal ringing
artur9 is offline
post #12844 of 12857 Old Yesterday, 02:34 PM
ssjp55's Avatar
Quoted: 63 Post(s)
Maybe I am just not understanding things correctly, but does the fact that this graph is showing down to 20 db and in the noise floor have something to do with the resonance?
ssjp55 is offline
post #12845 of 12857 Old Yesterday, 02:38 PM
Audionut11's Avatar
Quoted: 88 Post(s)
Liked: 53
No. It is that big long peak at around 35hz that's the point of interest, and that is well out of the noise floor.
Audionut11 is offline
post #12846 of 12857 Old Yesterday, 02:52 PM
markus767's Avatar
Quoted: 1011 Post(s)
Liked: 396
The measurement isn't level calibrated and as Audionut said, the interesting part is the mode at 33Hz that rings on forever.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is online now
post #12847 of 12857 Old Yesterday, 03:15 PM
jim19611961's Avatar
Quoted: 155 Post(s)
Liked: 89
Click on the graph. It will show at the bottom the various distortion figures for the frequency you click on. The numbers on THIS graph are meaningless without knowing where the target was when you saved the pic.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, (2) Classe CA-100 bridged power amps (350w)
Jenzen Next
jim19611961 is offline
post #12848 of 12857 Old Yesterday, 03:34 PM
SherazNJ's Avatar
Quoted: 42 Post(s)
Quick question about water fall graph. Its X-axis shows Hz and Y-axis shows db. Based on room floor noise, we ignore anything under that noise (since its not audible). Is there also a limit on X-axis that we can ignore?
In other words, Assuming floor noise = 50db, if we have a decay of 45 at 40Hz, we can ignore it since its below floor noise. Similarly is there a point on X-axis that we don't need to worry about below certain point even if it exceeds 50db?
thx.
SherazNJ is offline
post #12849 of 12857 Old Yesterday, 03:59 PM
AustinJerry's Avatar
Quoted: 1146 Post(s)
Liked: 922
If everyone thinks there is value, I can add this example to the guide.
AustinJerry is offline
post #12850 of 12857 Old Yesterday, 04:14 PM
Quoted: 155 Post(s)
Liked: 89
I am not sure we all agree on how to read the graph. IMO, its not about what extents out to 450ms, or any other time (within reason), but when the ridge starts both in time and in magnitude. But I do feel we will all agree the graph with the 35hz ridge is a good example of a very BAD result. That is an extreme example though. Likewise, its easy to look at graphs with no ridges or extension and agree that would be a good one. At the other extreme. But 99% of us are going to be between these extremes. And that is where help will do some good in graph interpretation.
My Room
My Music
Jenzen Next
post #12851 of 12857 Unread Yesterday, 07:27 PM
tvuong's Avatar
Quoted: 278 Post(s)
Liked: 128
Got cha. What order(s) of harmonic distortion (2nd, 3rd, etc...) is most important that I need to pay attention to? 3rd? based on Dood's comment below?
Originally Posted by 3ll3d00d View Post
Generally speaking there is some debate about the absolute audibility of distortion at low frequencies. However what isn't up for debate is that high levels of distortion are a clear sign of impending distress for your sub, in my experience you are in the danger zone when you by past 10% and then really clearly in trouble at 30%. This percentage refers to how much quieter the distortion is vs the fundamental tone, 10% distortion = -20dB and 30% = -10dB.
I mention 60Hz as you seem to have a clear spike in the distortion there upto ~5%, this must be audyssey boosting. You can then see you reach ~10% distortion at ~16Hz so this is getting the limits of your system at reference. Note that 3rd harmonic is escalating rapidly under 20Hz, AIUI 3rd harmonic is predominantly mechanical non linearity (i.e. magnet losing control of driver aka reaching xmax) so this shows that ~12Hz or so sees your drivers losing it.
Dood, Based on your comment about the 10% distortion limit, If I interprete correctly, I am safe down to 14Hz (I based it on the THD)? Seem fine @60Hz, is it not?
Thanks so much.
Name:	distortion @10hz.png
ID:	428290   Click image for larger version
Name:	distortion @12hz.png
ID:	428298   Click image for larger version
Name:	distortion @13hz.png
ID:	428306   Click image for larger version
Name:	distortion @14hz.png
ID:	428314   Click image for larger version
Name:	distortion @18hz.png
Name:	distortion @60hz.png
tvuong is offline
post #12852 of 12857 Unread Yesterday, 07:30 PM
Skylinestar's Avatar
Quoted: 222 Post(s)
Liked: 73
Is there a need to do soundcard calibration for REW setup if I were to use HDMI to my AVR and UMIK1 mic.
Is this in a concrete bunker?
Skylinestar is online now
post #12853 of 12857 Unread Yesterday, 08:09 PM
Liked: 922
Soundcard calibration is not required when using the USB/HDMI Kit.
post #12854 of 12857 Unread Today, 12:35 AM
markus767's Avatar
Liked: 396
Yes, this is the important message for people trying to understand waterfall graphs. They need to understand that each single waterfall slice contains not only energy from that specific point in time but from several hundreds of milliseconds before (rise time) and after (window).
Markus
post #12855 of 12857 Unread Today, 12:39 AM
markus767's Avatar
Liked: 396
Most basements in Europe are poured concrete so this is unfortunately rather the norm than an exception. Those wooden tents Americans call their homes are much better for good bass reproduction
Markus
post #12856 of 12857 Unread Today, 04:13 AM
Audionut11's Avatar
Quoted: 88 Post(s)
Liked: 53
Looks like they are cubes also.
post #12857 of 12857 Unread Today, 04:53 AM
3ll3d00d's Avatar
Quoted: 324 Post(s)
Liked: 92
generally speaking
* the higher the harmonic, the more noticeable it will be hence you need to keep them to a relatively lower level than lower harmonics.
* harmonic distortion is relatively less noticeable at v low frequencies (though might be much much more audible when you get into infrasonics)
* I don't think there is a straight answer to individual preference/tolerance for different levels of distortion
seems a reasonable conclusion to me
Dayton , Dayton Audio , Room Equilizer Wizard Rew
