Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 430 - AVS Forum | Home Theater Discussions And Reviews
 1869Likes
post #12871 of 22103 Old 12-19-2014, 10:38 AM
markus767's Avatar
Quoted: 3766 Post(s)
Liked: 1347
Originally Posted by tvuong View Post
Have a dumb question for all of the Denon owner, X4000 especially, how do you change ALL speakers level without starting the receiver test tone?
You don't. Most receivers don't allow adjustment of speaker gain without annoying the user with a noise signal.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #12872 of 22103 Old 12-19-2014, 10:51 AM
Alan P's Avatar
Quoted: 4881 Post(s)
Liked: 3505
Originally Posted by AustinJerry View Post
As the guide says, you should be using "Speaker Cal" Pink Noise output at -30dBFS.
So sorry Jerry, shoulda known it was in the Guide.
BTW, it says to set my AVR to "Stereo" but when I do that and select the CC in REW (CH3) the pink noise comes through my FL/R. Am I doing something wrong?
I just set it to multi-channel and it works fine for me.
Alan P is offline
post #12873 of 22103 Old 12-19-2014, 11:25 AM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
I am finding spectrograms more and more useful when looking at decay and reflections (mids and highs). While ETC slicing is an interesting way also, the spectrogram is a one step easy snapshot. Above are 3 different mdats I have access to. All three of these rooms have had treatment.
I am beginning to question the usefulness of full range ETC's. All 3 of the above rooms look pretty good looking at full range ETC's. But the spectrograms tell different stories I think.
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #12874 of 22103 Old 12-19-2014, 11:32 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6889 Post(s)
Liked: 3824
Yes. Recall that I only have 2.0 support on my laptop HDMI. There are a number of spots in the guide where I say Stereo, when laptop users with full 7.1 HDMI functionality should choose Multi CH. I should clean up the guide, but am focused on some other priorities right now. Glad you figured it out.
AustinJerry is online now
post #12875 of 22103 Old 12-19-2014, 11:49 AM
markus767's Avatar
Liked: 1347
Yes, I also do use the spectrogram quite often. If only there were a normalize function. This would make comparisons much easier.
Markus
post #12876 of 22103 Old 12-19-2014, 12:29 PM
tvuong's Avatar
Quoted: 1590 Post(s)
Liked: 922
Every AVR I have ever used has a section in the menu that outputs level-setting tones to individual speakers, and has a trim setting allowing for the levels to be adjusted. Sure, when you use this menu, the AVR test tone temporarily overrides the RREW tone, but one you change the trim, you are back to the REW test tone. I am not following why this is an issue.
Got Cha. Thanks.
tvuong is online now
post #12877 of 22103 Old 12-19-2014, 12:33 PM
tvuong's Avatar
Liked: 922
Originally Posted by ambesolman View Post
The iOS app DeRemote will allow you to do this. Not sure if it's on other platforms.
Attachment 431194
Sent using Tapatalk since the mobile version is still
That is very nice. Why can't the Denon remote or gui do that is another question.
post #12878 of 22103 Old 12-20-2014, 05:11 AM
RyanCo's Avatar
Liked: 24
Attachment 431218
Attachment 431226
Attachment 431234
Hey Jim, RyanC from GS, I believe the 2nd spectrogram there is mine. That is interesting to see that, I think more than anything else that is diffraction/reflections from my workstation/desk, I attached a picture. In the next round of refinements I intend to (try) to make it both more acoustically transparent via having the structure have smaller reflective dimensions, as well as motorized height adjustable for the center part. Sitting all day every day is (literally) killing me!
But also some of that mid-range messiness might be due to rear wall (and some side wall) slats (they all should be over about 15ms). Even if it might clean up the measurement a little to take them down, I wouldn't want to. I found the dead room was harder for me to mix in, and extra-difficult with attending clients who weren't adjusted to it. At some point the best *fix* is going to come from getting into a room that is bigger than 200sf and 1600ft^3. I Have been shopping, the goal for the next control room will be more like 400sf a 4000ft^3.
Name:	setup + vax.jpg
RyanCo is offline
post #12879 of 22103 Old 12-20-2014, 07:04 AM
Liked: 3824
Attachment 431218
Attachment 431226
Attachment 431234
Jim, Those Spectrograms look different than the ones I generate. Did you use REW to create them? Here is what mine look like:
Other than looking at resonance, which is what we have been using them for, what else do you see in the Spectrogram that reveals something about the listening room?
post #12880 of 22103 Old 12-20-2014, 07:17 AM
Quoted: 449 Post(s)
Liked: 153
I included the control settings in my spectrograms. The ones I made were meant to show early and mid length reflections across the frequency band where as yours, and the way they are set are more about late room decay and resonances. The spectrogram is a versatile tool that shows different things depending on how it is set.
So yes, I made those with REW and if you make your control settings match mine, you will get this picture as well.
My Room
My Music
Jenzen Next
post #12881 of 22103 Old 12-22-2014, 06:50 AM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
@jim19611961
Over at GS, you mention the transition frequency as 250hz. Your room dimensions suggest an Schroeder's frequency of around 151hz.
