Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs - Page 446 - AVS | Home Theater Discussions And Reviews
 320Likes
post #13351 of 13361 Old Yesterday, 03:02 PM
AustinJerry's Avatar
Quoted: 1642 Post(s)
Liked: 1026
Originally Posted by Alan P View Post
Apparently.
When the subs are set to 75db they just don't satisfy like they do at 80-81db. I know I'm not alone.
I see folks on here saying that they are running their subs "3db hot" or "6db hot", I was just wondering how they know how hot they are running. Because by one method I'm ~10db hot, by another I'm onyl ~5db hot that is all.
Wouldn't a measurement show how hot the sub is running?
AustinJerry is offline
post #13352 of 13361 Old Yesterday, 03:11 PM
Alan P's Avatar
Quoted: 1225 Post(s)
Liked: 617
Jerry,
Well, that goes back to my OP (linked below)....I get seemingly differing results from a sweep than I do with Pink Noise and REWs SPL logger. I guess it really doesn't matter as long as it sounds good to me.
F.Cook likes this.
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC64ii, SUR: Polk LS F/X x 4, SUB: PSA T-18 x 2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #13353 of 13361 Unread Yesterday, 03:41 PM
tvuong's Avatar
Quoted: 379 Post(s)
Liked: 152
^^ you have to measure with -3dbsf in rew in order to have the correct absolute db. With this -3dbsf measurement at -30MV, your subs only (at Aud set level) should be along the 85db line, your speaker only should be along the 75db line. I always check these after running Aud and always find subs set -2db lower by Aud. Perhaps, Jerry should add the -3dbsf part to the guide if one wants to know the absolute db numbers. The default by REW is -12dbsf IIRC.
tvuong is offline
post #13354 of 13361 Unread Yesterday, 04:10 PM
Alan P's Avatar
Liked: 617
Ahhh, thanks tvuong. That makes sense.
That sweep above was done at -23dbsf and 0MV. When you say:
I'm assuming that be using the LFE output of REW (CH4), correct?
Audyssey 101
Audyssey FAQ
post #13355 of 13361 Unread Yesterday, 04:14 PM
tvuong's Avatar
Quoted: 379 Post(s)
Liked: 152
^^ yes sir, correct.
tvuong is offline
post #13356 of 13361 Unread Yesterday, 04:20 PM
Alan P's Avatar
Liked: 617
Sweet, gonna do some more sweeps tonight!
How bad is it I get excited when I have a REW project to do??
ahblaza likes this.
Audyssey 101
Audyssey FAQ
post #13357 of 13361 Unread Yesterday, 04:26 PM
tvuong's Avatar
Quoted: 379 Post(s)
Liked: 152
^^ running compression sweeps with -3dbsf will let you know the true highest db your subs can play before compression. Have fun.
tvuong is offline
post #13358 of 13361 Unread Yesterday, 04:53 PM
Liked: 1026
I disagree. Read the Guide section titled "Using REW to Set and Measure Speaker Levels" starting on p. 95. After reading that section, we can discuss if you disagree with the procedure.
post #13359 of 13361 Unread Yesterday, 09:48 PM
steveting99's Avatar
Quoted: 487 Post(s)
Liked: 151
Originally Posted by markus767 View Post
In any room the number of modes increases with frequency:
Markus,
A little confused by your graph. I was referring to the axial room modes determine by Harmon calculator here: http://www.harman.com/EN-US/OurCompa...ID=Calculators
Is our graph counting all the axial, tangential and oblique room modes + their harmonics going up to infinity? Thought above 500Hz, broadband absorbers such OC703 are quite effective.
Maranatz SR-7009, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
steveting99 is online now
post #13360 of 13361 Unread Yesterday, 10:00 PM
Audionut11's Avatar
Quoted: 129 Post(s)
Liked: 54
The room modes do increase with frequency as per the graph Markus posted. But it is this increase in modes that negates their effect.
A room mode enforces SPL at the frequency of the mode. So if we have modes at every hz between 20-80hz, we don't really have a problem, because every hz has the same level. And this is what happens at higher frequencies, there are so many modes packed so close together.
This is different to an reflection, which at high frequencies (as you note), can be easily fixed. At frequencies below 200hz, not so easily (when one considers WAF etc).
Audionut11 is offline
post #13361 of 13361 Unread Today, 02:17 AM
markus767's Avatar
Quoted: 1237 Post(s)
Liked: 488
The graph shows all modes.
From 80Hz to 500Hz it's a long way
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is online now
Dayton , Dayton Audio , Room Equilizer Wizard Rew