Nice work btw.
Audionut11 is offline
post #12882 of 22103 Old 12-22-2014, 06:59 AM
LastButNotLeast's Avatar
Quoted: 1544 Post(s)
Liked: 1151
Looks like the "Guide" needs another chapter.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #12883 of 22103 Old 12-22-2014, 07:01 AM
Quoted: 449 Post(s)
Liked: 153
Originally Posted by Audionut11 View Post
@jim19611961
Nice work btw.
Name:	Schroeder frequency.JPG
This calculator says its 84hz. In any case, I am not going to get early reflections to -20db down to 84hz
This does provoke another thought. If the transition frequency or Schroeder's frequency (Defined as approximately the boundary between reverberant room behavior above and discrete room modes below) designates at what point you begin to hear the room more vs hearing the speakers. Then it also stands to reason that it also defines the point at which you begin to lose a sense of directionality. My reasoning is once room modes begin to dominate what you hear, then directionality queues from the speaker begin to become compromised.
Saril likes this.
My Room
My Music
Jenzen Next
post #12884 of 22103 Old 12-22-2014, 07:05 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
Attachment 431194
this doesnt work with the x4100...unless there has been an update which I havent had yet
nvm just saw there was an update...ill see if it does it now..that would be huge!
Brian Fineberg is offline
post #12885 of 22103 Old 12-22-2014, 07:12 AM
markus767's Avatar
Liked: 1347
Attachment 435057
Why only -20dB? Research suggests that depending on the signal you'd need to get to -30dB. And, by the way, your reverberation time is way to high
Markus
post #12886 of 22103 Old 12-22-2014, 07:31 AM
Quoted: 449 Post(s)
Liked: 153
Done
My Room
My Music
Jenzen Next
post #12887 of 22103 Old 12-22-2014, 07:37 AM
markus767's Avatar
Liked: 1347
Phew, thanks
Markus
post #12888 of 22103 Old 12-22-2014, 07:50 AM
Quoted: 449 Post(s)
Liked: 153
Phew, thanks
On a more serious note, doesn't the needed DB down requirement/recommendation depend on the frequency in question?
My Room
My Music
Jenzen Next
post #12889 of 22103 Old 12-22-2014, 07:53 AM
markus767's Avatar
Liked: 1347
Frequency, type of signal, probably even direction. And, the less reflections the more single ones become audible. Our hearing is actively scanning for patterns it can associate with known aural spaces and situations.
Markus
post #12890 of 22103 Old 12-22-2014, 07:57 AM
Quoted: 449 Post(s)
Liked: 153
Hence, one of the reasons for a strong kicker
My Room
My Music
Jenzen Next
post #12891 of 22103 Old 12-22-2014, 08:08 AM
markus767's Avatar
Liked: 1347
It's a nice effect but I would want the recording to provide the kicker. It should be the content creator's prerogative to decide how his art sounds.
Markus
post #12892 of 22103 Old 12-22-2014, 08:26 AM
Quoted: 449 Post(s)
Liked: 153
How it sounds depends much on how it is reproduced in ones listening environment.
My Room
My Music
Jenzen Next
post #12893 of 22103 Old 12-22-2014, 12:29 PM
IgorZep's Avatar
Quoted: 386 Post(s)
Liked: 185
If it does then the question is... Where is the FIdelity?
IgorZep is online now
post #12894 of 22103 Old 12-22-2014, 12:37 PM
markus767's Avatar
Liked: 1347
Lost in reproduction.
Markus
post #12895 of 22103 Old 12-22-2014, 04:33 PM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
Master handbook of acoustics. I linked it earlier.
post #12896 of 22103 Old 12-22-2014, 08:43 PM
Liked: 1151
Too bad we can't get a content creator to sit in our theaters for a proper evaluation.
post #12897 of 22103 Old 12-23-2014, 01:30 AM
markus767's Avatar
Liked: 1347
You're jumping to conclusions. Single lateral reflection in an anechoic environment. That's what those studies looked at. Quite different from sound reproduction in living rooms.
Markus
post #12898 of 22103 Old 12-23-2014, 01:32 AM
markus767's Avatar
Liked: 1347
With proper reproduction standards he wouldn't need to.
ambesolman and IgorZep like this.
Markus
post #12899 of 22103 Old 12-23-2014, 03:03 AM
Audionut11's Avatar
Quoted: 162 Post(s)
Liked: 65
I'm not jumping to anything markus. I've sparked discussion.
I'm somewhat surprised you jumped all over it's singularity, rather then the fact that it is speech.
They study lots of things in the PDF I linked. Single lateral reflections being one of them.
post #12900 of 22103 Old 12-23-2014, 03:08 AM
markus767's Avatar
Liked: 1347
That's good but I've been through this discussion multiple times so please forgive me if I don't sound as enthusiastic as you might expect. Rest assured that I know all those references down to the single papers.
Markus
Dayton , Dayton Audio , Room Equilizer Wizard Rew
